Old 02-21-2008, 08:40 AM   #1
silverbullet325
My Ride: BMW 325i
Sometimes my Angel eyes won't turn off.
I have them spliced into the main acessory wire in the control box per the istructions. The problem is sometimes they turn off about 30 seconds after the car is stopped (walk away feature) and sometimes they do not turn off at all. I have never sat there for more than about a minute to see how long they actually stay on. I just turn the key over and turn it back and this resets the computer and then they go off after 30 seconds. I'm not sure if I left them they would turn off at all before draining my battery dead. Diagram of wire I tapped into below. Its the red and white stripped with yellow dots. Anyone else have this happen?
silverbullet325 is offline   Reply With Quote
Old 02-21-2008, 09:03 AM   #2
Polish_328Ci
My Ride: M3
Mine stay on for about 5-10 seconds or when the doors are open since I wired the remote feature. For some reason your accessory wire still has power for longer thaan that. Kinda weird.
Polish_328Ci is offline   Reply With Quote
Old 02-21-2008, 09:06 AM   #3
silverbullet325
My Ride: BMW 325i
Yeah and its not all the time. Most of the time it works as planned but sometimes it goofs up. I swear our cars are worse than women when it comes to mood swings.
Old 02-21-2008, 09:07 AM   #4
Polish_328Ci
My Ride: M3
Haha ohh I can believe that lol.
Old 02-21-2008, 10:36 AM   #5
ahhchu430
My Ride: 2003 325i
I noticed the same thing when I first got them. I eventually gave up and left it as is and have yet to have any battery issues (knock on wood). They do turn off eventually...It usually happens after a fairly long drive right??
ahhchu430 is offline   Reply With Quote
Old 02-21-2008, 10:37 AM   #6
Cruzader
My Ride: Alpinweiß facelift
Happens to me sometimes to, just give them a minute and they will shut off
Cruzader is offline   Reply With Quote
Old 02-21-2008, 10:37 AM   #7
silverbullet325
My Ride: BMW 325i
Haven't payed attention to the drive time but I will now. Do you just leave them on and walk away and they reset?
Old 02-21-2008, 10:44 AM   #8
StikiGreenZ
My Ride: 2002 BMW 330i
It happens to me, sometimes I've waited 3-4 minutes for them to go off. They ALWAYS do go off within 5 minutes.
2002 BMW 330i Premium | 1996 Chevrolet Cavalier
StikiGreenZ is offline   Reply With Quote
Old 02-21-2008, 10:46 AM   #9
BMWPower06
BMWPower06's Avatar
My Ride: ///M5 & ///M3
Send a message via AIM to BMWPower06
i have mine wired to the parking lights, soo much better
Current: E60 M5 6MT; E46 M3 6MT
Sold: E46 330CiA; E36 M3/2/5; E60 M5 SMG
DD: B8.5 Audi S4 6MT
BMWPower06 is offline   Reply With Quote
Old 02-21-2008, 02:04 PM   #10
Jeffxxx
My Ride: 02 SLOW lsb m3
Are you talking about the remote feature? Because that's not the wire you tap for that. They only stay on because there is still power running through the accessory wire.
Featured in the August 2009 issue of Performance BMW.
nwbmwclub.com
Jeffxxx is offline   Reply With Quote
Old 02-21-2008, 09:05 PM   #11
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
The wire you tapped is for the auxiliary fan if i'm not mistaken(which is hte correct wire to tap), so it will stay on for a while after the car is turned off. They will go off after a couple of minutes and they shouldn't drain your battery. you should be fine, nothing to worry about.
SL Blak Soldier is offline   Reply With Quote
Old 02-22-2008, 12:54 AM   #12
ahhchu430
My Ride: 2003 325i
I just walk away and it turns off whenever, no big deal. I tend to check it after driving a long distance so it's probably a coincidence.
Old 02-22-2008, 12:55 AM   #13
ahhchu430
My Ride: 2003 325i
Old 03-05-2008, 10:20 AM   #14
bmw_325i_ct
My Ride: 325i
My angels wouldn't turn off for more than a minute for first time today within 10 seconds of car being turned off. All I did was just turn my lights on and off without the key in the ignition and the angels turned off.
bmw_325i_ct is offline   Reply With Quote
Old 03-05-2008, 10:24 AM   #15
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
Yup, just sometimes your fan needs to stay on a bit longer. No problem.
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
Old 03-07-2008, 03:44 AM   #16
00Rayger00
My Ride: E46
Mine wouldnt turn off last night either....So I had to put the key in the ignition and turn my low beams off and on again. They turned off after doing this, but when I went to start my car today, they will not turn on.
Can anyone help me? I miss my angel eyes!!!
00Rayger00 is offline   Reply With Quote
Old 03-07-2008, 03:54 AM   #17
sillieidiot
My Ride: '06 AW 330ci
check your fuse or taps
Old 03-07-2008, 03:58 AM   #18
00Rayger00
My Ride: E46
thanks. Ill try that.
