Thread Tools Search this Thread Rating: Thread Rating: 74 votes, 4.78 average. Display Modes
Old 03-29-2003, 11:08 PM   #81
toddv
My Ride: .
WOW - Great Post
Actually, I did this by accident a few weeks ago, after working on the car. When returning home, I couldn't believe the response. Now I know what did it I already have the Dinan stage 3 kit, but driving Ms Daisy does seem to slow things down after a while. Great knowing I can kick this in when needed!
toddv is offline   Reply With Quote
Old 03-29-2003, 11:22 PM   #82
KevinJ_2k1_325ci
My Ride: 2001 325ci
Read post above.
I've asked Jim Conforti about this at one time. I assumed that the chip tuners updated the static tables as well as set lower threshold ranges. So basically when the car adapts with a tuned ECU it has a smaller - or + range. Jim Conforti seem to skirt around the question when I asked. But a few knowledgable people have confirmed my thoughts. So no as the post above indicates, it will not mess up the Dinan.
Originally posted by Paul330ci
How does this affect the Dinan S2 download. Will this reset mess it up.
KevinJ_2k1_325ci is offline   Reply With Quote
Old 10-20-2003, 09:47 AM   #83
bobm3
Senior Eurowerkz Member
bobm3's Avatar
My Ride: 2003m3smg
thats alot for the information
will try it tonight when i get out of work . can't wait...
bobm3
bobm3 is offline   Reply With Quote
Old 10-20-2003, 12:13 PM   #84
bobble
My Ride: 323Ci
Re: Re: Re: Does it work in 5spd?
Originally posted by KevinJ_2k1_325ci
THis should work on all cars with electronic throttle control meaning some later 323 and 328's as well as all 325 and 330's.
I believe 323/328's that were built 10/00-12/00 will have electronic throttle control or what is called "throttle by wire". It is with this new electronic throttle that these 323/328's got the new mototronics that this will work with.
For the old models meaning prior to 10/00, I've been told that you can try turning your ingnition to the on position (not started) and press the gas peddle all the way to the floor 4 times, then you will hear a beep or something and that tells you it worked.
Kevin,
I could be wrong but I thought they stopped producing 323's in @ august of 2000 and no 323's were DBW? Any thought to that. also hows the 330 intake tube project going, did it work?
bobble is offline   Reply With Quote
Old 10-20-2003, 12:13 PM   #85
vids_blk323Ci
DFW
My Ride: JB 323Ci SP PP
Send a message via AIM to vids_blk323Ci
wow bringin it back from the dead!
Dinan Stage I S/W | ACS RSB | ///M FSB |UUC TMEs & Pulleys |Ate Slotted Discs | ScanGuageII | RockyMounts MTB Carrrier | OEM Rear Clears | LED Euro City Lights & Rear Fogs | Two-Tone Suede DIY | ACS Pedals | Bimmian Gauge Rings & M3 Face | Smoked Frnt Corners w/ Luxeon LEDs | EAS CF Roundels | JLevi Ti CF trim | Blk Suede shift/ e-brake boots | ECS Smoked Frnt Bumper Reflectors | DICE Duo
vids_blk323Ci is offline   Reply With Quote
Old 10-20-2003, 05:19 PM   #86
KevinJ_2k1_325ci
My Ride: 2001 325ci
Re: Re: Re: Re: Does it work in 5spd?
The 323/328 with mechanical throttle according to documentation ended production 10/2000 and electronic throttle began. There have been a few people with electronic throttles with a 323/328 on this board that I've come across.
Actually I installed the 330 tube. Someone else did on this board to and posted pics of theirs. They did exactly the same as I did mine and noticed exactly the same things. There is a slight performance difference (very slight) and the intake sound is difference. Slightly deeper but not resonating. The performance change seemed to be in the 3k and 5k ranges. I certainly won't be dynoing for 1-2HP
Originally posted by bobble
Kevin,
Old 10-28-2003, 05:39 PM   #87
CartelDave
My Ride: 2002 M3
Has anyone tried it on the M3 yet?
CartelDave is offline   Reply With Quote
Old 10-28-2003, 08:51 PM   #88
mpowerbmw2002
My Ride: 2002 330i
Send a message via AIM to mpowerbmw2002
Hey guys I really dont think it is in my head just went out for a ride (02 330i) and I think this works. I nailed out of my driveway and at about 4,000 RPM the car just seemed to have so much more pull than before. Also in 2nd gear. I drive 10 miles to work and dont drive agressivly there so I can see how the responce would fade. Try this boys.
mpowerbmw2002 is offline   Reply With Quote
Old 10-29-2003, 01:10 PM   #89
bobm3
bobm3's Avatar
My Ride: 2003m3smg
i tried it on my 2003m3 it works but
you have to drive aggresive (fast) you will see a difference some what. with me turning on a corner of a street when i turn it is usually at 20mph and my m3 slows down.but after a reset the program it did not do it as much by it self.it wasn't so noticable.
i guess the more aggresive you drive the better the car will respond. but if you hit traffic it blows the adjustment you make already. that is the only thing you have to watch for.
bobm3
Old 11-11-2003, 07:35 PM   #90
Commander FAT
Network Analyst
My Ride: 2002 330Ci
So when we put the key to the Off position do you mean the positin in which the key is first inserted or the first click of turning the key?
dave
Because the B isn't for bling.
Commander FAT is offline   Reply With Quote
Old 11-11-2003, 08:21 PM   #91
cncmastr
Carbon Fiber Airbox
My Ride: E30 / E46 / E53
Send a message via AIM to cncmastr Send a message via MSN to cncmastr
i think so
2006 BMW ///M3 | ZCP | Xenon | Nav | Premium | M Texture Alcantara
cncmastr is offline   Reply With Quote
Old 11-11-2003, 08:37 PM   #92
mpowerbmw2002
My Ride: 2002 330i
You have to go to the 2nd click of the key just before the start position.
Old 11-11-2003, 08:52 PM   #93
sheefo2k
sheefo2k's Avatar
My Ride: vrm psh - 02 325ci
i think i put it in position 2 the postion 1 (off)
and i felt a difference in the respoce. no more second delay till the rpm shoots up
Performance BMW car
Sponsored by :
www.euro-spec.net
www.bimmian.com
BMW Motorwerks
support:
www.vmwerks.com
www.esstuning.com
www.my330i.com
sheefo2k is offline   Reply With Quote
Old 11-12-2003, 12:45 AM   #94
Artan5
life is a *****..........
Artan5's Avatar
My Ride: 330ci :) RIP323i
Send a message via AIM to Artan5
How do i do it for my 99 323i?
Artan5 is offline   Reply With Quote
Old 11-12-2003, 01:37 AM   #95
Trax
My Ride: 99' 323i Sedan
Send a message via ICQ to Trax Send a message via AIM to Trax Send a message via Yahoo to Trax
I just did it for my 99 323i and I deffinately noticed an improvement/change! It made it a lot more responsive but then again it could be in my head?
This sig has been viewed by fanatics since March 14, 2004
Trax is offline   Reply With Quote
Old 12-15-2003, 09:01 AM   #96
zahoor
My Ride: 330i sport saloon
Excellent, a great tip! Just tried this out yesterday and I'm going much faster everywhere
Thanks!
Mod list to follow.
zahoor is offline   Reply With Quote
Old 12-15-2003, 12:09 PM   #97
mpressive6
My Ride: 330 ci
Originally posted by cncmastr
i think so
CNCMASTR,
I couldn't help but notice that you're from Toms River. I had a childhood friend from their by the name of Paul Mueller. Do you know him or his family. He has a younger brother but I can't remember his name right now. Sorry about the thread drift.
Leroy
mpressive6 is offline   Reply With Quote
Old 12-17-2003, 12:51 AM   #98
KevinJ_2k1_325ci
My Ride: 2001 325ci
This does work, this info is from BMW not me!
There is no gimmic or trick here folks, this is the OFFICIAL electronic adaptation reset procedures.
The deal is that yes if you did it correctly, you will notice the change. Otherwise there is not a light or signal or sound that throttle adaptation has been reset. Basically if you know your engines performance, you will notice the change in throttle response and engine performance. More pep in its step if you will. Under certain driving conditions yes I've noted that adaptation will change within a day or two and other times it has lasted more than a week before fading. For me I should be resetting everyday since my average MPG in stop and go traffic is 17!
In regard to 323's and 328's with mechanical throttles, this information simply does not apply since ahhhh...its mechanical and not electronically controlled.
Old 12-17-2003, 01:08 AM   #99
pwalsh53
My Ride: E46
Send a message via AIM to pwalsh53
Hmm. I knew my car had a throttle cable, but I thought there was an electronic component too, like right at the throttle body. I thought some of it was electronically activated.
So you're telling me my 99 328i is COMPLETELY mechanical throttle?
I read earlier in the post about pushing the pedal to the floor 4 times on my car to do this adaptation, what about that?
Patrick
pwalsh53 is offline   Reply With Quote
Old 12-17-2003, 02:58 AM   #100
DJ-SF
My Ride: 2004 E46 M3
let me see if i get thise straight
Essentially, your throttle response is adaptive and will conform to your particular driving style.
So, if you consistently drive in aggressive (spirited) fashion your car will have adapted to your driving style and have adjusted the throttle response time to react quicker and support the demands of your aggressive driving habits.
That being said, if I performed the throttle reset, which clears the temp memory....am I basically erasing all the knowledge my car had gained based on my driving habits and starting back at
time zero?
Should this memory clearing be performed for those you primarily use their car as their daily commuter and want to clear their cars memory of slow driving habits, which would gain back the quicker throttle response?
TIA.
2004 ///M3 MT-Silver Grey Metalic
DJ-SF is offline   Reply With Quote
