Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Old 01-30-2008, 06:09 PM   #1
dirtbiker245
My Ride: 00 323ci, 02 325i
Head Removal on E46
So Ive got a 323ci, and it blew a head gasket... still runs... but has low compression in two cylinders and uses coolant... usual head gasket problems.
So I have to change the head gasket. Im about... 40% there... (50% being everything taken apart..)
Anyhow, I have been doing all the work myself. Ive got the intake manifold off, today I got the VANOS off and got all the cam sprockets off. I am taking "decent" pictures and notes on the stuff... but nothing overkill... I will write up a little DIY when im all done for others on this site because when I was origonally looking for information on it, it was hard to find.
Ive realized the only two bmw speacialty tools you need are the camshaft locating fixture and the flywheel tdc locking pin... And you dont REALLY need the pin...
If anybody has any questions about head removal before i get the guide complete, ask me, and i'll be happy to help you out
dirtbiker245 is offline   Reply With Quote
Old 01-30-2008, 10:15 PM   #2
dpgrand
My Ride: 2005 330xi
good luck with the VANOS install. If it isn't perfect...there goes your engine!
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 01-30-2008, 10:50 PM   #3
vaio76109
My Ride: Race Cars
Subscribe. I assume you're using a Bentley manual or something? One thing to be very careful about is how you loosen and tighten the head back on the block as you don't want to bend the head.
vaio76109 is offline   Reply With Quote
Old 01-31-2008, 12:30 AM   #4
elite53
My Ride: Twin Screwed 325Ci
Very interested.
elite53 is offline   Reply With Quote
Old 01-31-2008, 01:13 AM   #5
ROYIII
My Ride: bmw 325ci
the vanos install is actually pretty straightfoward see http://www.beisansystems.com/procedu..._procedure.htm
its the timing i would be worried about.
and whether or not the head bolts will hold torque.
ROYIII is offline   Reply With Quote
Old 01-31-2008, 01:22 AM   #6
Toadfart
My Ride: 04 330i ZHP
Just don't reuse the head bolts and don't forget to lube them up to get an accurate reading with the torque wrench. Might not be a bad idea to replace the head bolts with ARP head bolts. Good luck!!!
Toadfart is offline   Reply With Quote
Old 02-01-2008, 12:21 PM   #7
dirtbiker245
new
The head bolts are one time use stretch head bolts, so yes, I will be replacing them. The vanos is actually not that big of a pain as people might be thinking. My friend has an M3 e46, ive just got a 323ci, but he had his head rebuilt, removed the vanos, and everything without even using the special tools. The special tools DO help though.. but the only one you really need is the "Camshaft Locating Fixture".
As far as the timing goes... its not super complicated... Basically you need to make sure that both the cams are at TDC. Theres two ways to tell this, first off, the first set of lobes (for cylinder one) must be pointing towards each other but up... forming an angle sort of.
and heres the camshaft locating fixture:
Another way to make sure the cams are in TDC is that the Camshaft locating fixture hooks on at the BACK of the cams... (rear of head). it goes over the two square spots.. They have 2 dots on the side of them that is TDC... So just make sure that the dots are facing up... then put the locating fixture on it and it is in TDC
The second thing for timing is the Crank must be in TDC. This is pretty simple... if you look down at the crank pulley, at the top of the crank on the block, there is a vertical line that protrudes from the block... its about 3/4 of an inch long. On the crank pulley itself there is "O/T" drawn where the TDC position is. Mine was worn off!!!!! so, that means before disconnecting the chain, put the engine in TDC by means of the cams, then the crank will automatically be in TDC, and make a mark on the crank pulley where it lines up with the line on the block... I hope that made some sense... I'll try and get some more pictures... If you have questions, ask, that way I can be sure to include the answers for it in the DIY im gonna write..
Old 02-01-2008, 12:28 PM   #8
dirtbiker245
Oh, also, there is a method that I have learned through Pelican for removing the camshafts and it does work without the need for the special tool from bmw to remove the cams... The cams are HOLLOW, and will break if they are taken off improperly. BMW claims they will break if taken off without the tool... This is NOT the case, because pelicans method has been performed by many, HOWEVER, I cant be held responsible for you breaking your cam nor can pelican... Its your decision to do this method or not. Its worked for me.. And should work for you too. Just remember, the cams are FRAGILE! And take all the precautions you can to not break them.. If you DO break them however, it would suck, HOWEVER its not the end of the world! I believe the cams are 500 dollars each from BMW... or something along those lines... so they CAN be replaced, but of course... you dont want to have to replace them... lol.
Old 02-01-2008, 04:26 PM   #9
dirtbiker245
progress update
heres an update on my progress. Head is OFF the block. Some little hints...
The REAR exhaust manifold bolts are pretty much impossible to remove because of their location... You simply cant get a tool in there.. So, I just undid the exhaust manifold at its joint to the exhaust pipe... and pulled off the head with the rear exhaust manifold attached to it, then unbolted it once out of the car. You probably could pull out the front exhaust manifold attached as well... but I chose to unbolt it cause it was possible fairly easily in the car.
I got the cams removed, lifters removed, and everything packed up in ziplock baggies and labeled. Now the head is off to the machine shop for a deep cleaning, get the valves ground/replaced, new valve guides, checked for cracks/warpage... And will be surfaced to provide a nice clean seat for the new head gasket
heres some pictures.
Old 02-01-2008, 07:32 PM   #10
dirtbiker245
And, im getting the valve seats ground... Should be pretty much a new head when its all said and done
Old 02-01-2008, 07:58 PM   #11
elite53
Great info so far. I would be very interested to hear some rough estimate prices for the work you are having done. Also, where it's being done.
Old 02-01-2008, 08:01 PM   #12
AdamBath
My Ride: E30
tell me about those exhaust manifold bolts! i had to get the front manifold out of there first, then get a universal out to get those in the back, from underneath the car...
AdamBath is offline   Reply With Quote
Old 02-01-2008, 09:06 PM   #13
dirtbiker245
im
well, I normally would have done the head work myself at my school, because they have a surfacer, valve grinder, and valve seat grinder, but im between semesters, so I cant use the shop
But im having it done at a place that a buddy of mine works. For 250 bucks he is doing a deep cleaning on it, checking for cracks/warpage, grinding the valves, grinding valve seats, Checking/replacing valve guides as needed, and then surfacing the head to clean up the bottom of it a little bit
I normally would just want to do it myself to save money, but when it comes down to it, im already short on time, so its nice to get a little break while the head work is being performed.
Other then the head work, im doing all the removal/installation myself.
Adambath, yeah... im glad to see I wasnt the only person having trouble with the exhaust manifold bolts! haha.
Old 02-03-2008, 01:43 AM   #14
dirtbiker245
Well, heres my plans for while the head is out getting the work done. I plan on doing a deep clean of my engine bay. It is filthy!!! haha. This will help to make it easier to work on in the future as well. I'll get some before and after pictures once I do it
Old 02-06-2008, 01:39 AM   #15
dirtbiker245
head should be back tommorow. Then i'll get some pictures of everything getting put back together again
Old 02-06-2008, 09:36 AM   #16
dpgrand
My Ride: 2005 330xi
cant wait to see some more pics man!
Old 02-06-2008, 11:35 AM   #17
Ted13B
My Ride: 07 Z4 Coupe
Before you go any further, drop the old head gasket in place, drop the head on, and make sure the head bolts will torque. When these engines overheat, the head can warp, lifting off the block, stripping out the head bolt threads in the block. BMW has a bulletin on this, and recommends checking for torque before you get too deep. If they won't torque, it's time for an engine.
Ted13B is offline   Reply With Quote
Old 02-06-2008, 01:14 PM   #18
dirtbiker245
Yeah
The head was checked for straightness and it didn't warp. I can understand how that could be a possibility, but keep in mind, the head bolts are stretch bolt for a reason so they stretch instead of hurting the block. Worse comes to worse, it would just strip out the threading in the block. Yes, thats not good, I know. LOL. But it doesn't mean your engine is over. You can repair threads with helicoil if you have to. My friend actually did that to his e30 and it repaired just fine.
Old 02-09-2008, 11:10 AM   #19
dirtbiker245
heads back
so the head is back from the machine shop... I will probably be working on it tommorow cause today I am working on my garage... but heres a picture
Old 02-09-2008, 11:12 AM   #20
dirtbiker245
oh
oh, and there was a slight crack in one of the water passages, but they were able to repair it Its got all new exhaust valves, new exhaust guides.. surfaced... the whole shabang
