Sponsored by The Tire Rack
Old 03-16-2008, 12:15 PM   #1
330iGuy07
My Ride: 2004 330i ZHP
how deep should tread be before replacement?
I have the 18" tires that came on my 2004 330i ZHP (M wheels/tires). They're 4 years old and have about 30K miles on them. I estimate there to be just under 1/4" of tread depth. What is the number/depth I should start thinking about replacement?
2004 330i ZHP
330iGuy07 is offline   Reply With Quote
Old 03-16-2008, 03:53 PM   #2
mcr_driver
My Ride: my favorite two feet
you can take them to a place like discount tire and have them use a tire tread gauge or buy one and check yourself. im sure you can find one at a autozone and snag one.
mcr_driver is offline   Reply With Quote
Old 03-16-2008, 04:00 PM   #3
Polish_328Ci
My Ride: M3
Every so often in the grooves there is a...forgot the name so let's call it a "speed bump" when the tread and that bump line up or almost line up it's time to change your tires. Just run your hand along the groove and you'll feel it.
Polish_328Ci is offline   Reply With Quote
Old 03-16-2008, 09:50 PM   #4
Xcelratr
My Ride: 04 330Ci ZHP
^^^ "wear bars"
Your tires probably started with about 11/32" of tread depth. The wear bars are 2/32" tall. When the tread is worn even with them, the tire is considered worn out.
Generally, the less tread depth you have, the better the tire will grip and handle on dry pavement. The tread lugs flare slightly as they get to the bottom, so the shorter they are, the more rubber contacts the road. Also the shorter the tread lugs get, the more stable they are. More rubber contacting the road and stiffer tread lugs = better handling.
The downside is that once you're dealing with anything other than dry pavement, the lower tread depth makes the tire handle worse. The most common example is driving in rain. A newer tire has more volume in the tread grooves, so it can move more water faster out from underneath the tire, allowing the tread lugs to stay in contact with the road surface. When the tread groove volume isnt enough to displace water at a rate that allows the tread lugs to stay in contact with the road surface, the tire hydroplanes. That's bad news.
So depending on the conditions you drive in, it might be a good idea to replace the tires before they reach the wear bars. Or, you can maximize your mile per $ and run them down until they're slicks before replacing them. It's a judgement call on your part.
Hope this helps.
We will not tolerate intolerance.
Xcelratr is offline   Reply With Quote
Old 03-16-2008, 10:27 PM   #5
Penguin Koolaid
Banned
My Ride: Inline Six
Everything you need to know:
http://www.tirerack.com/tires/tirete....jsp?techid=51
Penguin Koolaid is offline   Reply With Quote
Old 03-16-2008, 10:27 PM   #6
Polish_328Ci
My Ride: M3
Originally Posted by Xcelratr View Post
^^^ "wear bars"
^thanks for filling in the name..
Old 03-17-2008, 10:50 AM   #7
330iGuy07
Thank you all for the input. The tires(and rims) are currently off the car for the Winter. When I did drive them last Fall, I noticed some slipping (or start of hydroplaning) on a few really rainy drives. Right now I have the Dunlop Winter Sport 3D's on and it's been great. But these are 16" wheels and I want to go back to the 18" wheels now that Winter's over.
I might first have to buy the 18" Pirelli or Goodyear F1 all season tires before I put them back on. I was just a little put off and uncomfortable about the way the car handled on wet roads.
Based on Tire Rack reviews, people really seem to like both and claim they handle very well on wet roads. Anyone have further comments about a good set of all season tires to go on the 18" M wheels?
2004 330i ZHP
Old 03-18-2008, 11:16 AM   #8
330iGuy07
I guess I really need to get mine replaced. I finally got around to using the penny measurement method of the treads on my 18" tires. They're down to about 6/32" at the deepest point and almost nothing at the lowest point where the treads thin out to a point.
In this file image, my treads are thickest (6/32") in the wider parts of the treads, but progressively become nothing as the treads narrow to the point. Is that the normal design of this tire?
2004 330i ZHP
Old 03-18-2008, 03:32 PM   #9
Penguin Koolaid
Banned
My Ride: Inline Six
I had to replace my RE750 Potenzas because they were bald on the insides of the tire, despite having maybe another 7,000 miles to go on the thickest part. I was worried about hydroplaning problems.
It's normal for the insides to wear faster, especially the rears.
