Old 03-01-2008, 03:47 PM   #1
finger123
My Ride: E46 2001 M3
E46 M3 front bumper removal
Need some guidance from anyone who may know. Im trying to remove the front bumper of my M3. Im doing a VF SC install today, and everything seems to be going well so far **knock on wood**. however the issue is the front bumper. After reading a few DIY guides, nothing seems to be pointing me in the right direction. I removed 1 screw from each side of the fender well. Then removed the four screws from the bottom of the bumper. HOwever the bumper doesnt come off. What am i missing? It seems like there is more screws in place that is holding it. I have removed several bumpers on other types of cars, but never has it been this hard to remove just the front bumper. Oh yeah, i removed the screws that holds the foglights as well.
any inputs or help is greatly appreciated.
finger123 is offline   Reply With Quote
Old 03-01-2008, 04:17 PM   #2
WizeGi///M3
My Ride: 06 4.8is
Send a message via AIM to WizeGi///M3
Have you removed the screws in the fender liner as well as the under tray?
Also, there are a couple screws located under the headlights behind that trim piece. I took these off when I removed mine, unsure if it is necessary.
Carmen™
WizeGi///M3 is offline   Reply With Quote
Old 03-01-2008, 04:56 PM   #3
LagunaBlau///M3
My Ride: HEMI powered AWD
only screw's on there are the ones on the bottom and the ones in the fender well. and it should slide right off.
2010 SRT8 Challenger (mildly built motor)
2007 SRT8 Jeep Cherokee SRT8 SOLD!
2006 Subaru STI highly modified SOLD!
2003.5 E46 M3 (the smurf) SOLD!
LagunaBlau///M3 is offline   Reply With Quote
Old 03-01-2008, 06:24 PM   #4
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
You've got to give it a good tug directly forward. Some are a little stuck.
Chris.
HPF Chris is offline   Reply With Quote
Old 08-05-2008, 12:47 PM   #5
zerogravityE46
My Ride: 2002 BMW 325CI
just to follow up, i have a 325ci coupe with the m3 bumper, i believe its after market, now the e46 m3 has a carbon Kevlar bumper support = easy uninstall. on my car its aluminum, so does that mean to take of that bumper, i need to unbolt the whole bumper support off? because i got all 4 screws on the bottom, 2 near the under fender, and 2 in the fender well. but it still stuck, and yes seems it is stuck to the bumper support! let me know thanks
zerogravityE46 is offline   Reply With Quote
Old 08-05-2008, 02:32 PM   #6
redronin
My Ride: 330ci
2 T55 torx bolts on the underside of the reinforcement bar.
redronin is offline   Reply With Quote
Old 08-05-2008, 02:36 PM   #7
sheefo2k
sheefo2k's Avatar
My Ride: vrm psh - 02 325ci
theres 2 t 50 torx huge bolts on the carbon fiber reinforcment bar.. its right above the mesh!!
Performance BMW car
Sponsored by :
www.euro-spec.net
www.bimmian.com
BMW Motorwerks
support:
www.vmwerks.com
www.esstuning.com
www.my330i.com
sheefo2k is offline   Reply With Quote
Old 08-05-2008, 02:37 PM   #8
sheefo2k
sheefo2k's Avatar
damn it you beat me to it.. but i think its a t50 not t55
Performance BMW car
Sponsored by :
www.euro-spec.net
www.bimmian.com
BMW Motorwerks
support:
www.vmwerks.com
www.esstuning.com
www.my330i.com
Old 08-05-2008, 02:53 PM   #9
sheefo2k
sheefo2k's Avatar
Performance BMW car
Sponsored by :
www.euro-spec.net
www.bimmian.com
BMW Motorwerks
support:
www.vmwerks.com
www.esstuning.com
www.my330i.com
Old 08-07-2008, 12:54 AM   #10
zerogravityE46
what sucks is that the bumper mesh does not come off, it is part of the bumper. now i see 8 or 10mm bolt near the foglight underneath , but dont see any torx bolts under the mesh area. is there a post on how to for my year 2002?
Old 06-07-2009, 05:23 PM   #11
EURO M3 CSL
My Ride: 05' Comp M3-CSL
Send a message via AIM to EURO M3 CSL
any1 figured out how to get these off? My car just got hit and a new front bumper is needed. Going to be doing the job myself as the person who hit me is my friend and offered to pay for everything.
EURO M3 CSL is offline   Reply With Quote
Old 06-08-2009, 10:14 AM   #12
bluejeansonfire
ninja editor
My Ride: m5xual
Send a message via AIM to bluejeansonfire
read the posts above, the process of bumper removal was addressed. If you need more visual aid, I recommend a Haynes or Bentley manual.
01 330cit-92 s13c-99 328i/5-04 x5/6
bluejeansonfire is offline   Reply With Quote
Old 11-13-2009, 03:08 PM   #13
umermariner
My Ride: 1999, 328I
http://www.e46fanatics.com/howto/how...hp?howto_id=41
A good write up
umermariner is offline   Reply With Quote
Old 11-13-2009, 04:02 PM   #14
finger123
Originally Posted by umermariner View Post
thanks for bringing back the dead....
Old 11-14-2009, 02:10 AM   #15
RACEMX-M3
My Ride: M3
It's been a while since my car was oem so not sure if this is complete but here's what I do - remove 3 8mm bolts from the fender well on each side (total of 6 bolts). On the driver's side there's 2 more 8mm bolts under the bumper that connect to the fender well. The fender well should now be able to be removed and set aside. The passenger side also has 2 8mm bolts and a plastic phillips screw that needs to be removed and you then need to pull out the plastic "thing" that the screw came out of. You should now be able to remove the passenger fender well and then remove the bumper. Just tug on the bumper each side and it should come off with a little persistence. Once the bumper is off the body you will need to disconnect the the fog lights on each side - just rotate the gray plastic insert about 90 degrees and it will come right out.
RACEMX-M3 is offline   Reply With Quote
Old 11-14-2009, 02:13 AM   #16
RACEMX-M3
My Ride: M3
Not sure about other E46 cars but the torx bolts by the mesh are not present on the M3.
