Old 01-31-2008, 12:14 PM   #21
ice330ci05
My Ride: 2005 330ci
Originally Posted by bluejeansonfire View Post
He has an auto, his first gear ratio is completely different, and I think his 5th is overdrive, unlike ours.
Do you have schrick cams?
My car is ~3300 and runs a 13.689@100.01 w/ a 1.8 60', and a 8.8 1/8th
wow, thats one hell of a lounch there !!
no cams or headers on my car... only what i have in my sign...
how did you get 13.6 ? u have a s/c or ur NA?
ice330ci05 is offline   Reply With Quote
Old 01-31-2008, 12:17 PM   #22
dubplaya
My Ride: a car
Send a message via AIM to dubplaya
Get some headers and cams.
Shady and I put our cars head to head several times
(my Getta ran a consistent 14.3) and she would either beat me by a small amount or run even with me
dubplaya is offline   Reply With Quote
Old 01-31-2008, 12:18 PM   #23
kpeng
Banned User
My Ride: E46 330 and E30 325
I'm really contemplating the headers, but I don't want it to drone like crazy.
kpeng is offline   Reply With Quote
Old 01-31-2008, 12:19 PM   #24
dubplaya
My Ride: a car
decent muffler and a resonator should keep the drone down.
Old 01-31-2008, 12:24 PM   #25
kpeng
Banned User
I've got a Magnaflow muffler laying around here somewhere. You think if I put that in with a small resonator it'd be ok?
Old 02-01-2008, 01:02 PM   #26
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
I'm NA with cams and hedders, 3.38, i was running cheapie sumitomo's at the time as well. Right now my car is outfitted with 255/40r17 azenis 615s, paired with a LSD, I'm hoping for a 1.7 60'. I also just took some weight out of the car, and my weight reduction must continue. All i have is 16lbs wheels, 'lum e46 m3 hood, carbon csl deck lid. Now I also replaced the driver's seat. I'm eventually going to start tearing things off at an accelerated rate.
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 02-02-2008, 12:27 AM   #27
malina
My Ride: stock ZHP
You must be a super-dooper launch master to manage a 1.8 60' with sumitomos and ran 13.6@100.01
I remember having those tires was a nightmare. No traction in 1 & 2nd gears on a regular highway, not talking about awful drag strip surface prep on Moroso track.
malina is offline   Reply With Quote
Old 02-02-2008, 01:02 AM   #28
TiAgTouring
My Ride: has a D-Pillar
Here are the Specs on a stock 330i with the Steptronic
Road and Tracked clocked one 0-60 at 6.5, and 15.0 @ 94.0 for the 1/4
Given they are damn good drivers...Id say 15.4 for a tuned 330i isn't bad at all...
Just swap your engine for a 335i's, get a Vishnu V2 ECU, then youll be able to rock...
TiAgTouring is offline   Reply With Quote
Old 02-02-2008, 09:22 PM   #29
bluejeansonfire
ninja editor
My Ride: m5xual
I vote you do it first, before anyone else... pioneer my friend, pioneer
Or just save your money and time and purchase the far more capable 135i
Old 02-04-2008, 10:32 AM   #30
ice330ci05
My Ride: 2005 330ci
i know... thats crazy, i always feel bad for the car(clutch) when i lounch, so i don't push it that much, i dunno what it is, i just feel all bad inside and stuff when i'm about to do it lol..... but one time i did it a bit i got my 13.9 run so i was happy and left lol....
by the way, how do u guys clean out all that rubber off your rear bumper, i had soooo much the last time i went and i still have it on the car lol, well it's stored for the winter so when i take it out in few months i'll finish cleaning it, it shouldn't **** up the pait or anything right?
Old 02-04-2008, 01:48 PM   #31
bluejeansonfire
ninja editor
My Ride: m5xual
LOLLERCAUST!
I destroyed someone's wash mitt trying to clean that off
...my run, those were sumitomo's 255/40r17, ~-2.5 rear camber, 457lbs linear springs, pss9 shocks...the 1.89 was on a 13.7@100.01
I'm a little proud, to say the least
Old 03-26-2008, 09:07 PM   #32
FISHTAILN5OH
My Ride: 330i, 03 Cobra
Well, I'm new here, but I've been going to the drags for years. First of all, they make some tape you can put on your rear bumper so that you don't have to worry about getting rubber on the paint. Forget what it's called though, looks like painters tape, it's blue, and won't hurt your paint. Heck you might even be able to use painters tape...I just never have. I usually wash the car as soon as I get home, and remove any rubber with a claybar.
As for dropping your times...weight is your enemy. The easiest way to go faster, is to go lighter. Obviously, you aren't going to want to start stripping the interior or anything just to post a better time, but if you are running with the wheels in your sig pic I'd bet those are costing you. If I were you, my next mod would be a set of drag wheels. Get some light wheels, smallest diameter you can fit on the car. Put some DR's on the rear, and skinnies on the front. Reducing the rotating mass up front will help shave your times...I've seen people drop as much as half a second with a set of welds.
Icing your intake, and short belting the car can help lower times too. It all depends on how badly you want to drop the time. Usually people do that kind of stuff when they are on the cusp of dropping down into the next full second range (ie, from a 14.00 to a 13.99) etc. Other things to keep in mind...dont run with a full tank, a little less than 1/2 a tank should be fine. I often go with 1/4 tank or less, but the fuel in the tank does help keep the pumps cool so keep that in mind.
I'm tempted to run the 330 a the club track rental this may, but as it's my DD I'm a little concerned about breaking something. I think I'll probably just end up running the cobra or the focus, even though the cobra trans is now in need of a rebuild.
FISHTAILN5OH is offline   Reply With Quote
Old 03-26-2008, 09:11 PM   #33
FISHTAILN5OH
LOLLERCAUST!
That's a nice run..what do you have done? I'd be happy if my DD could cut a 13...of course, I also said I'd leave my first cobra stock...and then that I wouldn't touch the second one...
Do they have therapy for people with the mod bug?
Old 03-26-2008, 09:41 PM   #34
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
The 330 in stock form is almost industructible at the drag strip. I ran over 20 passes with mine in about 2 hrs.
The only time I've heard of transmission issues with this trans is when it's fed over 800 hp. (Same tranny as the E36 M3)
My stock clutch lasted more than 60k, (Including drag, and autocross use) and it looked fine when I removed it to upgrade the flywheel.
I've never heard of a diff failure on a 330 at the strip.
Run it and post your times!
Old 03-27-2008, 01:38 AM   #35
kpeng
Banned User
Thanks for the tips FISHTAILN5OH.
I don't think I want to go THAT hardcore and get drag radials, etc. I was going to run the car tonight now that I have headers, but there was a ton of cars out as it was the first Test & Tune night after Gatornationals.
I'll report back sometime next week.
Old 03-27-2008, 08:44 AM   #36
FISHTAILN5OH
Well, if nothing else a light set of wheels(or even just a stock set with DR's) will save your street tires...
Old 03-27-2008, 08:47 AM   #37
FISHTAILN5OH
Hmm...tempting. I may have to give it a shot just for the hell of it. I'll probably run the cobra at the May rental just because I want to get a full pass out of the car..
Old 11-16-2009, 09:18 AM   #38
downwithbrown7
My Ride: BMW M3 Droptop
i have a m3 vert with 103k miles i went to the drag strip yesterday and my fastest time was a 14.007 i didnt think that was bad considering i could not take off properly ( the track was slippery)
the time i did do a aggressive launch i spun through first and halfway through second and got a 15.6.
given that the track was as slippery as it was i figured i could get into 13.8-9 range. my car stock was 13.7s at 104mph
60-2.197
330-6.021
1/8-9.167
mph-78.86
1000-11.831
1/4-14.007
mph- 100.11
if you can keep your car better than stock (new) id say that would be an achievement congrats you did over.4 seconds better i did about .3 seconds worse.
downwithbrown7 is offline   Reply With Quote
Old 11-22-2009, 09:55 PM   #39
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
Wow I don't have my time slip in front of me but my best time is 14.3/96mph this is before my headers
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 11-22-2009, 11:06 PM   #40
e46techtuner
My Ride: 2000 328i
I ran my 2000 328i manual, at the drag strip back in 2004 when it was stock with full interior. I had my full size spare removed (50lbs) and floor mats. Had 225/45/17 tires (360 treadwear) on it at the time and ran a 15.4 at 92mph in 100 degree weather.
Im curious to see what it would run now...
e46techtuner is offline   Reply With Quote
