Old 02-16-2008, 09:28 PM   #1
jontran8
My Ride: 97 M3, 05 330ci
Send a message via AIM to jontran8
HID install problem
I just installed some hid's into my low beams. They lit up alright the first night. But now they don't work. On the gauge cluster, there is a car with headlight picture showing that they aren't working. I've searched and found something about pulling fuse 32. Is this what I need to do to make them work? What does fuse 32 do? Also is the fuse box screwed down by torx screws? TIA
jontran8 is offline   Reply With Quote
Old 02-16-2008, 10:32 PM   #2
gTkidrokin330
My Ride: Bemdub
......i didnt know you can run xenons in your low beams....i thought there wasnt enough power going ot it
gTkidrokin330 is offline   Reply With Quote
Old 02-16-2008, 10:33 PM   #3
jontran8
I'm new to the e46 so I'm not sure. Please don't tell me this since I just spent all this money on getting hid's.
Old 02-16-2008, 10:34 PM   #4
NorCal Einstein
My Ride: E92 335i
Send a message via AIM to NorCal Einstein Send a message via Yahoo to NorCal Einstein
You haven't heard of Projector 46's?
Current:
2009 E92 335i Alpine White/Coral Red
Past:
2007 E92 335i Sparkling Graphite/Black
2000 E46 323i Steel Blue/Grey
NorCal Einstein is offline   Reply With Quote
Old 02-16-2008, 10:37 PM   #5
NorCal Einstein
My Ride: E92 335i
So if the HID's do not light up at ALL anymore, you will need a supplementary power harness.
Pulling Fuse 32 will NOT help you. People pull Fuse 32 when their HID's work, but they are receiving a bulb out warning when their HID's are off.
Contact Khoa @ Khoalty via PM or AIM and let him know of your situation, and that I mentioned that you will possibly need a supplementary power harness.
Current:
Past:
Old 02-16-2008, 10:37 PM   #6
jontran8
I read something about them. Don't know much about them though. I have a 05 330ci, which I don't know if I need p46's.
Old 02-16-2008, 10:40 PM   #7
NorCal Einstein
My Ride: E92 335i
Did your car come with Xenon's from factory? Or did you install aftermarket lighting?
Current:
Past:
Old 02-16-2008, 10:43 PM   #8
jontran8
installed aftermarket hid kit
Old 02-16-2008, 10:44 PM   #9
sillieidiot
My Ride: '06 AW 330ci
judging from his my rides section, he has a facelifted coupe like mines. they already come with projectors even if he has halogens.
jon, what you need to do is get your car reflashed by the dealer so that they car can recognize the xenons. that should solved the problem. or you can use the capacitor mod or try resistors.
Old 02-16-2008, 10:44 PM   #10
NorCal Einstein
My Ride: E92 335i
Can you post the link of what you bought?
Current:
Past:
Old 02-16-2008, 10:48 PM   #11
jontran8
I've been a member on bf.c for awhile which is where I got it from.
http://forums.bimmerforums.com/forum...d.php?t=924391
Old 02-16-2008, 10:49 PM   #12
NorCal Einstein
My Ride: E92 335i
If his car won't even fire the xenons's anymore, its not that the car is not recognizing xenons, its that there is not enough power supplied. I don't believe a reflash will fix this.
I just finished an install for a local kid who had the same problem as described. His car would not fire the xenons. Turned out he has a car that requires ANOTHER harness to fire xenons. The harness basically just connects from the battery terminals in the engine bay, out to the headlights. After installing that, it did the trick and the xenons would light up properly. I believe his car still has bulb-out warnings, which he will need separate resistors for, OR get a reflash (resistors are the cheaper way out)
Current:
Past:
Old 02-16-2008, 10:49 PM   #13
jontran8
How much does the reflashed cost? Is there anyway that I can do it myself? What is the capacitor mod or resistor mod? What does pulling fuse 32 help with?
Old 02-16-2008, 10:52 PM   #14
NorCal Einstein
My Ride: E92 335i
A reflash will be in excess of $100.
In post #5, I told you what pulling Fuse 32 will do.
Resistor mod will only be useful to you AFTER the fact you get your lights to work.
Current:
Past:
Old 02-16-2008, 10:53 PM   #15
sillieidiot
can you do us a favor, put your key in and turn it to the position before you start the car (i think that's 2, i forgot). then turn on your headlights with the HID kit connected. does it turn on?
Old 02-16-2008, 10:54 PM   #16
sillieidiot
for facelifted coupes and a lot of the new bmws. when installing an HID kit, the lights will not come on because of the bulb out warnings. other symptoms include flickering on then off and others as you already know.
Old 02-16-2008, 10:54 PM   #17
jontran8
Thanks. When I go to the dealer, what do I say to them. "I want a reflash"? And this is after I get the harness?
Old 02-16-2008, 10:57 PM   #18
jontran8
The first night that I did it, I didn't turn on the car, just turned the key to 2nd and the lights worked every time. The next day after turning on the car, the lights don't work anymore. I turn the lights on (key in 2nd and key with car on) and the lights flicker then stay off.
Old 02-16-2008, 11:02 PM   #19
sillieidiot
ok, then we know for sure your car has enough power to turn on the xenons. you just need to get your car reflashed. might want to call your dealer first. a lot of dealers won't know what you're talking about so yea. tell them that you need you lsz (new name for lcm) reflashed to accept xenons. you may lose your high beams though.
Old 02-16-2008, 11:07 PM   #20
jontran8
Well thats not good if I lose my highbeams. I live in VA where I need to get state inspection done every year.
