Thread Tools Search this Thread Rating: Thread Rating: 74 votes, 4.78 average. Display Modes
Old 01-12-2003, 11:28 PM   #1
KevinJ_2k1_325ci
My Ride: 2001 325ci
Post Electronic Throttle Adaptation reset procedures
According to BMW's documentation, to reset the throttle adaptation you do the following:
With the car off, turn the ignition to the on position for 10 seconds(do not start) then turn the ignition off for 10 seconds. Then start the car. You should notice slightly improved performance if you normally drive miss daisy.
I have also been told that disconnecting the battery ground for 20 seconds will reset the short term ECU memory but I can't validate that with BMW doco. These steps are necessary if testing or installing new modifications to be able to determine true performance.
KevinJ_2k1_325ci is offline   Reply With Quote
Old 01-12-2003, 11:34 PM   #2
Nick325xiT 5spd
BMW Land Barge
My Ride: '04 M3 & '99 323i
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd
Hmm...
It would be awfully nice if I didn't have to unplug the battery every time I put gas in.
Nick325xiT 5spd is offline   Reply With Quote
Old 01-13-2003, 04:16 AM   #3
Banker
Whassup?
Banker's Avatar
My Ride: 325i
Send a message via ICQ to Banker Send a message via AIM to Banker
Thumbs Up Thanks for the tip!
Hey Kevin...thanks for the info. I've been thinking that my throttle response deterioriated somewhat after installing my GruppeM and UUC TSExhaust. So I though I'd give both of you're suggestions a try this afternoon. All I can say is...WOW! I didn't really believe it would make such a difference!!! Throttle response is definitely better now!
Keep feeding us these great tips and suggestions
BBS-RGR's / KW V2 Coils / UUC Sways / GruppeM Intake / Sharked / SMG M3 Wheel / DAE v5 / ACS Roof Spoiler / M3 Lip Spoiler / Body Color Molding / OEM Euro Clears /
Banker is offline   Reply With Quote
Old 01-13-2003, 07:00 AM   #4
dennisf
My Ride: BMW 330Cic
Great tip!! I'm gonna try that one
dennisf is offline   Reply With Quote
Old 01-13-2003, 08:18 AM   #5
KevinJ_2k1_325ci
My Ride: 2001 325ci
Re: Thanks for the tip!
At first I thought the adaptation reset didn't do anything until I got out on the highway this morning. Yeah it worked. I could see and feel spikes in the RPM band. Mostly in the mid and high RPM's. I'm sure the lower RPM's are improved but harder to tell.
Old 01-14-2003, 08:16 AM   #6
KevinJ_2k1_325ci
My Ride: 2001 325ci
It might be the cooler temps but I spiked at 6500 RPM this morning
I was shocked, I spiked my redline at 6500 which is the engine max! My car was pulling hard in sport mode on my steptronic akin to when I had my mass air sensor screens off (very close except not as much low end). I tried regular automatic mode and it was fast as hell yesterday unlike it's normal sluggishness. Definitely adaptation reset works and my car is performing better throughout the RPM band. Mostly in the mid and upper RPM.s. I wonder if Dinan is just turning off adaptation or just toning it down? That would suck it that's all their chip does.
Old 01-14-2003, 08:38 AM   #7
vids_blk323Ci
DFW
My Ride: JB 323Ci SP PP
Send a message via AIM to vids_blk323Ci
good tip! need to go and try this!
Dinan Stage I S/W | ACS RSB | ///M FSB |UUC TMEs & Pulleys |Ate Slotted Discs | ScanGuageII | RockyMounts MTB Carrrier | OEM Rear Clears | LED Euro City Lights & Rear Fogs | Two-Tone Suede DIY | ACS Pedals | Bimmian Gauge Rings & M3 Face | Smoked Frnt Corners w/ Luxeon LEDs | EAS CF Roundels | JLevi Ti CF trim | Blk Suede shift/ e-brake boots | ECS Smoked Frnt Bumper Reflectors | DICE Duo
vids_blk323Ci is offline   Reply With Quote
Old 01-14-2003, 08:43 AM   #8
ari00
My Ride: 04 330ci
guys will this have the same effect if i already have the dinan software?
ari00 is offline   Reply With Quote
Old 01-14-2003, 08:56 AM   #9
agriebel
Evil McGriebel
My Ride: 1999 BMW 328i
Sounds great, I'll give it a try!
agriebel is offline   Reply With Quote
Old 01-14-2003, 09:12 AM   #10
KevinJ_2k1_325ci
My Ride: 2001 325ci
I would hope so!
I would imagine that they are adjusting the fuel/air ratio and spark advance maps. I would imagine that the throttle adaptation still exists.
Old 01-14-2003, 09:41 AM   #11
Atlas
My Ride: 320i
Send a message via ICQ to Atlas
But i imagine that when you floor it it still goes the same
Atlas is offline   Reply With Quote
Old 01-14-2003, 09:56 AM   #12
Salvator
My Ride: 2001 325 Ci
I'm sorry, but I came in late into this discussion... If I am interpreting correctly what I am reading, are you saying that the onboard computer is adjusting the throttle response based on how we drive? And thus, if you want better throttle response, perform the 10 second thing as stated above, this will reset the throttle response, and if you then drive with a heavy foot from that point forward, the car will react to this and provide better response? Just wondering, because if that's true, I'm going out to my car right now!
Salvator is offline   Reply With Quote
Old 01-14-2003, 10:53 AM   #13
dennisf
My Ride: BMW 330Cic
I also did the 10 second thing and I also noticed some difference.. If the car really got faster??? Maybe.. It feels quicker and it reacts more aggresive to the gas.. the butdyno thinks its faster anyway and that's what counts..
Thanks for this great tip..
One problem though... I do the 10 second thing now almost every morning before I start the car because I want the car to be fast always!!!
Old 01-14-2003, 10:57 AM   #14
jason330i
moderation in all things
My Ride: 2002 330i
Re: Electronic Throttle Adaptation reset procedures
i've gotta try this!!!
but when you say "turn the ignition off" what position is that? completely off?
you sir, are a
jason330i is offline   Reply With Quote
Old 01-14-2003, 11:32 AM   #15
.Gravedgr.
Got M?
My Ride: '02 CBM M3
Send a message via AIM to .Gravedgr.
Excellent info! I can't wait to give it a try. I spend a lot of time cruising along the hwy. in traffic or just to/from work putzing around at about 2-4k RPM, so I'm sure it's mapped my fuel intake for a soccer mom. I'll play with it next time I take the car out.
Past Present
.Gravedgr. is offline   Reply With Quote
Old 01-14-2003, 11:37 AM   #16
polorl57
My Ride: 325
yes that is true...its true for all obdII ecu....but just different ways to reset it for different cars...like for my old prelude...i had to take out the clock fuse from the fuse box and it would temporarily reset everything
polorl57 is offline   Reply With Quote
Old 01-14-2003, 11:41 AM   #17
spd
My Ride: 323i
Question Does it work in 5spd?
I think it only works in Steptronic, coz I do not think 5 spd has the electronic adaptive throttle contol. Could someone verify this. Thanks!
Old 01-14-2003, 11:59 AM   #18
Atlas
My Ride: 320i
It's just throttle response... and i imagine if u drive with a heavy foot it would adapt as such...no need to do it every morning lol...
Old 01-14-2003, 12:02 PM   #19
sullyz
frequent tire purchaser
My Ride: 01 M3, 02 M3, 08 M3
Re: Does it work in 5spd?
I'll verify it. I tried it before I left work yesterday and then mildly drove home, but when I left again later and started mashin' I absolutely noticed a difference.
Great Tip!!
sullyz is offline   Reply With Quote
Old 01-14-2003, 12:31 PM   #20
KevinJ_2k1_325ci
My Ride: 2001 325ci
Re: Re: Does it work in 5spd?
THis should work on all cars with electronic throttle control meaning some later 323 and 328's as well as all 325 and 330's.
I believe 323/328's that were built 10/00-12/00 will have electronic throttle control or what is called "throttle by wire". It is with this new electronic throttle that these 323/328's got the new mototronics that this will work with.
For the old models meaning prior to 10/00, I've been told that you can try turning your ingnition to the on position (not started) and press the gas peddle all the way to the floor 4 times, then you will hear a beep or something and that tells you it worked.
Great Tip!!
