Old 01-18-2003, 04:42 PM   #1
Dev
PSHOPWERKS
My Ride: Yellow Porsche GT2
Pedal Installation
Ok...I just have a question about the accelerator pedal. How in the world can you get to the back of the pedal to install the washer and nut?
Holes are drilled, but accessibility to the back portion of the pedal is like [almost] impossible!!! I've got small hands and yet it's still so difficult to get back there. Ok...is there a way to take the plastic accelerator pedal piece out entirely and install it that way? Or must you reach back there and somehow miraculously get the washer and nut to lock in place?
Any tips, suggestions, etc. on how to make this process easier? I mean...drilling the brake (metal) pedal was easier than this!!!
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers)
Current Hate Level: 10 | Previous Hate Level: 9
The hatin' level on the E46Fanatics.com board.
Dev is offline   Reply With Quote
Old 01-18-2003, 04:46 PM   #2
GarrettF
needs a new sig...
GarrettF's Avatar
My Ride: '02 330Ci
Send a message via AIM to GarrettF
umm..i had this problem today..what i did is drill the holes on the pedal smaller then the screw and used a little force to get them thru..then i didnt even need the nuts because the screws held it in place tight enough maybe ill put a little sealent on the back of the screws later for good measure!
[LEFT]
CAR IS GONE
GarrettF is offline   Reply With Quote
Old 01-18-2003, 04:48 PM   #3
beauport
My Ride: 02 330Ci Steel Gray
Re: Pedal Installation
It isn't easy, but a good set of needle nose pliers will make it a bit easier. Slip on the washer, hold it with a finger, have the nut in the tip of the needle nose pliers and place it over the bolt, carefully tighten from the Front.
beauport is offline   Reply With Quote
Old 01-18-2003, 05:22 PM   #4
Yellowmann
Rolling on Dubs. Got Boost?
My Ride: AA SC Y2K 323i
Send a message via AIM to Yellowmann
The gas pedal is easiest to do. Just take that off and then u have lots of room to work on it. I just pop the bottom tap at the back where its fasten to the floor and pull it up. Then flip up that piece to almost where it touch the bottom of das. It should slid to the left side and its off. I got the OEM one from Circle BMW and they also gave me new one to mount the aluminum peds to it... didnt know why since I thought I could just use existing one.
Once A Yellowmann, Always A Yellowmann ...One Who Is Wise - Always Learn From Other People's Mistakes ...One Who Thinks That They Can Never Be Successful - Will Never Be Successful ...First You Don't Succeed - Try, Try Again ...
Yellowmann is offline   Reply With Quote
Old 01-18-2003, 05:41 PM   #5
Dev
PSHOPWERKS
Wait...you're saying that the accelerator pedal is fastened to the floor (carpet)? Is it a snap on type? Or is it screw/bolted on? Interesting. If that works, that would make it much easier to install.
PSHOPWERKS
Old 01-18-2003, 05:45 PM   #6
Yellowmann
Yes its very easy to do... if you look at it the top is the main part and the bottom is just to hold the pedal in place. IM me on aol Yellowmann. If you have questions.
Old 01-18-2003, 06:31 PM   #7
Dev
PSHOPWERKS
I can see at the bottom (back of pedal) that there is a lever/latch. I have been able to unlatched the lever from the pedal by pushing it away from the pedal. However the pedal still won't budge as I try to move it. What am I missing here?
PSHOPWERKS
