Sponsored by BAVSOUND
Old 01-22-2008, 10:06 PM   #1
Bkz325i
N|Y|C
My Ride: 2002, 325i
Send a message via AIM to Bkz325i
Confused Like A Mo-fo!!!!!
Ok guy's Im not sure If this is the problem. But I jus put a Viper GPS security system w/auto start.
1. Ok to start it off.... My auto start doesnt work..
2. The main problem I HAVE A STRANGE AS$$$ Exclamation point Near the D in the dash... Please need help.. could it be that something is wrong with the connection to the alarm system?
LMAO.. my drawing is the worst...lol
Bkz325i is offline   Reply With Quote
Old 01-22-2008, 10:08 PM   #2
e34werkz
My Ride: F30
The ! means you have transmission problems. Any symptoms?
BMWCCA Member#395677
e34werkz is offline   Reply With Quote
Old 01-22-2008, 10:11 PM   #3
Addy25
My Ride: TitanSilber m3 Vert.
Send a message via AIM to Addy25
that exclamation point..means error in the tranny
Addy25 is offline   Reply With Quote
Old 01-22-2008, 10:15 PM   #4
Bkz325i
N|Y|C
My Ride: 2002, 325i
Nothing the car runs fine.....All i know is that this started showing once I put the Viper on.... Could there be something wrong with the auto start?
Old 01-22-2008, 10:29 PM   #5
Bkz325i
N|Y|C
My Ride: 2002, 325i
Why was I moved???
Old 01-23-2008, 12:31 PM   #6
DC323ci
My Ride: 2000 323ci
Send a message via AIM to DC323ci
Do you have an auto tranny or manual?
DC323ci is offline   Reply With Quote
Old 01-25-2008, 06:57 PM   #7
ca1242
My Ride: 2003 330i
where did you tap for the tach?
where did you tap for the brake?
disconnect one wire at a time and troubleshoot. Keep in mind that it takes up to 3 start cycles to reset the warning light once you fix it.
...or you can take it somewhere and have them read the codes.
Old 01-25-2008, 07:00 PM   #8
bmwstephen
My Ride: e46 325XI, e36 M3
its a voltage miscommunication between your tcu. Adding the viper alarm might have caused this. check the connections. This happen to me once when i was using an OBD Scanner while adjusting through the gears. It messed with the voltage readings
bmwstephen is offline   Reply With Quote
