Sponsored by The Tire Rack
Old 02-23-2008, 05:20 AM   #1
SBREM2
My Ride: 2000 328CI
E46 wheel offset non M
I have a 00' 328ci. I know a lot of non-M owners are going x10 in the rear...What offset do I need to achieve a wheel size of 19x10 in the rear? I the fender rolling is required and that ok.
SBREM2 is offline   Reply With Quote
Old 02-23-2008, 11:13 AM   #2
BartenderPlease
My Ride: '03 540i/6 M-Sport
You will probably need a +45 for your coupe. I've never seen offset numbers for a 10" on a non-M but that would be about right. And you are right about rolled fenders. You could run a 245 for sure, maybe a 255.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 02-23-2008, 12:33 PM   #3
slvrr
My Ride: misses me
A +44 et would be better harder to find but still. I wouldn't go any higher than a +45 for sure other wise you run into the problem I'm having hitting the brake caliper or in your case witth a 10" rim hitting the rear shocks. You can always get a +40 et and have them machine the offset for you to like a 42-43.Its usually around $30 nit to bad
slvrr is offline   Reply With Quote
Old 03-11-2008, 12:20 AM   #4
BokCh0y
My Ride: JCE10; E46 CAB
So without having to roll the fenders, what's the max tire and rim size i can go with a non M 3 series?
Current have stock 17" Style 44's - 225/45/17. Can someone list some sizes up to 19" and maybe a good staggered setup size as well please.
What's the offset I can go with int he front and rears for 18's and 19's?
Thanks.
BokCh0y is offline   Reply With Quote
Old 04-21-2009, 10:06 PM   #5
Mohammad_a90
My Ride: Ontario
hey i have almost same problem i got a 2000 328i and i am wondering if i can fit a Front tires: 235/45/17 Rear tires: 255/40/17
Mohammad_a90 is offline   Reply With Quote
Old 04-21-2009, 11:24 PM   #6
BokCh0y
I heard 255 is the fattest you should/can go on a non M E46.
Running 18's now. The fronts are 235/40/18. Rears are 255/35/18. Fronts...yeah i have to double check, pretty sure they are 235 but i'm asian and my eyes are small.......
Old 09-27-2010, 12:12 AM   #7
jamesgillon
My Ride: e46 328ci
Send a message via AIM to jamesgillon
i am running 275/30/19s (9.5 wide) in the rear with 37 off set(not 100 percent though) and not rubbing fronts are 245/35/19 (8.5)
jamesgillon is offline   Reply With Quote
Old 09-27-2010, 04:41 PM   #8
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
That is on the OE Sport wheels that are 8.5" wide. With an aftermarket setup you can go with a 10" wide wheel but modifications will need to be done to the fender and you will have to run a slightly stretched tire.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-02-2012, 03:51 PM   #9
bwarren91
My Ride: 02 325CI
i am having the same problem too. i have a 02 325ci coupe and i wanna run some aggressive 18s but idk what specs are good without rolling fenders. any help would be much appreciated
bwarren91 is offline   Reply With Quote
