Old 02-17-2008, 02:12 AM   #21
ewerc
My Ride: 2002 e46 325ci
get a hold of KHOA, I too live in an area where I needed my high beams and went through KHOA whose supplier is Apexcone. Apexcone makes a dual input/output harness (lowbeam plugs into harness, then routes power to a relay, then to the ballasts) to eliminate flickering/problems with the LCM not recognizing the HID's. You will still have the bulb out warning and can do the resistor mod or KHOA now has a plug n play resistor harness that is really clean for $50.
ewerc is offline   Reply With Quote
Old 02-18-2008, 12:44 PM   #22
sdbimmer
My Ride: 2004 325Ci
JonTran8, I had the same issue like yours when I first installed my aftermarket HIDs. When you turn your keys to the ON position without starting your engine, your lights should light up just fine. But when you start your engine and turn on your lights, it will flicker like crazy. To remedy this, you will need to install a capacitor. Install the capacitor to the power line before it goes into the Ballast. You can get the capacitor at Radio Shack. On the capacitor. notice the arrows. When you install it, the arrow lead should be pointing to your "negative" wire. The other end goes into your positive wire.
http://www.radioshack.com/product/in...entPage=search
OR
sdbimmer is offline   Reply With Quote
Old 02-19-2008, 03:36 PM   #23
jontran8
My Ride: 97 M3, 05 330ci
Send a message via AIM to jontran8
Ok, so my hid's work when the key is to the ON position without starting the car. When starting the car, the lights flicker and turn off. To fix this the capacitor method will fix this problem? Are there any good write-up's?
jontran8 is offline   Reply With Quote
Old 02-19-2008, 03:42 PM   #24
sillieidiot
My Ride: '06 AW 330ci
hey jon, i got the shipment. pm me
Old 02-19-2008, 03:44 PM   #25
sandman512
My Ride: 2005 325I
Don't know if this applies to you, but here you go. Hopefully it helps.
http://forum.e46fanatics.com/showthread.php?t=539292
If not, disregard....
sandman512 is offline   Reply With Quote
Old 02-19-2008, 03:45 PM   #26
sdbimmer
My Ride: 2004 325Ci
http://forum.e46fanatics.com/showthr...hack+capacitor
