Old 02-10-2008, 09:54 PM   #1
Tom///
My Ride: 95 M3 RIP, tpz 330ci
Led;s with Resistors = BAD IDEA
So I was installing the LED eagle eye deals with a 6ohm reistor turned on the right blinker felt it, I was like hmmm no heat, so I leave it that way for 5-10 next thing I know I go to touch it and it pratically burns me. So I coudn't imagine this being a good thing unless engineering by BMW or having a skilled mechanic strategically place the resistors somewhere.
I think the answer is somewhere in the LCM there has to be a wire that is doing the checking of lights to see if they are working.
We need to find that wire and cut the bastard.
Tom
Tom/// is offline   Reply With Quote
Old 02-10-2008, 10:03 PM   #2
Alex323Ci
My Ride: M3 & 323Ci (sold)
Tom
i think the answer is to buy OEM.
even if you cut the check wire, it would still cause the problem since the check sends a pulse of power and the resistance is read as it completes the circuit. low or no resistence causes the fault code.
Old 02-10-2008, 10:07 PM   #3
BartenderPlease
My Ride: '03 540i/6 M-Sport
They are supposed to get hot as hell. Around 200* F to be exact. You should have around a 15" cord so that you can place them somewhere that it can somewhat breathe.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 02-10-2008, 10:17 PM   #4
T330
My Ride: X5
Send a message via AIM to T330
T330 is offline   Reply With Quote
Old 02-11-2008, 08:44 PM   #5
stef80
My Ride: Peugeot 206
Why 6 Ohm resistor???
I think you should be fine with a 47 Ohm power resistor and it wouldn't be that hot either.
stef80 is offline   Reply With Quote
Old 02-12-2008, 12:31 AM   #6
Tom///
That's a good point would that work?
Tom
Old 02-12-2008, 12:31 AM   #7
Tom///
Tom
Old 02-12-2008, 02:19 AM   #8
paraklas
My Ride: ESS TS2 320ci
I used 50W 33Ohm power resistors with heatsinks for the leds bolted on an aluminum heatsink. Didn't get hot at all.
OP there's not a specific wire that checks for the bulbs. A 3v pulse is sent through the wires which are used to light the bulbs.
Three ways possible to get around the LED issue
Use power resistors (LOTs of DIY here)
Reprogram your LCM (if your car is made after 09/2001)
Get a NEW LCM (I stress the word NEW)
Old 02-12-2008, 08:41 AM   #9
stef80
The 33 Ohm that paraklas uses is the most guaranteed solution for the bulb out error but I think it is possible you can get away with 47 Ohm or even more in order to avoid the extra heat as the heat produced is conversely proportional(I hope this is how it is called in english) to the resistance.
Old 02-12-2008, 09:03 AM   #10
SammyV
My Ride: CB M3
Send a message via AIM to SammyV
you can disable the rear tail light bulb check in your LCM if you get your hands on some of the BMW lab tools...
SammyV is offline   Reply With Quote
Old 02-12-2008, 09:17 AM   #11
paraklas
I don't recall such option in the coding menu for the E46, since bulb check is a safety feature. Even if you disabled the check, you would still get fast blinking and flickering.
Old 02-12-2008, 09:23 AM   #12
dubplaya
My Ride: a car
Send a message via AIM to dubplaya
correct resistors do wonders
dubplaya is offline   Reply With Quote
Old 02-12-2008, 09:18 PM   #13
mpowered95
My Ride: 02 M3
those resistors are self insulated, they wont melt or burn anything.
mpowered95 is offline   Reply With Quote
Old 02-13-2008, 01:48 AM   #14
Tom///
Then why the hell did my fingers almost get burnt once I dropped them?
Tom
Old 02-13-2008, 01:58 AM   #15
mpowered95
My Ride: 02 M3
Tom
there is a big difference between your skin and some carpet. youll be fine bro
Old 02-13-2008, 02:22 AM   #16
Tom///
You sure about that I mean that $hit got HOT!!
Tom
Old 02-13-2008, 11:34 AM   #17
mpowered95
My Ride: 02 M3
Tom
yup, just mount them and they will be fine. i have the same one in my car, but i dont touch the resistors, haha jk
Old 02-13-2008, 11:41 AM   #18
leftcoastm3
My Ride: 2002 M3
Im just a n00b when it comes to DIY'n on my E46 but I thought the LED Eagle Eye tails were p'n'p and all that good stuff.
leftcoastm3 is offline   Reply With Quote
Old 02-13-2008, 12:09 PM   #19
E46_Project
My Ride: '02 325Ci
thats what I thought and am hoping for
Tom
Did you buy these from one of the group buys???
E46_Project is offline   Reply With Quote
Old 02-13-2008, 03:48 PM   #20
sillieidiot
My Ride: '06 AW 330ci
Tom
lol when i first read it, i thought that you meant using LEDs (not LED tails) with resistors is bad.
