Old 03-22-2008, 12:14 PM   #1
lilstevo900k
My Ride: 2001 330xi
odd vibration
Around 79 mph, 2600 ish rpms i think? the car has a pretty noticable vibration. There is a low rumbling sound, and the entire car, not just the wheel or the gas, shakes. It happens at the high speed (maybe just more noticable, i dont know, 90% of my driving is city) at exactly that rpm. Take my foot off the gas for going downhill and maintaining speed, it goes away. Apply pressure, and it comes back. Because of this, i figured balance or alignment issues arent the problem. Besides this, im semi-lost on what this could be.
Any ideas? Thanks
lilstevo900k is offline   Reply With Quote
Old 03-22-2008, 12:56 PM   #2
Fly Guy
My Ride: E46 323I
I have the same problems. Is the the control arms? Mine is really felt by the front passenger side.
FS:: Pioneer AVIC N3 Navigation/DVD/iPod/MP3
http://forum.e46fanatics.com/showthread.php?t=609482
FS::Two Breitling Bentley Watchs: High End Replicas
http://forum.e46fanatics.com/showthread.php?t=610457
Fly Guy is offline   Reply With Quote
Old 03-22-2008, 01:01 PM   #3
numba1guju
My Ride: 2013 328i
Send a message via AIM to numba1guju
balancing...i just got rid of my shake...and if you have bigger wheels on your car and you have bad camber in front your tires wear uneven so it causes the rumble/shake at high speeds of 60-80...at least thats what the guy at discount tire said...i felt my tires so im pretty sure what he said is right
2002 325i: Black/Black
Mods: Clears, VM V715 Matte Black 19in staggered, 20% tint all around, Suspension Technique Coilovers, p46s 6000k w/ aurora 60LED
numba1guju is offline   Reply With Quote
Old 03-22-2008, 01:38 PM   #4
lilstevo900k
My Ride: 2001 330xi
it seems to have too many things related to engine speed to be a balance issue..maybe?
Old 03-22-2008, 02:34 PM   #5
jsonli
My Ride: 04 330ci TiAg
differential? just a shot in the dark i really don't know.
did you look into the xi specific issues?
jsonli is offline   Reply With Quote
Old 03-22-2008, 05:45 PM   #6
lilstevo900k
My Ride: 2001 330xi
could not even find a close choice to help explain the problem,
if it even is a problem....?
Old 03-22-2008, 09:52 PM   #7
Topshelf
My Ride: 2005 325xiT
Do you have an xi? If so, it's your front inner CV joint. Most likely the drivers side. Not sure what causes it, but the grease in there has broken down and after 10-15 minutes of driving it will start a horrible vibration when on the gas. Pull over for 20 minutes and you're good for another 15. Some people have had luck by repacking the joint. It did solve my issue for a week, but I think I got there too late and the damage is done. I re-repacked mine today, if that doesn't take care of it, time for a new axle. Anyway, if you want to repack the CV joint, you'll need a 4" clamp, and 1 3/4" clamp I think and about 6 oz. of CV grease...most just use a high quality bearing grease if you can't find it. Cut the clamps off, slide the boot back and watch the old grease just pour out. Clean it as best as you can and then pack the new grease as far in as possible. Oh, get a box of disposable gloves, it's a messy job. Only takes 20 minutes though. Good luck.
Topshelf is offline   Reply With Quote
Old 03-24-2008, 05:44 PM   #8
lilstevo900k
My Ride: 2001 330xi
visually inspected the boots and did an ever so precise once over with my hand, looks fine.
ive had a similar problem on a very dissimilar thing (dirtbike).
engine mount?
Old 03-24-2008, 08:38 PM   #9
Colin Hughes
My Ride: 1999 323i, 1991 E30
xi vibration
Could be the front drive shafts. We have a 2002 325xi and had a major shake on acceleration, let off on the gas it was fine. There was a lot of play where the shaft meets the cv joint. Found a place on Ebay (FP Groton?)that sells complete drive shafts with a lifetime warranty for under $200 each. Dropped two new shafts in and the car drives like a breeze. Lots of stuff in these forums on x'ers vibrations.
Colin Hughes is offline   Reply With Quote
Old 03-27-2008, 01:26 PM   #10
jodiannsb
My Ride: BMW 2001 BMW 330I
Let me tell you what happened to ours...same issue.. Replaced rack and pinion, then power steering pump, then new tires, then had it aligned. STILL NO LUCK...finally noticed that the right brake caliper seemed to be sticking, bought and replaced it and noticed the rotor was warped. ALL FINE NOW. I was told to replace the Control Arm, but we sent those back and got our money back, as the caliper has solved the problem....GOOD LUCK TO YOU,,,,It is a known issue.....and everyone has a different opinion, however ours worked!!!!!
jodiannsb is offline   Reply With Quote
