Thread Tools Search this Thread Rating: Thread Rating: 39 votes, 5.00 average. Display Modes
Old 05-16-2009, 01:25 AM   #41
bmwownage
My Ride: 330i
I don't understand, so a car that did not came with Cruise control, will have cruise control after installing this properly? i always thought cruise control is some kind of a computer chip that is required?
bmwownage is offline   Reply With Quote
Old 05-16-2009, 06:10 AM   #42
Cazz
My Ride: 2005 BMW M3
Cruise control comes programmed into the DME for the "drive by wire" e46s. It takes a MF steering wheel and a couple of wires to enable and control it.
Here is a thread on this topic: Thread
Cazz is offline   Reply With Quote
Old 07-04-2009, 01:55 PM   #43
malcpace
My Ride: BMW E46 318d 2004
could some one put a wiring set on ebay for people to buy it would be a great idea, here in malta i cannot find a retrofit harness.
malcpace is offline   Reply With Quote
Old 07-31-2009, 09:40 AM   #44
loayo
My Ride: 2001 M3 Coupe
I wish I can add this feature to my car. Ever heard of this? Perhaps map it to the sport or DSC button?
Regards,
Loay
2001///M3/PowerchipGroup/Eisenmann/Race Flow S-Pipes/AFe Stage II/AutoSolutions/ZCPs/NGK Ir/ULF/JL Audio Amp/Sub/Clutch-Stop 12.8" 1/4mi
1990 Honda Civic DX Hatch B18c1(GSR)/CAI/Greddy Exhaust/DC Sport/H&R/Suspension Techniques/Tanabe/KDWs/Pulstar/Apex Blue Pearl from 2008 S2K CR 14" 1/4mi
2002 Odyssey EX - Secret Weapon R/Pulstar/CAI 15" 1/4mi
2011 Camry V6 SE - Uper Optik 14" 1/4mi
2001 330ci Dinan S1 [Sold]
loayo is offline   Reply With Quote
Old 09-12-2009, 06:06 PM   #45
kensou
My Ride: ///M3 E46 cab
Send a message via MSN to kensou Send a message via Yahoo to kensou
Hi,
I just successfully replaced a nonMF 3 spokes SW by a MF round airbag SW, all is working fine !
Thank you again for your great DIY, clear and simple.
kensou is offline   Reply With Quote
Old 09-21-2009, 05:30 AM   #46
webboy
My Ride: 2004 330xd
I just replaced a non MF 4 spoke wheel with a MF M sport wheel. Worked out well except I had different DME/DDE connectors than in the PDF, but I was saved - http://www.bimmerforums.co.uk/forum/...83/#post193780 FYI I have a 2004 300xd Touring that originated in Germany in case that is helpful for anyone...
webboy is offline   Reply With Quote
Old 10-31-2009, 08:27 AM   #47
PatrickS
My Ride: 320Ci
Thanks very much for this guide, just put a MF unit into my 320Ci. I had to using this number to order the wiring kit though:
61 12 0 016 012
On a right hand drive car you need to take out the glove box, access to the wiring box is behind there
www.msportster.co.uk Marlin Sportster Build Site - BMW Power
PatrickS is offline   Reply With Quote
Old 01-24-2010, 01:03 PM   #48
johnmcgill
My Ride: 330ci
RE: Small hole in Firewall
Great DIY man. Cheers.
I decided to take a photo of the hole which the blue wire passes through before I put everything back together.... Just incase anyone gets stuck at this part... Cos I was worried about finding it.
Blue wire is running from Right hand side of the photo.
This is obv a RHD car and the photo is of the removed glovebox side but I presume its the same kinda hole in a LHD car behind the steering assembly.
Thanks again!
John
johnmcgill is offline   Reply With Quote
Old 01-24-2010, 03:01 PM   #49
Cazz
Finding the pass through took me a while. Here is a pic (not mine) from a LHD car. The RHD car is probably harder to get at because fuse box.
Old 03-06-2010, 12:56 AM   #50
jdl8r
My Ride: nothing yet
Cazz, and others, this truly is a fantastic thread with some great photos etc. I finished mine (second attempt) in about 3 hours. Granted I was going slowly so as not to break anything and double checking everything before I soldered any connections etc.
The reason I purchased my 06 ZCP was because of this thread. I wanted the competition package, but I am one who also needs cruise control. Now I have both! I find it remarkable how powerful user forums are in regard to the knowledge, sharing, and value to owners. I am really surprised there aren't more manufactures (BMW) found supporting these sites?
Thanks again for everything, everyone!
jdl8r is offline   Reply With Quote
Old 03-06-2010, 02:06 PM   #51
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
bump for dayclone
delmarco is offline   Reply With Quote
Old 03-23-2010, 11:45 PM   #52
dayclone
My Ride: 01' 320i
So I followed the instructions and added a wire into pin #27 of my DDE under the hood, and the cruise control still doesn't work....
Wth is going on here. I had to run the wire from my steering wheel to the fuse box on the RHS and then through the firewall that way instead of running 30 cm behind my pedals... regardless do I have to enable this feature at the dealership? or what should I do?
Please advise.
Thanks!
dayclone is offline   Reply With Quote
Old 03-24-2010, 06:31 AM   #53
Cazz
Fuse box? The wire that connects to the DDE goes to the steering column switch, pin 8. That is in the PDF file A6 and A1 are connected.
No dealer activation.
Old 12-20-2010, 05:00 AM   #54
Fen
My Ride: 330Ci Cabrio
Thanks StavKon and everyone else who added to the DIY, especially johnmcgill for the invaluable picture of the hole that I couldn't find.
Fen
Fen is offline   Reply With Quote
Old 06-22-2011, 09:20 PM   #55
yuting lin
My Ride: bmw 323i 2000
BMW pdf instruction file
hello, could you send me BMW service manual for 2000 323i sedan PDF to my email
thank you
l1233799@hotmail.com
yuting lin is offline   Reply With Quote
Old 08-07-2011, 06:06 AM   #56
tommyg318
My Ride: bmw e46 318
Ive started to do this retro fit. It was all pritty easy to install with the help from this quide, thankyou again, but ive encountered a problem. I have the the bmw e46 318 54plate facelift model. The DDE control module is different from the one in this guide and I dont want to wire the harness up to the wrong connector in case anything goes wrong. Can anyone shed some light on this issue. Ive included some pics of the module and the two different plugs.
tommyg318 is offline   Reply With Quote
Old 08-07-2011, 10:55 AM   #57
Cazz
A couple of questions:
1) Which engine do you have?
2) On your pic, there is a blue dot. Does the connector pull apart there?
Old 08-07-2011, 05:39 PM   #58
tommyg318
I have the N46 engine. This is the DME module:
Yes the connector with the blue dot does come apart. I have already inspected it because I found this information on the DME module:
http://tis.spaghetticoder.org/s/view.pl?1/09/88/03
It clearly says that the wire for 'E46 Signal from cruise control (right-hand button pad on multi-function steering wheel)' goes into slot 4 of the 'connector X60002, 26-pin'
. But there is already a wire in that slot so havn't got a clue where to put it.
Old 08-07-2011, 06:58 PM   #59
Cazz
OK. I found that too.
You might read thru this
It is a google translation of a German site so my understanding is not going to be perfect.
Only vehicles with N46 engine
Female terminal branch separated from the A6.
Branch A8 using butt connectors (1) and
Shrink tubing (2) at the open end of the cable
A6 connect feeder.
Black, 58-pin plug X60002 from the
DME control unit unlock and remove.
Branch A7, einpinen to PIN 4 of plug X60002.
Assemble and plug X60002 on DMESteuergerät
reconnect.
Perfectly clear, right?
It looks like there is a slightly different retrofit wiring kit for the N46 that has a pin connector that fits into fits into that socket. The blue wire is extended (using a butt connector) by a brown wire.
In the posts down the page it looks like someone just tapped into the existing wire on pin #4 of x60002 to reuse the connector. I think he just clipped it.
Also note, that the link and the picture you posted are mirrored because one depicts the socket side and the other the plug side.
Good luck.
(Disclaimer time: I'm not a mechanic and I haven't done this before. I don't speak German. I take no responsibility for anything at any time.)
Old 09-30-2011, 08:15 AM   #60
Angelic0-
My Ride: BMW E34, E46 & E38
Send a message via MSN to Angelic0-
Sorry for a rewake of an old thread...
This will make cruise control work 100% ??
Angelic0- is offline   Reply With Quote
