Old 03-08-2008, 01:33 PM   #1
DADON4SHO
My Ride: SLOW E46
changing my belts for 150
is that a good deal
thats for all the belts and install
thanks guys
Photobucket
DADON4SHO is offline   Reply With Quote
Old 03-08-2008, 01:36 PM   #2
///Mbimmer
My Ride: `02 325i
i think its a good deal, I paid 210$ for replacing my belts at a local shop
///Mbimmer is offline   Reply With Quote
Old 03-08-2008, 01:43 PM   #3
BartenderPlease
My Ride: 328i Sport
Send a message via AIM to BartenderPlease
Nice. I got my belts replaced and thermostat replaced yesterday for $281.
Gottalovethexi: thx for the old p-chopped sig
| BBS CH | FK coils | RE Bushings/Mounts | K&N Intake | ZHP box/no resonators |
| 330i brakes | FX-R + Orion V4 | Full Exterior LED kit | JL Audio in trunk |
BartenderPlease is offline   Reply With Quote
Old 03-08-2008, 03:50 PM   #4
Jrob1
My Ride: 2003 BMW 330i
Come on guys, this is seriously the easiest DIY out there. New belts from Autozone cost $40 and I got them installed in around 15 minutes. Don't waste your money having a shop do it.
Jrob1 is offline   Reply With Quote
Old 03-08-2008, 04:10 PM   #5
Dan04E46
My Ride: '04 S54B32 Coupe
I agree. It's about as hard/time consuming as changing the oil. But for those that aren't mechanically inclined, $150 sounds about right.
DAN WAS HERE
2001 330Ci= Sold :(
2004 M3 coupe= Mine! :D
Dan04E46 is offline   Reply With Quote
Old 03-08-2008, 04:18 PM   #6
Jrob1
You don't have to be mechanically inclined to do it, as long as you have a couple tools, just follow one of the many DIY's on here and it's a piece of cake.
Old 03-08-2008, 04:20 PM   #7
lftlane
My Ride: 2006 M3
The only "strange" tool is the t50 torx bit. Definitely an easy DIY.
lftlane is offline   Reply With Quote
Old 03-08-2008, 04:58 PM   #8
DADON4SHO
My Ride: SLOW E46
really? n e one got a dyi page? or wanna come down and help me?
Photobucket
Old 03-08-2008, 05:20 PM   #9
lftlane
My Ride: 2006 M3
http://tuningemotion.com/forum/showthread.php?t=2471
That's a thread on replacing the water pump but you have to take the belts off to do that, so it's the same idea. You may or may not need that tool to get the fan off, it just depends on your car. I ***think*** automatic cars are more likely to have the mechanical fan and thus need that special tool. Anyways, once you get the fan out it's just a matter of taking the caps off of a couple of T50 torx bolts and cranking them to one side and all the belts will come loose.
Old 03-08-2008, 06:12 PM   #10
DADON4SHO
My Ride: SLOW E46
thats for all the belts, accessory belts too
Photobucket
Old 03-08-2008, 06:18 PM   #11
lftlane
My Ride: 2006 M3
Yeah, the E46 has 2 belts. One belt is for the AC and one that runs the alternator, PS pump, and water pump. The AC belt is on the outside, the drive belt is behind it.
Old 03-08-2008, 10:01 PM   #12
DADON4SHO
My Ride: SLOW E46
so is it a good deal??????????????????
Photobucket
Old 03-08-2008, 11:13 PM   #13
tko200
My Ride: 01, 325i
Easy diy i did on my E36 , i will be doing my E46 soon water pump and thermostat, belts already change at 66.000, now have 70.000 miles.
tko200 is offline   Reply With Quote
Old 03-09-2008, 12:27 AM   #14
323Panzer
My Ride: 1999 BMW 323i E46
Just did a belt swap during a water pump diy and must say it was easy.
323Panzer is offline   Reply With Quote
Old 03-09-2008, 12:51 AM   #15
digivation
changing your belts is only difficult when you have the mechanical fan (either you must remove it or work around it).
other then that, its really easy to change them - my tensioners use regular hex heads that you can turn with a socket wrench (you grab the one that's molded into the metal and offset from center). Rotate, put a small screw or pin of some sort through the "lock" holes to keep the tensioner from tightening back down.
Then slip the old belts off, put the new ones on (being sure to route them the same as the old ones), remove the pin or screw from the lock holes in the tensioners... voila, you're done!
digivation is offline   Reply With Quote
Old 03-09-2008, 06:17 PM   #16
Jrob1
Here is the DIY I used, very easy to follow and with pictures to help http://forum.e46fanatics.com/showthr...light=belt+diy
Old 03-09-2008, 09:08 PM   #17
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: Evo, 330Ci, Xterra
20 minute job. You can Paypal me $150 if you have that kind of cash lying around. I could use it.
^No longer looks like this
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 03-09-2008, 09:10 PM   #18
Snik
Snik's Avatar
My Ride: IR M3 Vert.
all u need is a few sockets, a screw driver, a t10 torx screwdriver, and a helping hand, its not worth $150, its a 30min job
Stuff for sale!!!!!
Do you ride a sportbike?
Old 08-22-2012, 05:49 PM   #19
cvessup
My Ride: 325ci
So ur saying auto belts are good.. beter then continantal ones,.? @ jrob1
cvessup is offline   Reply With Quote
Old 08-22-2012, 06:35 PM   #20
afstud
My Ride: 02 & 04 325xi sports
i get mine from advance auto because they have dayco which is a german company
2002 325xi Sport 5 speed Euro clears, short shifter, style 119 wheels
2002 GMC Envoy SLT (stock)
afstud is offline   Reply With Quote
