///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 03-02-2008, 01:36 PM   #1
KHMITCHEM
My Ride: 2002 bmw M3
Limp Mode???
I Have A 2002 M3 Dn Recently My Car Has Been Running Bad. Hardly The Power It Had The First Two Weeks I Had It. The Check Engine Light Has Come On, And After Having It Read It Says Misfire In Cylinders. The Dealer Cant Seem To Help Me Without Ringing Me Up For More Money Than Neccesary. Does Anyone Have Any Ideas As To What It Could Be? I Bought It Recently In Texas And I Live In Kansas. Could It Be The Difference In Gas?
KHMITCHEM is offline   Reply With Quote
Old 03-02-2008, 01:48 PM   #2
shagwar
My Ride: E53 & E90
doesnt sound like limp mode.
shagwar is offline   Reply With Quote
Old 03-02-2008, 02:12 PM   #3
KHMITCHEM
Any Suggestions As To What It Could Be? I Read Somewhere About Some Cam Sensors? Could Be Making That Up? Who Knows Im Just Getting Into These Cars And I Am Having Nothing But Trouble So Far.
Old 03-02-2008, 02:15 PM   #4
coolmody
My Ride: E46 M3 / E28 Turbo
It's your Bremi ignition coils. There is a service bulletin out on them. They are warrantied for 8years/unlimited mileage.
"SI B 12 24 05
Engine Electrical SystemsFebruary 2006
Technical Service
This Service Information Bulletin replaces S.I. B12 02 04 dated March 2005.
SUBJECT
S54B32- Special Limited Ignition Coils Warranty of 8 Years/Unlimited Miles
MODEL
MY '01, '02, '03 E46 - M3 coupe/convertible with S54 engine
MY '01, '02 E36/7 - M roadster/coupe with S54 engine
SITUATION
BMW has become aware of a potential problem that could affect the durability of Bremi ignition coils of certain MY' 2001, 2002, and 2003 BMW automobiles equipped with the Motorsport S54B32 engines. We estimate that only a small percentage of vehicles will actually develop a problem. Affected vehicles may have a Service Engine Soon light illuminated with misfire faults stored in the Engine Control Module (DME) and a rough running complaint.
CORRECTION
In the event that the Bremi ignition coils of a 2001, 2002, 2003 E46 (M3 coupe/convertible), or 2001, 2002 E36/7 (M roadster, M coupe) with S54B32 engine exhibit the symptoms of failure indicated above, they should be replaced with the improved ERA part (PN 12 13 7 551 260). For ignition coils replacing instruction refer to RA 12 13 511 found in BMW TIS.
PARTS INFORMATION
Part Number
Description
Quantity
12 13 7 551 260
ERA coil
Max 6
WARRANTY INFORMATION
As a commitment to our customers, and to demonstrate our confidence in our product, BMW will extend the warranty of the Bremi ignition coils from 4 years or 50,000 miles to 8 years and unlimited miles.
The warranty extension for this component applies to the above listed models only and is transferable to any subsequent purchaser of these models.
This extended warranty is applicable to vehicles registered in all 50 states.
Warranty coverage for all other parts is not affected.
BMW will inform all affected owners of the above listed models of their extended Bremi ignition coils warranty. A sample letter is attached.
The following Warranty Information should be used if Bremi ignition coils replacement becomes necessary as outlined above:
Defect Code
12 13 93 14 00
Replace Bremi ignition coils. Includes deleting any
misfire fault codes stored in the Engine Control
Module (ECM/DME)
Main Work
Labor Operation:
Labor Allowance:
00 54 124
11 FRU - E46 M3 with S54
8 FRU - E36/7 M roadster/coupe with S54
+Associated Work
Labor Operation:
Labor Allowance:
00 54 692
9 FRU - E46 M3 with S54
6 FRU - E36/7 M roadster/coupe with S54
Note: The following explanations spell out the correct use of the work times.
Main Work:
Use this labor operation number when the only repair performed is the listed warranty repair.
OR
+Associated Work:
Use this labor operation number when other repairs or services are performed along with the listed warranty repair.
Under no circumstances should both labor operation numbers be claimed. Attempts to claim both times will result in an unnecessary delay in claim processing and payment"
coolmody is offline   Reply With Quote
Old 03-02-2008, 02:28 PM   #5
KHMITCHEM
Thank You Very Much For All Your Help! I Am Supposed To Take It In To The Dealer Tom. Morning So Lets Pray It Works Out.
Old 03-02-2008, 05:00 PM   #6
Alan
Alan's Avatar
My Ride: 2006 M3
Bad coils will cause limp mode - and what you describe doesn't sound anything like limp mode.
Alan is offline   Reply With Quote
Old 03-03-2008, 08:22 PM   #7
KHMITCHEM
Sure Enough It Was Bad Coils! Got Her Fixed And Running Strong Again! Thanks Again For The Post! Saved Me A Lot Of Money!
Old 03-03-2008, 08:24 PM   #8
e4604
Banned
My Ride: ...
WHATS WITH YELLING!!!!! n00bs
e4604 is offline   Reply With Quote
Old 03-03-2008, 08:29 PM   #9
KHMITCHEM
Sorry My System Only Runs Off Of Caps Lock At Work! Yeah Im At Work And On The Forum!
Old 03-03-2008, 08:33 PM   #10
e4604
Banned
My Ride: ...
ah, disregard my previous post then
Old 03-27-2008, 09:30 AM   #11
TAILWAG
My Ride: 911EVT775 /Noble M12
back for more...?
I am driving today to work and suddenly my car begins to hesitate..as if it is missing wanting to backfire...??? I look at my dash and my "service engine soon" appears.
The car seems to run really rough, has limited power and it idles like a truck.
I wonder if this is the same issue you had. I will have to take it in to the dealership to see if this is the case.
Does anyone know if there are certain VIN numbers that were affected by it or are these ignition coils on ALL 2002 models? My M3 is running like ass and I need to get this fixed!!!???? Thanks!
2007 Porsche 911 EVT750
2004 Noble M12 GTO 3R
2012 GT-R Alpha 9+ 4.2 Stroker
2009 MB C63 AMG Supersprint
2010 Nissan Xterra Offroad
TAILWAG is offline   Reply With Quote
Old 08-30-2008, 11:53 PM   #12
paulwu
My Ride: 2004 BMW M3
2004 M3 Misfire
"SI B 12 24 05
Technical Service
SUBJECT
MODEL
SITUATION
CORRECTION
PARTS INFORMATION
Part Number
Description
Quantity
12 13 7 551 260
ERA coil
Max 6
Defect Code
12 13 93 14 00
Module (ECM/DME)
Main Work
Labor Operation:
Labor Allowance:
00 54 124
+Associated Work
Labor Operation:
Labor Allowance:
00 54 692
Main Work:
OR
+Associated Work:
I read your post and thank you for very useful info. I got a question here. My 04 E46 M3 built in 03 NOV.
Do you think it still covers for the Bremi coils replacement warranty?
However, my car was imported from USA and now in Quebec Montreal you think the dealer will still cover this service bulletin?
My car was driving fine but suddenly limd and misfire yesterday. I pulled the codes got cylinder 3, 4, 5 cylinders misfires!
Ouch how this would be so suddenly and having 3 colls bad together?!
paulwu is offline   Reply With Quote
Old 08-31-2008, 12:21 AM   #13
johnkent3
My Ride: 02 M3 Carbon/Cinnamo
02 sensors
sounds like f'd up o2 sensors
Stainless no-cat headers, D/A race software (Sean is ultra pro!), autosolutions ssk, borla midpipe V1, borla muffler, gunmetal factory 18s, 4.10 gears from DIFFSONLINE.com (DAN is the best!) murdered out everything else. super clean always, carbon/cinnamon
M 4 EVA!
johnkent3 is offline   Reply With Quote
Old 09-02-2008, 07:44 PM   #14
paulwu
I passed by dealer today and gave the VIN of my 04 M3. Also I present about the service bulletins copied and printed out from forum inputs; but the dealer told me the print out didn't work since the BMW USA is different from BMW Canada recall and also saying that the letter doesn't specify it is for my car with VIN on it. Bad!
You mentioned your M3 also imported from USA and no problem to have coils replecement in Canada dealer? The dealer recommend me to pay first for the the coils replacement and they will try to check for recall and reimbursement for me! But I think if you let dealer do the job they will simply charge you and then make you hopeless without any effort!
Any input will be appreciated!
Old 09-04-2008, 03:52 PM   #15
carbon Bimmer
My Ride: 04 M3
These will probably be cheaper then what the dealership would charge for parts and labor. These are probably better and you can put them on yourself in 5 minutes. If these exact ones are the wrong ones for your car I think they carry them for most models.
http://www.bavauto.com/shop.asp?HC1=...CY=2004&HCM=M3
carbon Bimmer is offline   Reply With Quote
Old 09-04-2008, 04:14 PM   #16
VAMZ
My Ride: ///M3
Send a message via Yahoo to VAMZ
is there a thread / bulletin where it lists all the recalls for the e46 m3?
VAMZ is offline   Reply With Quote
Old 09-04-2008, 06:43 PM   #17
dfedon4
My Ride: Jeep
My brother-in-law was having a problem with his 03 on Tuesday. He said it felt like her lost a cylinder. After he dropped it off at the dealership, i told him about this thread about the coils. The next day, the dealr called and told him that it was twoofhis coils and that he would replace them for free because of the recall. He didn't even have to bring it up. Century BMW - Greenville, SC. Thanks for posting this topic.
dfedon4 is offline   Reply With Quote
Old 07-02-2014, 03:52 AM   #18
iansevilla
My Ride: 2004 M3 Coupe
Limp Mode???
I'm thinking of getting them too. It's high performance coils. Do you think this will resolve the backfire on high rpm? I get a back fire once in a while on high rpm. Backfire happens when I shift gears....no check engine light or any kind. :-)
iansevilla is offline   Reply With Quote
