Old 02-13-2008, 06:55 PM   #1
ihs 328i
My Ride: 2000 328i
for the love of * how do you get LED corners in
just got mine from JleviSW and i have the installation instructions and everything and they don't even get close to going in. I bent out the housing and the fit was not snug even the slightest bit. I can't get them to twist either, pressing as hard as i can? Any help?
ihs 328i is offline   Reply With Quote
Old 02-13-2008, 06:59 PM   #2
SurreyF1
My Ride: BMW
try harder
SurreyF1 is online now   Reply With Quote
Old 02-14-2008, 07:10 AM   #3
Breyton-BMW
Breyton-BMW's Avatar
My Ride: Ti
Send a message via AIM to Breyton-BMW Send a message via Yahoo to Breyton-BMW
put some more muscle into it. are you sure they are the right ones?
Breyton-BMW is offline   Reply With Quote
Old 02-14-2008, 07:12 AM   #4
tblue3cibm
My Ride: allroad / Hayabusa
i think you have to dremel / file down one of the prongs.
tblue3cibm is offline   Reply With Quote
Old 02-14-2008, 01:49 PM   #5
Deah7
My Ride: 330i
You dont have to if you got the right kind. If you didnt get the right kind just file down one of the prongs and then put it in and it will be fine. If you got the right ones then just push down harder then turn. It shouldnt be hard.
Deah7 is offline   Reply With Quote
Old 02-14-2008, 03:54 PM   #6
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
It's not a prong issue, the newer bulbs have a larger base because of the 8 additional LEDs. You need to bend the housing out a bit to accommodate the larger bulb. It requires a bit of force and is a very tight fit but you can do it. When putting the socket back into the housing, the socket will be a bit larger than the housing hole so line up the tabs and press the two together.
Old 02-15-2008, 02:58 AM   #7
TeKNiC3
TeKNiC3's Avatar
My Ride: 330i.M3.aBox.996TT
Send a message via AIM to TeKNiC3
/\ Sounds like something will break with all that force
TeKNiC3 is offline   Reply With Quote
Old 02-15-2008, 10:33 AM   #8
Sam 330ci
My Ride: 3 Pedals - 3 Litres
Send a message via AIM to Sam 330ci
everything "snaps right in" or is "plug and play" until it actually arrives.
Sam 330ci is offline   Reply With Quote
Old 02-15-2008, 05:59 PM   #9
NorCal Einstein
My Ride: E92 335i
Send a message via AIM to NorCal Einstein Send a message via Yahoo to NorCal Einstein
Very nice...
Current:
2009 E92 335i Alpine White/Coral Red
Past:
2007 E92 335i Sparkling Graphite/Black
2000 E46 323i Steel Blue/Grey
NorCal Einstein is offline   Reply With Quote
