E46 Convertible
Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
Old 03-14-2008, 10:53 AM   #21
e46vert
My Ride: 330ci
Yeah got to make sure the trunk is closed tight. Thats what happened to me too.
e46vert is offline   Reply With Quote
Old 03-19-2008, 01:19 PM   #22
TheRiddle
Sofa-king-what
My Ride: M52TUB28-Vert
I have an other problem..
top won't roll up.. the led is blinking but there's no movement..
to make it work i've to unfold manually the top 'till a certanin point and then i can use te close button..
and everything work..
but when i try to roll it back it stops @ 3/4 and there were no way to close it.. i've had to remove the keys,let the sys.discharge and then lock the compartment by the torx between the seats...
Dealer already changed both haul sensors and the ecu, but nothing changed
check the video and give me your opinions
http://www.gigasize.com/get.php?d=73oyrysr66c
TheRiddle is offline   Reply With Quote
Old 03-26-2008, 09:24 PM   #23
ck_gixxer
My Ride: 323 vert e39 m5/////
+1 more 2000 323 went to open it today it dropped the window but nothing else. I am going to manually lock it and unlock at the front windshield torx. I will report findings tomorrow.
ck_gixxer is offline   Reply With Quote
Old 03-27-2008, 09:21 PM   #24
silentak1
Banned
My Ride: '03 330ci cabrio
<-- subscribed
This sometimes happens to me, but it has always been fixed by just collapsing/expanding the storage compartment, closing the trunk, and press the opposite button of what I'm trying to do (i.e. If i'm trying to open it, I'd push the close button until it closes and then re-open).
I think in my case it may be related to my trunk release latch mechanism. Sometimes my trunk won't close, so I have to press the trunk release button again for it to "unjam" and then all is well. I get a feeling that most people have some time of "sensor" failure somewhere in the system, and not a pump problem.
Anyone have a Bentley manual?
silentak1 is offline   Reply With Quote
Old 03-30-2008, 12:30 PM   #25
honeywell
Banned
My Ride: undecided
i had a same problem, FIXED by replacing the compartment shock/absorber in the trunk
only $25 for a shock and trim.
installation wouldn't be so hard
http://forum.e46fanatics.com/showthread.php?t=559874
honeywell is offline   Reply With Quote
Old 03-30-2008, 01:20 PM   #26
TheRiddle
Sofa-king-what
orange light.. here the problem is the red one.....
anyway tomorrow i'll take it to a different dealer and let's what they can discover..
Old 04-02-2008, 08:57 AM   #27
TheRiddle
Sofa-king-what
Just recieved a call from the dealer..
and confirmed my worst nightmare..
After 2 days of testing they couldn't find where is the problem, they think that is related to the electric sys.
considering that ecu and haul sensors are ok ( they checked the top angle via Modic and every degree is correct)
they suppose that the problem is a shorted circuit in a wire somewhere..
if I want to procede they must dismantle the entire top and part of the car,charging me for this operation..
i've consdered to get an used ebay top for spares but the prices is around 1000 (but i dont need the fabrics..only the wires,the line and the valves assembly)..
I dont' think that the game is worth the candle..
but at the same time i think that the labor fees will be quite high for the things they have to do for finding the problem..
Advices?
Old 04-02-2008, 07:12 PM   #28
silentak1
Banned
This guy is selling a lot of parts from his convertible. Might want to try him...
http://forum.e46fanatics.com/showthread.php?t=512593
"bkms1"
Old 10-02-2008, 10:44 AM   #29
swednrox
My Ride: 2003 330cic
Sorry to hear about your problems,here is more Convertible problems....
I found a oil leak under the car on my right rear side,i traced it up to the trunk and located the hydraulic cylinder on the right side,man it was oil everywhere,all cables are soaked,battery was soaked.....half the container was emty.....(on the left side)
Anyway,i found the problem to why my top doeasnt work!!!Now i just need help from someone that have experience in this,is this a DIY project?I bought the hydraulic cylinder already,i did order it on 1stbmw.com,i saved $ 107.00 compare to the dealer.(i paid 201.00)(dealer 308.00).
Would i find istructions in the Bentley manual?
swednrox is offline   Reply With Quote
Old 10-02-2008, 12:51 PM   #30
TheRiddle
Sofa-king-what
ops ...
i forgot to update this.
I've found usefull infos on yahoo groups (dudes.. thanks again)
the problem was solved after changing the whole harness (from the top's ECU to the front lock mechanism).
as I supposed was something quite obvious and easy..
and not something related to the sensors or motors(as dealers keep saying)
Is funny because 2 on 3 dealers that i've asked to solve this problem never mentioned the harness, the 3rd agreed with me on it but refused to work on my car because they never did that job, and they don't want to risk to damage it
the harness was cheap more or less 150, the labor more than 500....
anyway, now my top is working great, still having squeaks and a lil' leakage into the trunk (only in case of really heavy rain), but it folds...
Old 10-02-2008, 01:10 PM   #31
EDH330CIC
My Ride: E-46 330 Droptop
Great to hear you got it fixed!
Can you post any of links for the Yahoo page for the repairs?
Geo.
EDH330CIC is offline   Reply With Quote
Old 10-02-2008, 01:44 PM   #32
TheRiddle
Sofa-king-what
http://autos.groups.yahoo.com/group/bmwconvertible/
Old 02-01-2010, 09:39 AM   #33
rads
My Ride: E46 M3
Holy Thread Resurrection!
I seem to be having a problem with my convertible roof when the temperature drops below 0 centigrade.
This quote from page one of the thread seems to describe pretty much exactly what I am experiencing, but it is the only scrap of evidence I can find anywhere on the web which suggests the presence of a cold temperature sensor for the roof.
a couple of amateur thoughts on this...
my '02 car originally came w/ a temperature sensor that wouldn't allow the top to go down below 28 degrees. of course, it wouldn't allow it to go up either. so it got stuck down one winter morning when the temperature plummeted and the car had been sitting in the garage over the weekend.
took it straight to the dealer, where they removed (maybe bypassed) the sensor. those sensors are no longer used and the top works great.
Has anyone else experienced this, or point me towards anymore info?
Over the last couple of days my experience has been as follows:
Temperature Roof Operation
+1 C open
-2 C Stuck - red light on button when trying to close but no movement, no noise, no window drop etc. *1
0 C Closed Nornmally
-1 C Refused to open, symptoms as per *1
+0.5 Opened normally
+0.5 Closed normally
Looks like an open and shut case () but there was, of course, some driving in between the steps, and the boot was opened and closed so there could be other factors. That said, when the roof first failed to close, I did try slamming the boot several times and the roof still did not work.
So in summary, E46 roof temperature inhibit switch, true or false.
David
'03 M3 convertible, in the UK
rads is offline   Reply With Quote
Old 02-14-2010, 04:16 AM   #34
badman
My Ride: bmw 330 convertible
Roof problem
Hi guys i had the same problem check that your boot or trunk[usa] is locking and unlocking that was my problem fixd it my self.Just rest the roof manuly and try again.
badman is offline   Reply With Quote
Old 02-14-2010, 10:33 AM   #35
i_ween
My Ride: '02 330Ci Vert
you are not supposed to put the top down in cold weather. says so in the manual.
-Derek
check out my astrophotography:
www.gil-galad.com
i_ween is offline   Reply With Quote
Old 02-14-2010, 05:23 PM   #36
Brett LaCroix
My Ride: 2001 330CiC 5-speed
Mine was already down... in the garage... before I took my car for a ride.
It was cold... but certainly not freezing... when I attempted to put my top up.
It stopped a few inches from "closed"... just died... and gave me the "blinking red light of death". I had to manually close it the rest of the way.
I am waiting for a sunny day to pull my car out... let the top warm up... then try to manually close the top all the way to see if that resets it.
However, I seem to remember trying to manually close the top the day it happened, but did not have any luck. I hope something is not broken or jammmed inside.
:) Brett
Brett LaCroix is offline   Reply With Quote
Old 09-26-2010, 09:34 PM   #37
d4cam2000
My Ride: 2002 Vert 330ci
Hello,
I'm new here. I am having the same problems with my '02 330CiC and today soft top operation stoped in down position before lid plate locks completely and started to make clicking noise. I reseted it and closed manually. Red light is blinking and now it doesn't want to open. Any suggestions will be very appresiated.
d4cam2000 is offline   Reply With Quote
Old 02-09-2011, 03:40 AM   #38
yazeed
My Ride: E36 328
hi everybody...
Who has technical reference for cabriolet of E46?..hope anybody can share with me....
yazeed is offline   Reply With Quote
Old 02-09-2011, 08:35 AM   #39
Lionelski
My Ride: 325CIc
Originally Posted by ///M3Turk View Post
Hi folks..i hope everybody is ok..
I've had my 03 convertible m3 for 2 years without a problem... i like to keep my car in my garage if the weather isn't good.. Today the weather was mostly sunny and i decided to drive it around in my town and put the top down.. when i was holding the button to put the top down it didnt work.. i tried it 10 times but it never worked..
did anybody have the same problem?? what should i do?
Please HELP ME!!
Thank you..!
I'm assuming that you checked to make sure the space saver (behind the rear seat) in the trunk was open?
And that the car was parked when you were trying to put the topdown?
'Ski
www.WarrenvilleRailroad.com
2001 325ci Convertible - Titanium Silver
Sport Package, Premium Package
Racing Dynamics Strut Tower Brace
Conforti Shark Injector, Conforti CAI
Interior: Leather, Euro Tray, M3 Dead Pedal
Lionelski is offline   Reply With Quote
Old 02-09-2011, 09:44 AM   #40
SMUUUUUV
My Ride: 330CiC X5 4.4-MBS550
you are not supposed to put the top down in cold weather. Says so in the manual.
+1.....
SMUUUUUV is offline   Reply With Quote
