Old 02-08-2008, 07:05 PM   #1
jeremyt
My Ride: 2003 325xi
enon leveling issues
When you turn the lights on they would go straight down and just sit there for a minute then not move. i thought they needed adjusting so i manually adjusted the headlights up. They are now in a good veiwing position when on but they are not really self leveling. Now when i start the car they go from the position i set them at drop to the bottom then come back up to the same position. Is there a way to reset the lights for a home position or do you think my sensor is bad? I have already checked the sensor and evrything is connected to it and plugged in.
thanks.
jeremyt is offline   Reply With Quote
Old 02-08-2008, 07:08 PM   #2
LW///M3
My Ride: 05 Sti >> E46 M3
did you recently have springs or suspension installed?
2009 ///M3 Space Gray on Fox Red
LW///M3 is offline   Reply With Quote
Old 02-08-2008, 09:03 PM   #3
jeremyt
My Ride: 2003 325xi
i had the cv boot replaced on the passenger side, and they said they would fix it if they messed it up but there incompitent and said well the rod is hooked up and the sensor is plugged in we dont see anything wrong.....
I know thats where the sensor is, could there still be something they did when they fixed the cv boot...
Old 02-09-2008, 09:40 AM   #4
jeremyt
My Ride: 2003 325xi
or is it just by chance that the sensor went bad while they had it.
Old 02-09-2008, 04:38 PM   #5
sillieidiot
My Ride: '06 AW 330ci
sounds like they broke the leveling arm that's part of the sensor. take off your passenger wheel and check to see if the plastic arm is broken or not.
Old 02-10-2008, 12:22 AM   #6
jeremyt
My Ride: 2003 325xi
ok, ill check it out
Old 02-11-2008, 09:14 PM   #7
jeremyt
My Ride: 2003 325xi
leveling arm looks to be good....
