Old 05-11-2002, 09:47 PM   #1
andy 323i
My Ride: a gas guzzler
Send a message via AIM to andy 323i
ron / topaz330 and othe av ppl
what do you think of this
7-INCH LCD MONITOR, the quality only SONY can bring you. Side volume, color, hue and brightness control. Built in speaker, comes with mounting pedestal mount with adjustable height and angle
•Details:
12 volt DC.
NTSC
TFT ACTIVE MATRIX
Summary:
A wireless stereo audio/video sender working at 2.4 gigahertz. Mount your overhead monitor in your car or truck, tap into the domelight for power..install this package with your DVD (no wires) - Makes it EASY!!
•Details:
Makes things extremely easy. If you are considering an in car video system in your car, this package makes things so simple. Imagine this install, overhead monitor. Mount overhead monitor on roof, possibly tap into existing domelight wiring area for powering the monitor -- normally, you would have to run a composite RCA video cable and maybe 2 RCA audio cables to the monitor also to provide it a feed. In some installs, this involved taking down the headliner and a LOT of interior panels.
NO MORE!
Mount your overhead monitor or headrest monitor. Install the receiver near the monitor, hook it up to monitor. Now mount your DVD, VCR or game machine under the seat, the glove, center console, whatever, -- run outputs from DVD, VCR or source unit to TRANSMITTER and MAGIC! Signal travels at 2.4 gigahertz to the receiver (the monitor) up to 400 feet away!
If you use a source selector or switch (see switcher department), you can install a DVD, A Playstation, a VCR, a TV TUNER and output from the source switcher will output to the transmitter of this package, makes things SO EASY!!
2.4 Ghz transmitter and receiver included
3 selectable channels
Long range transmissions up to 400 feet
NTSC/PAL video format compatible
2 sets of high quality Video/Audio RCAs included!
FCC approved
May be used in home applications with a AC to DC converter (transmit your down stairs DSS or DVD signals to your upstairs television!)
Can also be used as a wireless security system, use as a baby sitter to watch your baby anytime and anywhere at your home
Monitor and recod a meeting from another room
Works on DC 10-15 volts
Emits 2 audio sources and 1 video source
Dipole antenna
with a dvd player
I'm BACK
andy 323i is offline   Reply With Quote
