Old 05-12-2002, 12:16 PM   #1
HooKdUpBeAmEr
My Ride: 2000 323i
Send a message via AIM to HooKdUpBeAmEr
Brake Calipers
Anyone know anything about painting your brake calipers?? Like what paint is used and where it can be done. Also How much is it?
HooKdUpBeAmEr is offline   Reply With Quote
Old 05-12-2002, 12:41 PM   #2
hamann99
X-Hamann99
My Ride: 323i->350Z->87 325is
Send a message via AIM to hamann99
YOu can actuallydo it yourself. You would want to get high heat temp paint paint.
Here's what you'll need, I'd recommend buying a bottle of CRC brake cleaning fluid, paint brush, a small lil pan or some sort to hold the paint in. The choice of color is yours to pick, but make sure to it's high heat resistance paint or engine paint.
Take a wire brush and some brake fluid and squirt it on the caliper and clean it really good and then take a cotton cloth and make sure all the fluid are clean so the paint will cling on good
Now basically take the wheels off, if you want, cover all the unwanted areas that dont' need to be painted with newspaper and make sure it's covered or you can just do what I did, spray the paint on teh brush and brush it onto the caliper itself, don't put too much cause it'll drip. Wait every 10 min before the next coat, usually I do 4 coats, and you should be fine from there.
Let your car rest for a day and you can start driving.
Any fool can drive in a straight line
hamann99 is offline   Reply With Quote
Old 05-12-2002, 01:40 PM   #3
ky!
My Ride: awhiteysedan
High heat temp paint is also what I used on my calipers. Went with black for that cleaner look on my 328i. It's been over a year now and paint is holding up fine.
ky! is offline   Reply With Quote
Old 05-12-2002, 03:55 PM   #4
HooKdUpBeAmEr
My Ride: 2000 323i
Aight thanks.. any recommendations on color? My car is black and lights/clears are smoked and putting on Hamann black grill. I dont want anything to loud. black? gray?
Old 05-12-2002, 05:00 PM   #5
bmw performance
My Ride: getting a 330 ci
paint the calipers either black or red.... if u want it to look pimp
bmw performance is offline   Reply With Quote
Old 05-12-2002, 05:20 PM   #6
SohJai
My Ride: 2000 323Ci
Send a message via ICQ to SohJai
I like them red! matches most colours too.. black isn't that really noticable.. yellow is a good choice as well..
SohJai is offline   Reply With Quote
Old 05-12-2002, 05:33 PM   #7
BMW328i2000
[name here]
BMW328i2000's Avatar
My Ride: 2000 BMW 328i
I went to the local auto store and got some high temp spray paint. It worked just fine. Just be sure to tape off very well.
Name:	painted caliper.jpg
2000 328i
BMW328i2000 is offline   Reply With Quote
