Old 07-26-2015, 03:07 AM   #1
Pigyed
My Ride: 318i Touring
Stuck !! Need Help !!
Hi all,
Hopefully someone can help me out with the problem I am having:
Basically, I can start and drive my car (E46 2003 318i touring) then at a random point the car just dies, the EML, ASL, Battery & Oil light come on and the car can't be restarted once it has died, it turns over but won't fire up.
The battery is reading 12.5v with key turned. If i leave the car for ages it will start again but if I drive it the same problem happens, battery reads 14.3v whilst idling and hold it with blowers, wipers, lights, fogs etc on.
I have checked the throttle body and it looks spotlessly clean and moves easily enough.
Sadly I don't have a code reader to identify any fault codes.
Does anyone have any idea what could be causing this?
When i turn the key to position 2, the throttle body makes a long beep noise, then a rattling sound....could it be that the throttle body is faulty?
How would i know if the throttle position sensor is faulty?
i have changed the camshaft sensor as it was suggested that this could be an issue but it still happens. should i change the crankshaft sensor ?
The car has plenty of fuel & oil
Sorry for such a long post.
Pigyed is offline   Reply With Quote
Old 07-27-2015, 11:39 AM   #2
JVLux281
My Ride: 325i
Check voltage of alternator
JVLux281 is offline   Reply With Quote
Old 07-28-2015, 07:16 PM   #3
Pigyed
Thanks for the tip...sorry to appear dumb but how would I go about doing that and what am I looking for to indicate a problem or not with it?
