Thread Tools Search this Thread Rating: Thread Rating: 39 votes, 4.90 average. Display Modes
Old 02-23-2008, 02:04 PM   #1
Yober
My Ride: 2000 BMW 323i, 2000
Question reset the oil service light
I have a 2000 323i with the 20 pin connector. I don't have the service lights, I have a numerical "miles countdown" for the indicator. I have tried resetting it with the jumper in first, then turning the key and by turning the key and then inserting the jumper with no luck. The connector is numbered so I know I am using connections 7 and 19.
I have read and made many attempts to reset the oil service light per the directions given on BMW DIY website. Has anyone else ever had a problem with the oil service indicator NOT reseting?
Yober is offline   Reply With Quote
Old 02-23-2008, 02:08 PM   #2
Dan99
My Ride: 2001 330xi
For your car, I think you need a reset coder which cost like 100 bucks at bimmertools.com or you can also get one at bavauto.com.
Dan99 is offline   Reply With Quote
Old 02-23-2008, 06:06 PM   #3
slvr323i
My Ride: 2000 323i
Send a message via Yahoo to slvr323i
I have a 2000 323i and I am able to reset the oil service light by using the left knob on the dash. With the car off, hold down the left knob until it starts to flash, while holding the knob turn the key to position 1, keep holding the knob.
Play with it a few times, it took me a couple of times to get it just right. Look on the forum, there is a link that tells you exactly what and how to do it.
slvr323i is offline   Reply With Quote
Old 02-23-2008, 06:22 PM   #4
Dan99
My Ride: 2001 330xi
if that's the case then try this:
source: http://www.my330i.com/lof.php
RESETTING OIL SERVICE INDICATOR:
If your OBC needs to be reset after completing your oil change, there are two ways. NOTE: If you miss a step, just turn the key back off and try again:
A. Model Year 1999 to Mid-2000: You should have the older round 20-pin DLC connector under your hood behind the battery terminal, you need to use a small length of wire to connect (short) pins 7 and 19 for 3-5 seconds with the ignition key in position 1 (Accessory).
B. After Mid-2000: You should not have the 20-pin DLC connector. You only need to hold the left odometer reset button while turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds. All done.
Old 02-23-2008, 07:50 PM   #5
BmwPerfection
BmwPerfection's Avatar
My Ride: 3.5 M3 & 00 323ci
Send a message via AIM to BmwPerfection
The forum next time, this topic has been brought up hundreds of times...
BmwPerfection is offline   Reply With Quote
Old 02-23-2008, 07:52 PM   #6
Phoenixtsintsin
My Ride: 03 325i, 99 323i
This stinks. My 99 must be the only dammed car not to respond to this method.
But I was able to set the wife's 03 using the left button no problemo.
One out of two ain't bad.
Phoenixtsintsin is offline   Reply With Quote
Old 04-30-2008, 06:35 PM   #7
lumenos
My Ride: 2000 323i
I have a 2000 323i and i am having the same problem. I have read 100s of threads about connecting pins 7 and 19, i cant count the number of times i've tried and yet still nothing. So i have no idea but i dont want to spend $100 just to reset my damn oil counter, how stupid is that. If there is someone out there that knows how to do it let me know. By the way my car was built in April of 2000 so the knob thing doesnt work.
lumenos is offline   Reply With Quote
Old 04-30-2008, 09:35 PM   #8
grafiksguy
My Ride: 2010 328xi
This is a good visual diagram for the pin method http://forum.e46fanatics.com/showthr...ighlight=reset
The trick is in the timing. It's not about 3-5 seconds, it's exactly 5 seconds, which is what makes it often confounding to do. Too little time and it won't work, too much...ditto. Be patient and keep trying you'll get it. Also, pin 19 is really just the ground, and often the aluminum inside might have a slight tarnish which may inhibit a good contact. A solution I've found worked for me was to ground to the [-] battery terminal which is right there.
grafiksguy is offline   Reply With Quote
Old 04-30-2008, 09:46 PM   #9
monkeyjuice5150
My Ride: bmw
peak tool
monkeyjuice5150 is offline   Reply With Quote
Old 04-30-2008, 09:56 PM   #10
grafiksguy
My Ride: 2010 328xi
Originally Posted by Monkeyjuice5051 View Post
peak tool
Yeah, but where's the challenge in that? ;-}
Old 08-13-2015, 03:42 PM   #11
2000nhbmw
My Ride: 2000 328i
oil service reset
It's been a couple years since the last post here, so while it's probably working for most, I just went through it myself. The odometer button routine didn't work for me, I kept getting the test message. Jumping pin 7 to 19 didn't work. But jumping pin 7 to a bolt on the car and counting three seconds worked perfectly. Thanks for the help! This was on a 2000 328i.
2000nhbmw is offline   Reply With Quote
Old 06-17-2016, 05:24 PM   #12
Yober
did you connect the pin 7 to a (-) bolt first ? and then turned the key to position 1? or the other way around?
