Old 02-08-2008, 05:43 AM   #1
etl45
My Ride: 325Ci
Corner Delete Mod
So i read the corner delete mod DIY from start to finish! all 10 pages~ haha
so from my understanding.. only way not to damage the LMC? i think thats what its called... is to use LED sidemarker bulbs and LED front turn signal bulbs~
anyway to do this without using LED buls???
cause for my car.. the LED side marker bulbs stay dimly lit all the time and i hate that!!! haha
thanks~~~ i hope i dont get flamed for this question!
i just really want to do this because got some yellow 3000k HID fog lights.. and would look soo much better without thoes turn signal bulbs on!
etl45 is offline   Reply With Quote
Old 02-08-2008, 03:30 PM   #2
sillieidiot
My Ride: '06 AW 330ci
lcm or lsz is what it's called.
you don't really need LED sides, it'll help, but just using LED corners is a big help already.
Old 02-08-2008, 04:59 PM   #3
etl45
My Ride: 325Ci
so i should be fine with just front LED turn signals?
Old 02-08-2008, 05:14 PM   #4
sillieidiot
yes sir
Old 02-08-2008, 05:18 PM   #5
Custom3
My Ride: HellRot 330CI
i did the corner delete mod a year ago with regular bulbs and its still working fine....no need for leds
Old 02-08-2008, 07:31 PM   #6
etl45
My Ride: 325Ci
hmmm well i guess its better safe then sorry~
i guess i will be buyiing some led bulbs from jlevi haha~~~
so resistors for the led bulbs.. but then resistors again to fool the ecu? lmc?
Old 02-08-2008, 07:38 PM   #7
sillieidiot
you only need the resistors for the corner delete part. then just put LEDs for the corners. when you're done with the corner delete, the corners will be part of the sides. the ecu does not check the sides for bulb out, so you won't need another pair of resistors.
