Old 02-12-2008, 04:21 PM   #1
zerogravityE46
My Ride: 2002 BMW 325CI
which HID replacement bulbs?
which HID replacement bulbs should i get for my 2002 325ci 2dr? though one is getting yellowish and the other is super white! hope its not the ballast needs replacement.
are these bulbs good, should i go with 6k? with yellow foglights.
http://cgi.ebay.com/ebaymotors/ws/eB...187351618&rd=1
zerogravityE46 is offline   Reply With Quote
Old 02-12-2008, 05:33 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Make sure it's bulbs you need first. Try swapping the bulbs from one side to the other to see if the problem switches sides. We carry D2S Replacement Bulbs for your car in either 6000k or 8000k. These will ugprade the color temperature to a more pure white light output or aqua color for the 8000k.
Old 02-12-2008, 06:24 PM   #3
dinan Bimmer
My Ride: Turbo 350Z
Send a message via AIM to dinan Bimmer
I have the 8000k from you guys and the have very good light output, i would recommend them. My 8000k seems to be purple.
1997 VW Jetta TDi 16v ABAt
1997 BMW M3 S366
E90 335i 6mt DD
2000 323i Sold
2004.5 350Z APS ST 475whp 505wtq Sold
dinan Bimmer is offline   Reply With Quote
Old 02-13-2008, 04:55 AM   #4
zerogravityE46
how about Halos from JleviSW, all my halos are out, do i need replacements or new ballast or all new kit?
Old 02-13-2008, 08:38 AM   #5
bombguy
bombguy's Avatar
My Ride: 2004 M3
To the OP, I ordered the 6k from Jlevi and they are great. They have a slight purplish hue to them and honestly, if you go with 8k, your light output will be degraded. I recommend the 6k if anything.
2004 JB
KWv2, Spacers 15/F-10/R, MVR Rep, Alpine IDA-X305 w/ KCE-BT400 Bluetooth,
Agency Power Exhaust, Khoalty AE's
bombguy is offline   Reply With Quote
Old 02-13-2008, 08:56 AM   #6
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Could be several issues. Check the fuse and ECU taps first to make sure your connections are solid.
Old 02-13-2008, 01:54 PM   #7
dinan Bimmer
My Ride: Turbo 350Z
same thing happened to me last week. couldn't fix the issue. Nick from Jlevi even sent me a new relay and that didn't help. I just tapped them to my foglights, and now they work.
1997 BMW M3 S366
E90 335i 6mt DD
2000 323i Sold
Old 02-13-2008, 04:41 PM   #8
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
If they work with a different power source, then there was an issue with your ECU tap. Glad you got them working though.
Old 02-13-2008, 05:48 PM   #9
zerogravityE46
yea my setup is thru the foglights with a relay! relay is good, connection 12v source is good, though no source of power coming from the halos! i used a light tester!
Old 02-13-2008, 05:49 PM   #10
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
just don't get bulbs from visionbulbs
they suck and their bulbs suck
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 02-13-2008, 05:52 PM   #11
zerogravityE46
okay, and yea 6k is the way i am going with.
JleviSW, does your LED license plate stay fairly lit when installed and turns off in a few minutes when the car is off or armed?
