Sponsored by The Tire Rack
Old 02-25-2008, 11:01 AM   #1
ethanhunter
My Ride: 2005 bmw 325i
18x8.5 CSL upfront 235/40/18 going rub?
Hi
I have a 05 325i BMW with stock sport suspension. As for 18 Staggard CSL
If I go 235/40/18front and 255/32/18 rear
I was told the 235 front will rub is that true? Should I go 225?
Does anyone know, not sure what size to get on front
thanks
ethanhunter is offline   Reply With Quote
Old 02-25-2008, 11:36 AM   #2
slvrr
My Ride: misses me
Originally Posted by ethanhunter View Post
Hi
thanks
It would help to know the offset of the wheel. However the problem is going to be the 235/40 you need a 235/35/18 instead
slvrr is offline   Reply With Quote
Old 02-25-2008, 12:19 PM   #3
jwm5
My Ride: station wagon
^^ Not necessarily, I have 235/40/18 on an 8"wide up front and have no problems. It all depends on the offset, But I would say the OP will be fine.
jwm5 is offline   Reply With Quote
Old 02-25-2008, 12:23 PM   #4
ethanhunter
Front offset is 40 on the CSL
Old 02-25-2008, 12:31 PM   #5
Dr. Anthony
My Ride: E92 M3, E46m3cab,x5d
I had 235/40/18s
8.5" wide wheel, and my car is VERY VERY low (coilovers) not once did I ever rub. you'll be fine.
Dr. Anthony is offline   Reply With Quote
Old 02-25-2008, 12:58 PM   #6
Arrows
My Ride: 2000 323i.
Send a message via AIM to Arrows Send a message via MSN to Arrows
235/40/18 is the correct tire size.
Arrows is offline   Reply With Quote
Old 02-25-2008, 03:09 PM   #7
ethanhunter
thanks!
Old 02-25-2008, 03:13 PM   #8
entcee
My Ride: 2002 325i Sedan
Originally Posted by Dr. Anthony View Post
I had 235/40/18s
What is your wheel offset?
entcee is offline   Reply With Quote
Old 02-25-2008, 03:41 PM   #9
Art Bimmer
My Ride: 2004 E46 Coupe
I'm riding on the same 235/40/18 CSL's offset 40 in front w/ OEM sports suspension with no problems, are you lowered?
Art Bimmer is offline   Reply With Quote
Old 02-25-2008, 03:44 PM   #10
entcee
I donlt mean to hijack this thread but the reason I asked is because I am seriosly thinking of getting the CSL reps +40 offset and was considering the same tire size (235/40/18).
I have the stock sport suspension but will eventually lower it about 1". Just donlt want it to rub. Of course, i have a sedan though.
Old 02-25-2008, 03:55 PM   #11
Dr. Anthony
To be honest, I cant remember. I *think* it may have been 35? or 42? i know.. it doesnt help much
Old 02-25-2008, 03:57 PM   #12
entcee
Thanks for the reply anyway
Old 02-25-2008, 09:02 PM   #13
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Hi,
Here at VMR we usually do 235/40/18 fronts on a 8.5" +40 offset. Never had a problem before at stock ride height.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 02-25-2008, 09:04 PM   #14
entcee
Would there be any problems after lowering about 1" more than sport suspension. (Or 1.6" from stock suspension)?
Old 02-25-2008, 09:09 PM   #15
VMRWheels
VMRWheels's Avatar
I cant guarantee that will not rub. Usually springs people can get away with, but when you start going on coil overs rubbing will occur more frequently.
-Charles@VMRWheels
Old 02-25-2008, 09:13 PM   #16
entcee
I will eventually go with springs. I am thinking of getting Eibach springs. Either 1.4" or 1.8" drop from the non-sport suspension.
Sounds like I may need to find a 8" wide rim and use a 225 tire or find the CSL rim in a higher offset... +45 maybe
Old 04-11-2010, 11:13 PM   #17
TrickTizzle
My Ride: 325i
Wil 245/40/18 rub on a 18x8.5 ET 35 in the front. Lowered on Eibach ProKit
Old 04-12-2010, 01:01 PM   #18
VMRWheels
VMRWheels's Avatar
245's up front could possible rub during hard cornering. It will be tough to say, due to the fact that each person is running a different tire manufacturer and each vehicles alignment will vary.
-Charles@VMRWheels
Old 04-12-2010, 04:32 PM   #19
ZeroSum
My Ride: 05 325
I have 245/40/18 Ps2's on an 8.5 ET38 with coilovers and about 1.5 degrees negative camber. Fits great.
ZeroSum is offline   Reply With Quote
