Old 01-18-2003, 12:37 PM   #1
thekubiaks
My Ride: 2001 330i
Help please - ESS and air duct
I recently installed the ESS Supercharger in my 2001 330i... By design, the K&N Air filter goes down in the air space under the driver side headlight. The problem with this area is no airflow. Sure, it can suck in engine space air but, it needs a good positive pressure from an outside source for better flow. Marvelphx suggested that I replace the panel under the driver side fog light with these factory air ducts PN 51 11 7 890 095 & 51 11 7 890 096. I did so and had them painted to my car color. The problem is, the airflow problem is solved but I am concerned that rain will overwhelm the K&N and saturate it. What do you guys think, Is there a way to get the airflow without water ingestion?? Thanks.
thekubiaks is offline   Reply With Quote
Old 01-18-2003, 12:38 PM   #2
thekubiaks
My Ride: 2001 330i
I can't figure out how to post a picture, I searched the FAQ but no luck, any help would be appreciated. A picture of my airduct is at
http://home.insightbb.com/~thekubiaks/airduct/
thx
2001 330i, BLK/BLK 5SPD, PP,SP,HK,Xenon, ESS TX2 S/C, PSS9, UUC Sways, Brembo CD, SS Lines, Hawk HPS, M3 Wheel, VDO Gauges, Dynojet Widebandcommander, Pioneer XM, Alpine CHA-S634, M-Tech 2
Old 01-18-2003, 02:55 PM   #3
Clem
Alpha Male
Clem's Avatar
My Ride: Twin Turbo'd Beast
Thanks approximately where my Dinan filter is. I've had no problems thus far.
Clem is offline   Reply With Quote
Old 01-18-2003, 02:56 PM   #4
Clem
Alpha Male
Clem's Avatar
close up
Old 01-19-2003, 12:23 AM   #5
BobbyBimmer
My Ride: 2003 325i
I've been running the ess on my 00 323i for two years in norcal ,humboldt county, we get alot of rain and i've had no problems at all running with it set up the same as yours. Obviously you want to avoid going through any water deep enough to submerge the filter, but other than that an SC will actually perform better with a little moisture as you will be introducing a denser charge of air to the sc. I already ordered an ess for my 03 325i sedan(but i wont put it on til I get 10k on the engine and get the first dealer warranty service out of the way)
BobbyBimmer is offline   Reply With Quote
