Thread Tools Search this Thread Rating: Thread Rating: 39 votes, 5.00 average. Display Modes
Old 12-13-2012, 11:45 AM   #101
MazoMania
My Ride: BMW 318ci
Originally Posted by Xssxexile View Post
has anyone in the UK done this,
I have a v reg 328ci and have bought the m3 multifunction silver wheel and cable set.
I am too scared to complete this on my own and was wandering if someone has already done this would they care to help me do mine.
I will drive to them of course.
Do you have manual instructions in PDF and year of your car is?
MazoMania is offline   Reply With Quote
Old 12-14-2012, 04:29 AM   #102
Xssxexile
My Ride: E46 328ci
Its a 1999 v reg 328ci
and i have seen various instructions online but they all seam to be a little different. which is the worying bit.
Xssxexile is offline   Reply With Quote
Old 12-14-2012, 08:01 AM   #103
MazoMania
My Ride: BMW 318ci
I have 2 instructions in PDF, If you want send me your email address and I will send to you. This is realy simple to do. I' didn't buy orginal cables because it's cost too much. I made the cables myself and I'am not electrician I think that you can make only radio control and lightining ( I did like that ) to work because your engine is M52 and if you want to do a cruise control that will be a bigger problem, you have discribed all that here on this forum about cruise control.
Old 12-14-2012, 10:51 AM   #104
Xssxexile
My Ride: E46 328ci
thanks, the light up wheel and stereo controls would be a cracking start and it will look brilliant. I have sent you my email address. thanks for the help.
Old 12-18-2012, 09:01 PM   #105
Boboshanti
My Ride: e46 330i and 316i
Hello, I would be very grateful if you could better explain this to my understanding.
I have a 2002 330i M54 engine. Its fully equipped with cruise control. It has a 4 spoke Multifunction steering wheel.
I also have a 2002 316 N42 engine also with 4 spoke steering wheel but without multifunction buttons on it.
I drive the 2002 316 mostly and i would like to know if it possible to equip it with the cruise control from my 330i.
Boboshanti is offline   Reply With Quote
Old 12-18-2012, 09:37 PM   #106
Cazz
My Ride: 2005 BMW M3
The N42 is listed in the PDF, so I *think* it is the standard swap.
Here is one location (there are more).
http://www.kneb.net/bmw/E46/Multifun...20retrofit.pdf
Cazz is offline   Reply With Quote
Old 12-23-2012, 05:59 AM   #107
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
I have an '04 with a four spoke steering wheel with multi function controls including cruise control. Do I still need the retro fit wires/cables to do this swap or is it direct plug-n-play? Thanks in advance.
omni01_k is offline   Reply With Quote
Old 12-23-2012, 07:40 PM   #108
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
bump
Old 01-14-2013, 05:52 AM   #109
maxi
My Ride: BMW E46 328I, 1999
my car is e46 1999 328i Euro spec. I've done this retrofit in my car, I had square leather non multifunction before. I retrofit the sport 3 spoke model and every thing working fine, Radio control, Cruise control. I recommend this DIY.
Thanks for you all for your help.
http://forum.e46fanatics.com/signaturepics/sigpic64570_1.gif
maxi is offline   Reply With Quote
Old 01-14-2013, 07:36 AM   #110
Boboshanti
Thanks for the Info. It is a normal swap just as you said. my cruise works good on my 316 now. (any idea why the volume control keys dont work?)
Old 01-14-2013, 08:02 AM   #111
Boboshanti
Its just plug and play for you. you already have it installed.
Old 01-14-2013, 08:55 PM   #112
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
Awesome. Thank you guys
Old 04-29-2013, 07:29 AM   #113
macming
My Ride: 05 Mystic Blue ZCP
Originally Posted by StavKon View Post
As the title suggest this post describes how to retrofit the mfl buttons on a M3 steering wheel (from what I've seen it should be ok for the other types of steering wheels too.) for E46 models from 6/2000 and onwards.
I'm about to try out this guide tonight. What is this cable for? I bought the official wiring kit, and I don't see anything similar in there.
Also, once I'm inside the DME box, do I just insert the wire into PIN27 and nothing else? The official BMW guide said to connect A6 to A8 for some reason.
Thanks!
Ming
macming is offline   Reply With Quote
Old 04-30-2013, 01:06 PM   #114
Cazz
Thanks!
Ming
That connects the MFL panel to the steering wheel.
If you are doing the ZCP conversion, you already have it. The one button panel uses the same connector.
...and yes, pin27 should be the only thing to hook up in the DME. Looks like A8 is only for M47TU diesel engines.
Old 04-30-2013, 02:26 PM   #115
ocellatus
My Ride: 325i 2005
Cazz, I'm going to do the retrofit on a late 2004 325i with four spoke non MF steering wheel. I've ordered an M sport MF steering wheel and the cruise control cable set, waiting for them to come. But I'm a little confused with that small cable mentioned in the first and last posts, do I need that?
ocellatus is offline   Reply With Quote
Old 04-30-2013, 04:17 PM   #116
Cazz
It is included as part of the steering wheel.
It is part #5:
Link
Old 05-09-2013, 07:59 AM   #117
ocellatus
My Ride: 325i 2005
Thank you Cazz, it was included.
I'm gonna do the wiring tomorrow but so far the first part which is swapping the 4-spoke steering wheel with an M sport multifunction wheel is done.
Could you guys please look at attached pictures and tell me the airbag is properly fitted or not?
I've not had a close look at a factory installed M sport steering wheel but in my setup the gap between the wheel and upper edge of airbag seems to me more than what its supposed to be.
Was there anything to adjust how deep the airbag sits?
Steering wheel is brand new but the airbag I bought is second hand. Don't know if this has anything to do with the fitting issue.
ID:	504735   Click image for larger version
ID:	504736   Click image for larger version
Old 05-10-2013, 11:38 AM   #118
ocellatus
My Ride: 325i 2005
Any idea about the airbag issue?
I just finished the wiring and everything works just fine!
Old 05-10-2013, 12:03 PM   #119
omni01_k
omni01_k's Avatar
My Ride: 2014 335i
Nice job man.
Old 05-10-2013, 10:17 PM   #120
Cazz
I does look a little high. You might take the airbag out, make sure all the wires are sitting out of the way and put it back in. Either that or just smash the horn a few times
