Old 01-04-2008, 12:08 PM   #1
cabl3i
My Ride: 03 330i ZHP
Tail light out error on dash.
My dashboard is telling me both my tail lights are out.
I currently only have LED's on my sidemarkers (not front turn signals...side markers) and on the reverse light.
Now my driver side tail light does have a faulty contact, but even when I adjust it so that it lights up, my car still tells me that BOTH tail lights are out.
ALL of the bulbs are good...none of them are out, and the fuse for tail lights is fine as well.
Can anyone help me here?
Im also a bit worried since my LED tails will arrive in a few days and I wanna fix this before they get here.
cabl3i is offline   Reply With Quote
Old 01-04-2008, 12:38 PM   #2
KHOALTY, Inc.
My Ride: BMW
Send a message via AIM to KHOALTY, Inc.
Its the wiring to your taillights. It is a common problem with sedans that the wires get all shorted out. Check the wiring where it connects to the taillights, I bet the wires there are all messed up, not due to you but its a flaw in the system. I see alot of this happen at the dealer.
Did you check the bulbs in the taillights to make sure they all work also?
KHOALTY, Inc. is offline   Reply With Quote
Old 01-04-2008, 12:51 PM   #3
junrboy
My Ride: 2000 323 ci
have you checked your lights above your license plate, they'll throw a light out error as well
junrboy is offline   Reply With Quote
Old 01-04-2008, 02:09 PM   #4
cabl3i
Thats it then...I took out one of the bulbs to see what fitment it is so I can replace it w/an LED...havent put it back in...gonna try that out when I get home.
And yea all of the bulbs in the tail lights are working.
As if things couldnt get any worse...I was checking the bulb on my front left corner light and when I put it back in....it went out...like the bulb works, but it doesnt make a good contact..I have to take the corner out, wiggle the bulb and then it starts working.
Yes I tried switching it for a new bulb...no difference...keeps messing up after I fix it.
Old 01-05-2008, 05:23 PM   #5
cabl3i
Fixed it, it wasnt the license plate light.
Well sort of, I put the license plate light back in and then when I was able to make the connector make a good contact on the tail light's socket, the light out indicator on the dash would finally turn off.
I looked at the pins in the tial light socket and noticed that one of them was...burned off? Dunno it looked brownish and was missing half way...sooo I jimmy rigged it.
I just inserted a small rectangle of metal into the corresponding pin hole so aid it in contact when i put the connector in the socket...problem solved (at least till I get my new tails).
Old 01-09-2008, 11:31 PM   #6
cabl3i
so I got my festoon dome lights for my license plate lights today...I install them and they tripped the tail light out warnings...both of them! I took one out so it was 1 led bulb and 1 halogen bulb...and the warning turned off...but if I put both led's in it trips it..!? (got em at autolumination and yes they are the correct size/fitment)
also I noticed that my sidemarker LED's from jlevisw blink every 45 secs or so when the ignition key is turned, or also when the car is on.
any help with either of these issues?
Old 01-09-2008, 11:33 PM   #7
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
That is really odd for your license plate lights to trip a bulb out warning. What are the specs on the bulb?
For the sidemarkers, that is normal, that is the car's electrical system sending a pulse every 30 seconds to check if the bulb is present. This briefly illuminates the sidemarkers every 30 seconds or so on some models.
Old 01-09-2008, 11:45 PM   #8
cabl3i
yea the blinking on the side markers doesnt bother me....the licence plate light does though...i want them to work
the size of the halogen bulb is 39 mm so i ordered 39 mm festoon dome lights I think the fitment is 6418 I think.
Old 01-04-2009, 10:31 PM   #9
alumniu
My Ride: 2002 BMW 330i
led bulbs use less power, therefore your car doesnt recognize that a bulb is even present. You my need a load resistor so it will recognize the bulb.
alumniu is offline   Reply With Quote
Old 01-04-2009, 11:20 PM   #10
eosco
My Ride: 325
You should do a more permanent fix for that tail light problem. I had this problem like 2 months ago.
Heres a link for a DIY, it's very simple to do. Start at post #5
http://forum.e46fanatics.com/showthr...=taillight+fix
Jet Black 2003 325i
eosco is offline   Reply With Quote
