Old 02-04-2008, 07:29 PM   #1
adaseb
My Ride: 2002 BMW 320i
Having Airbag Problems (Drivers Side)
Basically about a year ago I got an airbag light. So bought the reset tool and clear it. It was "Firing Circuit, Driver Airbag, Stage 2".
Then a couple weeks ago it went on again. This time it got
"Firing Circuit, Driver Airbag, Stage 1".
I cleared it and it came back the next day.
So I took the airbag out to look for loose connections and all looked fine.
So anyone got a clue to what can be causing this?
A picture of my airbag is (back side)
and my airbag looks like (not my car)
I found an auction on eBay with my exact airbag
http://cgi.ebay.com/ebaymotors/ws/eB...m=220197598695
However I dont know if i'll work. Because I heard some airbags are stage 1 or stage 2, and they look exactly the same.
Any input?
adaseb is offline   Reply With Quote
Old 02-04-2008, 07:44 PM   #2
mistrzmiasta
My Ride: GLK350,ML63,Duc 748
I would find out before purchasing it if its compatible with your car....airbags WILL save your life in an accident so don't risk it....dealer will tell you what you have according to your vin...
mistrzmiasta is offline   Reply With Quote
Old 02-08-2008, 09:39 AM   #3
adaseb
bump...
Old 02-10-2008, 01:58 PM   #4
adaseb
... another bump
Old 02-12-2008, 01:37 PM   #5
adaseb
I am surprised there is noone else who is having this problem.
Old 02-12-2008, 02:45 PM   #6
mechanic_101
My Ride: 2005 325I
Always disconnect the battery when working around airbag. New vehicles, they likely have 2 stage airbag system which is the airbag deployed twice to reduce the force of the first deployment. Locate the airbag module and check the resistance between the connectors at the module to the steering wheel connector. Check for any signs of any corrosion. Check the stage 1 and 2 micro connectors at the airbag. You can rent a load tool and plug into the connector at the steering wheel. If the airbag light turns off, then you have a bad airbag. If remains on, then something is wrong with your wiring from the module to the bag. Again, make sure battery is disconnected when working around airbag.
Note: a load tool is used to simulate the airbag for preventing inadvertent deployment.
mechanic_101 is offline   Reply With Quote
Old 02-12-2008, 04:19 PM   #7
Ted13B
My Ride: 07 Z4 Coupe
Also, never check resistance with the airbag connected. A mulimeter puts out enough voltage to trigger the bag.
Ted13B is offline   Reply With Quote
Old 01-21-2009, 06:41 PM   #8
adaseb
I am bumping this topic but again after almost 11 months the light came on again. Anyone had a similar issue?
Old 01-21-2009, 06:49 PM   #9
JK1150
My Ride: 2004 325CI
never seen a wheel like that without radio/cruise controls in an e46. I see it's a euro though, interesting to see though.
JK1150 is offline   Reply With Quote
Old 01-21-2009, 07:34 PM   #10
rays330ci
My Ride: 03 330ci
Where can I get a load tool? Mines will not reset also.
rays330ci is offline   Reply With Quote
Old 06-17-2011, 01:26 AM   #11
timheidi
My Ride: 2002 525i
I have the EXACT same problem
I also have the codes "firing circuit, driver airbag, stage 1" and "firing circuit. driver airbag, stage 2", and find other problems will start to arise ie "check brake light" indicator light when brake lights are fine, horn will stop honking, steering wheel adjuster will move on its own . . .
timheidi is offline   Reply With Quote
