Old 04-29-2015, 12:44 PM   #1
sdonnelly
My Ride: 2002 320i
smoking from the block
Im a noob amd am look for some help, uploaded some pics and was hoping someone may be able to provide any help on where this leak that is causing block smoking when hot, is coming from. Anything helps, thanks
ID:	599103   Click image for larger version
sdonnelly is offline   Reply With Quote
Old 04-29-2015, 01:27 PM   #2
SilberVogel
My Ride: 2002 330Ci Conv.
Looks like your valve cover gasket (VCG) is leaking; common issue and easy fix.
See this thread on common oil/coolant/fluid leaks with photos: http://forum.e46fanatics.com/showthread.php?t=882732.
And there are plenty of DIYs out there you can reference if you search around. Would recommend using the OE Genuine BMW gasket, be sure to pick up 15 new grommets for the bolts, and be mindful of the torque/tightening steps when you tighten things back down. Below are a few resources, but would be worthwhile to read up on others' experiences.
Depending on the maintenance history, there may be other areas you want to address "while you're in there" (spark plugs, vacuum lines, cabin air filter, etc.).
Here's Beisan Systems' VANOS DIY that also covers much of the VCG (very clear steps/images/torques specs/etc.): http://www.beisansystems.com/procedu..._procedure.htm.
And here's a good video series by BavAuto:
Hope some of this helps, and you'll find a wealth of information if you search the forums, as well. Good luck!
Edit: here's a more thorough post of mine re: VCG from over on Bimmerfest: http://www.bimmerfest.com/forums/sho...34#post9066334.
DIYs help you save money with repairs; let www.bmwpnpc.com help you save money with the parts.
SilberVogel is offline   Reply With Quote
