Thread Tools Search this Thread Rating: Thread Rating: 48 votes, 5.00 average. Display Modes
Old 08-29-2011, 08:48 PM   #61
Mesa3077Boogie
My Ride: 325i Sport Package 0
Originally Posted by mp333 View Post
Lots of threads on this. Try the search engine......
ok well then how bout the kit i mentioned?
Mesa3077Boogie is offline   Reply With Quote
Old 08-30-2011, 12:08 AM   #62
mp333
My Ride: 2003 325XI
Well that too is on the forum.
bmwmercedesparts.com has cheap prices and good people to deal with.
And of course the sponsors.
http://directory.e46fanatics.com/sit...tesponsorindex
E46 & E90 Rocks
mp333 is offline   Reply With Quote
Old 09-05-2011, 03:10 AM   #63
westof5
My Ride: 2001 330i
t-stat tool
Mentioned is a thermostat tool and ways of getting around buying the tool.
I do not recommend the hammer technique because you will probably break something and the ST is cheap anyways.
I am super budget so after dangerously trying the wrench and hammer teq to no avail I needed the ST. Previous owner/mechanic was down there and did not put any anti-seize on the fan clutch bolt.
With the ST and help from a 280 lbs. friend turning the opp direction it came loose....finally.
I went to my indy and asked to borrow the tool over the weekend when he was closed anyways.
Borrowed a big friend and... ta dah!
Special Tool = 0$
big friend = 0$
running bimmer with new t-stat=.........not priceless but if got to NAPA on the second saturday of the month you get employee discount...
so oem t-stat at 50% price plus buy a case of beer and celebrate.
Dealership ~ $ 800
My way ~ awesome!
westof5 is offline   Reply With Quote
Old 09-05-2011, 05:40 PM   #64
E46M56
My Ride: 05 325i Sport Pakage
Special thermostat tool????
When you say special thermostat tool, are you talking about the tool to take off the fan? Because from what I remember, I only needed a special tool for the fan removal. Actually it was two tools, the holder and the special wrench. From there on, I only used regular metric sockets and wrenches. I did a whole cooling system replacement (radiator, expansion tank, thermostat, water pump, pulleys, tensioner and belts)
E46M56 is offline   Reply With Quote
Old 09-05-2011, 07:36 PM   #65
westof5
My Ride: 2001 330i
correct. i was a lil tipsy when i wrote that one.
Old 11-21-2011, 10:50 PM   #66
aleksankazakov
My Ride: 04 E46 330i sport
Send a message via ICQ to aleksankazakov
I just finished my DIY and I didnt remove the expansion tank, I had to take the whole assembly out because the tank would not come out. Then I hammered it off the plastic assembly . The AT thermostat broke off just as i expected. Plastic on that assembly and on the thermostat reminded me chocolate. It was crumbling easy with fingers. So now I replaced, the hoses, the expansion tank, the AT thermostat, the main thermostat and the assembly. Total part's cost exceeded 500 USD. I used prestone golden coolant . Everything mounted plug and play easily. My advice is not to remove old tank and just buy the assembly and the AT thermostat and put the new tank on the new assembly. Easier this way.
aleksankazakov is offline   Reply With Quote
Old 11-21-2011, 11:58 PM   #67
E46M56
What!? You didnt use the blue BMW coolant!? BIG mistake!!!!
Old 11-22-2011, 10:37 AM   #68
aleksankazakov
there is a forum about coolant, people agree that coolant is coolant ( as long as it is high quality) BMW also has synthetic oil BMW brand which is castrol which is 10$ more
Old 11-22-2011, 10:47 AM   #69
aleksankazakov
As long as the cooland or oil is German you can use it. BMW doesn't make coolant they buy it from coolant manufacturers. The same with oil. BMW brand oil is actually castrol full synthetic
Old 12-18-2011, 12:03 AM   #70
ralf
My Ride: 330i
I want to add something to the step of this DIY noted below:
Originally Posted by beberle View Post
4. Remove the expansion tank. Note: there's an electrical connection on the bottom of the expansion tank. Disconnect this 1st so that you don't forget while yanking the tank out. There's a hose on the side and two connections at the top. Have fun getting these off! Fortunately, you're replacing everything, so you don't have to be gentle Now for the fun part.. Yank and pull for all you're worth, straight up, to get the expansion tank out. Did you forget the quick disconnect that's holding it to the Transmission Thermostat? You've probably broken the thermostat, but you don't care because you have a new one. Pull straight up until you feel it release, then push the top of the tank away from the radiator and pull the rest of the way out.
You DONīT NEED TO REMOVE THE EXPANSION TANK FROM THE SUPPORT, you can actually take it off with the support attached without risking to break the transmission thermostat, which would add $60 bucks to your repair expenses.
To remove the expansion tank with the support you will need to remove all the hoses and the transmission cooler first of course, and 2 torx screws, one is located in the upper part, side of the radiator by the headlight. The other is below the expansion tank, facing the engine side, once you remove them you can just pull the entire assembly from the base of the radiator towards the engine and it will pop off, thereīs only one connecting pipe with an o ring and thatīs all. You can remove the expansion tank with its support base out and follow the DIY.
Of course, when you locate both torx screws you will notice that the position is almost impossible to access with a torx screwdriver, thatīs when you will need this tool : http://www.homedepot.com/h_d1/N-5yc1...1&ddkey=Search using this and the appropiate torx bit (T25), you can remove both screws and do the job without problems. Also, the tools is very handy for other uses and is less expensive than a new transmission thermostat.
ralf is offline   Reply With Quote
Old 06-11-2012, 08:17 PM   #71
tommersyip
My Ride: 2004 BMW 330ci
Just wanted to add a little something in terms of radiator fitting.
So in Dec 2010 I did this whole overhaul, went OEM with everything except the Behr Radiator for my 07/2004 built 330Ci - well the mounting plate didn't line up with the holes (off by 0.5cm -1.0 cm) and gave up on replacing the radiator. Well, finally the radiator is going. Going with Modine this time around
BMW CAN DO NO WRONG - except buna VANOS seals, brittle engine plastic, plastic water pumps, and a headliner that likes to drop on me to keep me awake while I drive.
tommersyip is offline   Reply With Quote
Old 06-20-2012, 01:22 AM   #72
srbija 328i
My Ride: has 262k miles
Great job op
M@R!O
srbija 328i is offline   Reply With Quote
Old 08-11-2012, 11:10 PM   #73
nughaud
My Ride: '01 330CI / '11 335i
I didn't need to remove the transmission cooler when I removed my radiator.
Here's some photos. There are two torx screws on the upper right driver's side and lower right driver's side that hold in the radiator besides the two that run across the top. It took me a bit to find those, but other than that the only issue I had was with the lower radiator hose. It would not come off and there is no room to put your hand in there to remove it, because it sits so close to the a/c compressor. Since I had the front of the car jacked up, I was able to just remove the other end of the hose from the thermostat and then drop the radiator. Once it was out from under the car I was able to pull straight up from the radiator a few times and finally that damn hose came off. That was the worst part for me. Now, just waiting on a new radiator. My wasn't leaking but the top right hose connecter section on the radiator literally broke off, so there was no temp patching that thing up.
You can see in the 2nd photo, that's what's left of my automatic transmission thermostat.
nughaud is offline   Reply With Quote
Old 01-18-2013, 04:46 PM   #74
Rumplemenz
My Ride: 05 330i zhp/15 335i
Just wanted to agree with the OP in regards to getting new hoses (upper and lower) when you replace the radiator. I speak from experience. My original hoses did not connect well at all to the Behr radiator. Both upper and lower leaked. The outlet and inlet on the Behr radiator seemed smaller than the original. The hoses were lose upon fitment. In the mean time I wrapped some electrical tape around the radiator connections so the hoses were more snug upon connection. This will hold me over until I get new hoses. Don't be like me. Get new hoses from the start.. !!
Rumplemenz is offline   Reply With Quote
Old 03-11-2013, 02:04 PM   #75
FreshNation
My Ride: 01 325i
Pictures of the 'wedge mounts' on the side of the radiator and corresponding mounts in the car.
Is that plastic peace on the side of the radiator in picture two replaceable or do i have to get a new radiator. Mine cracked and its blowing out steam
FreshNation is offline   Reply With Quote
Old 03-11-2013, 02:28 PM   #76
beberle
My Ride: 2009 328 wagon
The mounts are part of the side radiator plastic. Your radiator is shot unfortunately.
I hate dealing w/ the cooling system :-/
Good luck!
Brian
beberle is offline   Reply With Quote
Old 11-24-2013, 02:24 PM   #77
emrys
My Ride: 2002 E-46 M3 cabrio
The leak persists?
What follows is a (sorry to be long winded) question, in search of an answer.
But your DIY was golden, flawless and I thank you for it, Bentley was useless.
I followed your DIY to the letter, right down to having to cut off the lower hose. All my parts are new save one fixture on the expansion tank mounting bracket(looking down its on the right side, is mounted on a diagonal. Put it all back together filled it
started it and its leaking on the expansion tank side, and I'm not getting hot air in the cabin, any suggestions?
emrys is offline   Reply With Quote
Old 12-20-2013, 05:38 PM   #78
CharlzO
My Ride: 2000 328ci
Double check for the seal of the ET on the mount, sometimes it doesn't get seated all the way, or might be an O-ring missing there. Is it possible to identify where exactly your leak is coming from? Probably not getting heat due to excess air coming in through that. But it does depend on where it's leaking as to the possible causes.
CharlzO is offline   Reply With Quote
Old 11-14-2014, 05:33 PM   #79
brae46den
My Ride: 2003 325i
Originally Posted by Mango View Post
The mounting plate to the expansion tank needs to securely be mounted together with the tank. You will know it is securely mounted when the push-in clip "clips" into place. If you simply push it, but don't feel/hear it "snap" into place, then the tank isn't mounted properly. This will result in a leak. It takes some good elbow grease to mount that tank securely. Just push hard while wiggling it back and forth. The sealing ring is very tight so it takes lots of pressure to mount correctly.
A good tip for doing this is mount the mounting plate to the radiator and the expanion tank to the mounting plate while OUTSIDE of the car. So have the radiator outside the car then mount all three pieces together before dropping it into place. This ensures you have everything snug.
SO GLAD you said that.
brae46den is offline   Reply With Quote
Old 11-18-2014, 09:06 PM   #80
Diegoe46
KwliUdjcisixkskdjxisjsjjsisk b j nlrmmehu :
D
M.
Diegoe46 is offline   Reply With Quote
