Old 05-12-2002, 03:25 PM   #1
hamann99
X-Hamann99
My Ride: 323i->350Z->87 325is
Send a message via AIM to hamann99
Tech Question with rotor removal
I don't knwo whatz goin on, I've used a rubber hammer and smacked the crap outta the rotor, won't budge to come off, is there another nut that I need to remove, I've removed the 6mm hex nut that secures the rotor on there, but is the itme in the middle of the rotor of any use to secure the rotor on the hub?????????
Any fool can drive in a straight line
hamann99 is offline   Reply With Quote
Old 05-12-2002, 03:48 PM   #2
MarvelPhx
www.my330i.com
My Ride: E92335i,04ZHP,99M3
Send a message via AIM to MarvelPhx
You just have lots of rust. The nut in the center is to remove the entire hub (which you don't need to do).
Try spraying some penetrating oil in the joint between the rotor and hub and keep whacking away... it will eventually come off.
MarvelPhx is offline   Reply With Quote
Old 05-12-2002, 04:12 PM   #3
roundel3er
My Ride: 05 e46 M3
I see your jack stand behind the rotor and that you aren't using the jack points in front of the rear wheels. What point on the car is the jack stand supporting?
roundel3er is offline   Reply With Quote
Old 05-12-2002, 04:21 PM   #4
mmmpowr
My Ride: '01 M3, '04 R1
Is your parking brake set?
That looks like the rear rotor. The rear rotor uses a drum brake setup. If it is disengaged, all you need to do is tap the backside of the rotor with a rubber mallet and it should pop off.
mmmpowr is offline   Reply With Quote
Old 05-12-2002, 04:38 PM   #5
hamann99
X-Hamann99
The rotor is off now due to a friendly advise from a buddy of mine. It was the ebrake.
Now as for your question the jack stand behind the wheel si to hold my caliper up so it won't put pressure on the brake line. I'm using the stock jack pointin the rear. I would use the differential, but the problem is that my dual exhaust pipings are in the way and there's no way I could jack it up. I have to do one wheel at a time, trust me I've tried the idea of blocks, but the pipings won't allow me to work with it.
