Door refurbish - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-31-2014, 11:43 AM   #1
Cowspoo
My Ride: 328Ci
Door refurbish
Hey guys. So my door is old, stiff, and creaky. I'm sure it didn't roll off the lot feeling this way. What are the parts that I can replace to get that smooth factory door feeling again?
spacebarissolazy
doesntfeelikebeingpressed
Cowspoo is offline   Reply With Quote
Old 12-31-2014, 12:11 PM   #2
Gunsnbacon
My Ride: 2001 330ci
lube up the hinges and take the door card off and replace all the little trim clips with the foam washer ones
for the door handle creak, you have to disassemble it and use a silicone sealer in the clips on the inside of the handle
-List of Modifications-
2001 Alpinweiss 330ci ZSP
Gunsnbacon is offline   Reply With Quote
Old 12-31-2014, 02:17 PM   #3
Cowspoo
My Ride: 328Ci
Which lube should I use on the hinge? Would silicone grease work? I know some lubes can cause paint damage.
I notice a rubber strap in the hinge. Has anyone replaced that?
spacebarissolazy
Old 12-31-2014, 02:27 PM   #4
Gunsnbacon
My Ride: 2001 330ci
get some white lithium grease and spray it on the hinge and move it around, then wipe up the mess... should work well enough
Old 01-01-2015, 08:20 AM   #5
markusmarkus
My Ride: 2001 330Ci
Nah! Use Wurth's HHS-K spray lube. It's expensive but it works!
Old 01-05-2015, 02:54 PM   #6
Cowspoo
My Ride: 328Ci
Thanks for the suggestion! I'm able to find it for about $20. Is it worth that price when white lithium is about 5
spacebarissolazy
Old 01-05-2015, 05:49 PM   #7
Ceric
My Ride: 2005 BMW 325i
Make sure you also replace the door brake for that crisp factory new door feel.
Part #5 here:
http://realoem.com/bmw/showparts.do?...01&hg=41&fg=40
Ceric is offline   Reply With Quote
Old 01-05-2015, 07:14 PM   #8
Cowspoo
My Ride: 328Ci
Part #5 here:
Bingo! You rock
spacebarissolazy
