Old 04-02-2008, 08:30 PM   #1
jerseyrider
My Ride: 2001 330Ci-06 K1200s
Help. Smoked turn signals don't fit.
I just got my new smoked turn signals from JLeviSW, and they don't seem to fit right. It seems like they don't go al the way in and click. After pushing them in as far as I could I was still able to pull them out without depressing the tab. Also, they don't seem to fit well to the headlights. Does anyone have any advice? I want to put them on because they look great on my sapphire black 330ci. Thanks.
jerseyrider is offline   Reply With Quote
Old 04-02-2008, 08:32 PM   #2
k7780446
My Ride: 323i
you sure you need clip in and not screw in?
k7780446 is offline   Reply With Quote
Old 04-02-2008, 08:40 PM   #3
jerseyrider
Yeah the mounts are exactly the same as the factory ones. The new ones seem to have more rubber weatherstripping on them than the originals, though.
Old 04-02-2008, 08:51 PM   #4
negative330ci
negative330ci's Avatar
My Ride: '92 Camaro.
Send a message via MSN to negative330ci Send a message via Yahoo to negative330ci
I had the same problem with mine. If you loosen the two bolts on top of the headlight assembly, just so it is loose to be able to move it, you can clip them in and then tighten the headlight back. I was told that because the weatherstripping is thicker they just wont go all the way in without loosening the lights.
Worked like a charm. Could not do it without loosening the light.
"See how I blend in with nothing?"
negative330ci is offline   Reply With Quote
Old 04-03-2008, 12:03 AM   #5
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
That's just it, loosen the top two bolts and slide it in. They are designed with a tighter fit to prevent condensation and have them sit in tighter. The OEM corners tended to fall out over time so these are designed to combat that problem.
Old 04-03-2008, 09:40 AM   #6
jerseyrider
Thanks guys. I'll try it this afternoon.
Old 04-03-2008, 11:02 AM   #7
jerseyrider
By the way Nick, great job on the shipping and product. This is my second order from JleviSW and everything was great. Shipped in 2-3 days and the products arrived in perfect condition. I can't wait to get them in.
Ed
Old 04-03-2008, 01:41 PM   #8
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
Good advice.
Old 04-03-2008, 04:27 PM   #9
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Ed
Ed,
Our pleasure, glad you enjoy them!
Old 04-06-2008, 11:04 PM   #10
jerseyrider
Just a note. Today I installed my smoked turn signals as per Nick's and negative330ci's instructions. Not only do they fit well but they look great. I'll post pics soon. Thanks guys.
Old 04-06-2008, 11:05 PM   #11
jerseyrider
By the way, Nick. Is your website still down?
Old 04-07-2008, 12:04 AM   #12
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Yes sir: Jlevi SW | Website is BACK!- Faster High Capacity Server!
Old 04-23-2008, 09:17 PM   #13
jerseyrider
Thumbs Up Finally some pics
I really like the way that smoked lenses look on a dark car. My car is Sapphire black. I also put in LED license plate bulbs. Everything is from JLeviSW. Thanks, Nick. I'll be installing some smoked LED tails soon and painted reflectors. Who knows what's next?
By the way, my rotors are a bit rusty bcause I just finished washing the car.
ID:	268515   Click image for larger version
ID:	268516   Click image for larger version
ID:	268517   Click image for larger version
Old 04-23-2008, 11:05 PM   #14
Jabboure36
My Ride: 03 540i/6
Send a message via AIM to Jabboure36
look cool man..glad they worked out for ya
Jabboure36 is offline   Reply With Quote
Old 04-23-2008, 11:59 PM   #15
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Looking good!
Old 04-24-2008, 02:23 AM   #16
weisiong123
My Ride: 323ci
Do they fit perfectly now or what? Mine is still sticking out at the 2 sharp edges..sigh
weisiong123 is offline   Reply With Quote
Old 04-24-2008, 11:16 AM   #17
umnitza
8774866489
umnitza's Avatar
Seems like you are having nothing but issues with your setup weisiong
Old 04-24-2008, 11:36 AM   #18
weisiong123
My Ride: 323ci
The lights seems to work okay..just the corner problem and light out problem. Others can fit it but I don't know why mine can't..some people just let it be even tho its sticking out a little..Even if I get corners from you its still DEPO right?
Old 04-24-2008, 02:47 PM   #19
jerseyrider
To weisiong123;
Everything fits perfectly now, even better than OEM. I followed the instructions from everyone above and it worked out well. The front turn signals were an extremely tight fit but eventually I felt and heard the click when they locked in. Make sure you loosen up the two screws on top of the headlight assembly and you'll have to finesse the turn signal in to lock them in. They do have more weatherstripping than the factory ones. Don't be afraid to use some force but not too much. So far, I ordered all my lighting from JLeviSW and couldn't be happier.
Old 04-24-2008, 03:16 PM   #20
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Yep, both Umnitza and Jlevi SW carry DEPO
