Old 02-08-2008, 09:34 PM   #1
deepest green
My Ride: green machine
angel eye turns off when car turns on.
very weird.
when my car is unlocked. the eyes turn on.
but when u swtich the key position in 2 and position 3.
it turns off....
its only happened recently... i had the p46s installed at least a year before
anyone know what is the problem?
thanks
deepest green is offline   Reply With Quote
Old 03-06-2008, 01:21 PM   #2
dan1539__323CI
My Ride: 2003 3x Black Z4 3.0
Same Here!!
I don't know why now. They've worked fine thus far and now they go off when the key is in those positions. I checked the wiring and everything looks fine. Blown fuse? ECU wiring??
dan1539__323CI is offline   Reply With Quote
Old 03-06-2008, 02:00 PM   #3
DrusC5s
My Ride: 2004 CB M3 SMG II
Send a message via AIM to DrusC5s Send a message via MSN to DrusC5s Send a message via Yahoo to DrusC5s
Originally Posted by deepest green View Post
very weird.
it turns off....
thanks
It's the fuse, or wiring around the fuse. I had the same problem for a while.
-Dru
DrusC5s is offline   Reply With Quote
Old 03-06-2008, 02:05 PM   #4
dan1539__323CI
Did u simply replace the fuse? I thought this was the prob. but wasn't sure. Thanks Dru!
-Dan
Old 03-06-2008, 02:48 PM   #5
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Check the fuse first, if it is in tact, check the red wiring into the fuse holder.
Old 03-06-2008, 02:49 PM   #6
sillieidiot
My Ride: '06 AW 330ci
it's either your fuse, or the ecu tap not getting a good connection
Old 03-06-2008, 03:25 PM   #7
grnbmr808
My Ride: green 4 da money 323
5% tint-cf emblems-blackout grill-smoked front corners and side markers-smoked led tails-alpine iva-d105 dvd deck-7 inch headrest screens-alpine mids/highs-15" kicker L7 sub-3000 watt sub amp-600 watt 4 channel amp-3 farad cap-removed 3rd brake light-debadged-xenon bulbs in exterior-xenon interior coversion-green fogs-replaced all trims/cowl-shaved antenna-*new paint job*
grnbmr808 is offline   Reply With Quote
Old 03-06-2008, 03:47 PM   #8
DrusC5s
-Dan
When I had this problem, my fuse wasn't blown. It was just the wiring leading up to the fuse. I could wiggle the wires, and the angel eyes would go in and out. I then taped down the wires so they wouldn't wiggle so much. I haven't had that problem since. Good luck!
-Dru
Old 03-06-2008, 05:30 PM   #9
dan1539__323CI
Great advice! Tryin' to remember what fuse it is...
Old 03-06-2008, 08:55 PM   #10
DrusC5s
I dunno if your angel eyes is wired differently. But my fuse was just hanging in that big open area in the back of the engine bay on the passenger side. That's where it makes a "Y" connection, where one wire goes to the ECU tap and the right headlight, one wire goes to the left headlight. They come together at the fuse and goes into my interior to tap into my interior lights. I think that's how it works...I'm not sure! Anyways, just check that fuse. If it's still intact, then wiggle those wires around where the fuse is. The angel eyes might be going on and off. Once you figure out what position the wires are in so that the angel eyes stay on, zip tie them together and tape them down.
I think I confused you more!
-Dru
Old 03-07-2008, 11:34 AM   #11
dan1539__323CI
This is why I belong to this forum!! Problem fixed. It was that area around the Y-split. I taped it down and voila! Thanks Nick and Dru!
Old 03-07-2008, 11:53 AM   #12
DrusC5s
You're welcome!
I wonder if the OP fixed his angel eyes problem?
-Dru
Old 03-07-2008, 02:46 PM   #13
dan1539__323CI
Haha that's funny you say that...the whole time I've been thinking the same thing. Maybe I'll PM him...
