#1 |
1st FULL '02 ACS 330i
How do you know if you have a bad strut
After dropping my car on UUC v.2 springs my front passenger side strut sounds like it is phucked up. It goes clunk, clunk, clunk when going over bumps at slow speeds. The sound is not the springs rubbing on anything. It sounds like the strut is bottoming out. My girlfriend figured out that I messed with the suspension of the car with all the rattling under the car.
I haven't got an allignment yet, but I do have an appointment. Do you think an allignment would fix that sound or is front strut phucked? My car sounds like it is 20 years old. If this persists I will put my OEM springs back in.
#2 |
booo for body roll.
My Ride: 2009 335i.
um u can try pushing down on the side of the car where u think it has a bad strut/shock, and after u push it and it continues to bounce they're blown.
#3 |
Banned
Location: Im from where the hammers rung, news cameras never come, throw the work in the can and scream "runnn"
My Ride: Hamann 3
you should have stuck with H&R or Eibach.... Return them if the problem persists
#4 |
PSHOPWERKS
My Ride: Yellow Porsche GT2
Mine clunked for awhile. I tightened the top again and it solved my problems (when I had my earlier suspension setup, not my current).
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers) Current Hate Level: 10 | Previous Hate Level: 9 The hatin' level on the E46Fanatics.com board. |
#5 |
NWT Fanatic
My Ride: M3
Is the spring properly aligned with the boot on the strut?
#6 |
I just phuckin' cranked the car's steering wheel all the way to the side...and the freakin' bolt the the sway bar link is on the last thread.
I gotta run out and get a socket set. See ya in a bit.
#7 |
NWT Fanatic
My Ride: M3
damn. Hope you arent taking the car
#8 |
FIXED THE MOFO PROBLEM
The bolt was so fricken' loose that I could unscrew with ONE not two fingers. Cranked that sucker on there tight and went for a test drive. Sounded OEM to me. PHEWWWWWWW Problem solved. Drove it over speed bumps, pot holes, dips, bumps, & a valley...no clunk whatsoever. to the DIY gods
#9 | |
#10 |
Addicted to Torque!
Damn....Im getting the same sound on my PSS9's coming from the same side. Ill check my sway bar tomm!!!! THANKS!
Current Rides:
2008 M3 Vert - 6 Speed 2011 335d MSport My VehicleHistory 2008 VW R32 2006 Misubishi Lancer Evolution IX SE 1999 328is Lease Return :-) 2002 325ci AA Supercharged SOLD 2003 330i ZHP SOLD 1997 M3 Sedan FOR SALE! Wifeys VW History 2001 VW New Beetle GLS Turbo [1.8t - 5 speed - BBS RXII's] SOLD 2007 VW GTI [DSG] - SOLD 2009 VW Tiguan S - "Babymobile" |
#11 | |
