Old 03-03-2008, 06:11 PM   #1
RedBarron
My Ride: Porsche
Send a message via AIM to RedBarron
Angel Eye problem.
I have a problem with my angel eyes that when I have the angel eyes wired up the inside lights to the car as the remote function, the angle eyes will come on for about 5 seconds then start flickering along with the interior lights in my car. Also when I have it hooked just to the ECU tap they do not come on. I just put a new wiring harness in and the ground is good. Any idea, I think i need to check the ecu tap.
RedBarron is offline   Reply With Quote
Old 03-03-2008, 09:46 PM   #2
RedBarron
My Ride: Porsche
maybe the ballast are shot?
Old 03-03-2008, 10:12 PM   #3
sillieidiot
My Ride: '06 AW 330ci
check the fuse. that might explain the angels not coming on with the ecu. but the flickering for the interior lights, did you tap it right?
Old 03-03-2008, 10:15 PM   #4
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
Is this when the vehicle is off or idle? The inverters (proper name) need a minimum of 13.5V to fire up correctly.
tom @ eas is offline   Reply With Quote
Old 03-03-2008, 11:04 PM   #5
sillieidiot
he's using a wiring harness. power is from the battery so that isn't a problem.
Old 03-04-2008, 04:22 PM   #6
RedBarron
My Ride: Porsche
ok the inline fuse in the warning harness keeps blowing fuses, what would cause this?
Old 03-04-2008, 04:58 PM   #7
sillieidiot
that would mean you have a short somewhere. check your connections again. make sure they are properly insulated.
Old 03-04-2008, 10:26 PM   #8
RedBarron
My Ride: Porsche
I think it's prob a bad inverter. I disconnected the side that was not working and put a new fuse in and and the one side worked fine. Im going to hook up the possible faulty inverter to the other side tomorrow to confirm if the inverter is bad.
