Old 02-15-2008, 10:03 PM   #1
awei130
My Ride: E46 323ci / E92 335i
Xenon Headlight Question
I purchased a set of Xenon's off a forum member and was under the impression that it was for a 99-01 coupe model. However when i proceeded to install them the Xenon headlight assembly did not fit correctly at first as they were actually for an 02+ coupe model with the screw in corners. I was wondering if anyone else has retrofitted an 02 Xenon headlight into an 99-01 coupe. And if retrofitted would i just be able to purchase the screw in corners and have everything fit correctly?
awei130 is offline   Reply With Quote
Old 02-15-2008, 11:44 PM   #2
grnbmr808
My Ride: green 4 da money 323
im pretty sure you would need new front fenders. check out this for what you need to do, its very custom and expensive.
http://e46.mit.edu/
he fitted facelift coupe xenon headlight on a prefacelift sedan.
the problem is that the gap for the turn signal (corner) isnt wide enough to accept the facelift corner/facelift headlamp assembly.
5% tint-cf emblems-blackout grill-smoked front corners and side markers-smoked led tails-alpine iva-d105 dvd deck-7 inch headrest screens-alpine mids/highs-15" kicker L7 sub-3000 watt sub amp-600 watt 4 channel amp-3 farad cap-removed 3rd brake light-debadged-xenon bulbs in exterior-xenon interior coversion-green fogs-replaced all trims/cowl-shaved antenna-*new paint job*
grnbmr808 is offline   Reply With Quote
Old 02-16-2008, 12:05 AM   #3
awei130
Wow that is one extensive project. Yeah i believe he had to get custom front fenders because he was putting on headlights from a coupe to a sedan. I'm going to try and get the screw in type corners on those headlights and see if they fit correctly. I'll take some pictures when i get the chance and post them on here. If anyone has done or know someone has done this as well please post here or PM me !
Old 02-16-2008, 04:55 PM   #4
grnbmr808
the facelift coupe headlight assembly and coupe turn signal still wont fit, even if it is a pre-facelift coupe, not a sedan. its just to wide.
Old 02-16-2008, 05:31 PM   #5
sbocaj55
My Ride: 330
Send a message via AIM to sbocaj55
If you still have your stock headlights you can do this http://forum.e46fanatics.com/showthr...logen+housings
sbocaj55 is offline   Reply With Quote
Old 02-16-2008, 10:55 PM   #6
sillieidiot
My Ride: '06 AW 330ci
02+ coupe headlight is the same as your car with the exception of the screw in corners. you can get screw in corners with one of our sponsors here.
Old 02-17-2008, 12:23 AM   #7
awei130
So i can just purchase the screw in corners and they should fit perfectly? I searched around the forums and saw that many people retrofitted their Bi-Xenon assemblies ie. to my stock halogen headlights. I guess that would be my last choice as i dont have experience in doing it.
Old 02-17-2008, 12:27 AM   #8
sillieidiot
yea, make sure you contact jlevi or the sponsor before making the purchase to make sure you got the right ones.
Old 02-18-2008, 02:27 AM   #9
awei130
i tried using a friends screw in corners from a 02 coupe and they did not fit correctly. I guess the only choice i have is to either retrofit them into my halogen housings or purchase P46s or something.
Old 02-18-2008, 02:56 AM   #10
sillieidiot
are you sure you have an 02+ coupe headlight then? take a picture. we'll be able to identify the headlight for you.
also, you might want to try using your halogen headlights outer lens and the headlight trim.
Old 02-18-2008, 06:14 AM   #11
awei130
yeah these headlights came off of a 02 m3 ... i don't know why im having so much trouble getting it to fit correctly =/
Old 02-18-2008, 01:30 PM   #12
sillieidiot
i just got your pm. if you could bring 1 corner from your friend's 02 and your headlight, maybe we could find a solution.
Old 02-18-2008, 06:42 PM   #13
awei130
i could do that if your willing to help out. i'll pm you my number
