Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 04-06-2008, 01:03 PM   #1
dazhit
My Ride: bmw 318se
airbag light stays on what are the common faults how to fix
hi all i am having problems with the air bag light it was flashing on and off i disconnected the wires under the the seats and reconnected as advised buy the local garage now the light is on all the time do anyone have any helpful advice many thanks darrenh
dazhit is offline   Reply With Quote
Old 04-06-2008, 01:38 PM   #2
kobus
My Ride: e46 323i 1999
Mine's also on (passenger seat) when they clear it it stays off till someone sits there then it's on again. BMW wants to change the sensor and hopefully it's not the one inside the seat cause hell knows how you gonna take it out, undo the stitching.
kobus is offline   Reply With Quote
Old 04-06-2008, 01:48 PM   #3
Cobra
My Ride: '00 328i & '06 R6S
it could also be the seatbelt tensioner. my airbag light is on because the drivers seatbelt tensioner needs to be replaced.
Cobra is offline   Reply With Quote
Old 04-06-2008, 02:34 PM   #4
mbrain
My Ride: 325i Sport 2003
It will most probably be the passenger occupancy mat. These aren't cheap to fix, probably around 70 for the mat plus fitting, which is a bit tricky. I recently bought a plug from ebay for 45 that fools the car into thinking that someone is always sat in the seat, and thus rectifying the airbag light coming on.
mbrain is offline   Reply With Quote
Old 04-06-2008, 03:50 PM   #5
///Mechanic
My Ride: None currently
Lots of common problems, just go fix the damn thing and don't throw parts at it like your typical forum jackass.
YOU BOUGHT A BMW, IF YOU CANT AFFORD TO MAINTAIN IT............SELL IT.
///Mechanic is offline   Reply With Quote
Old 04-06-2008, 03:51 PM   #6
mdon
My Ride: 325i
mine is faulty passenger seatbeat connection!!
donno wtf is that.. but just go find a dealer they can clear that code for you!!
mdon is offline   Reply With Quote
Old 04-06-2008, 04:01 PM   #7
JoeyBoy
My Ride: 330Ci
I just got mine fixed this past week..it was the seatbelt tensioner..it was like 330 or so from the dealer..took about an hour and 1/2 to fix and the part was about 140 or so if I remember correctly..I'd say take it somewhere there's plenty of things to go wrong..I never wouldv'e thought a seatbelt would cause an issue with an airbag
JoeyBoy is offline   Reply With Quote
Old 04-06-2008, 08:59 PM   #8
tko200
My Ride: 01, 325i
Things that cause airbag light to be on
Seatbelt tensioner
Occupancy Mat
Seat sensor
Faulty Airbag or wiring
disconnect your seat plugs without disconnect your battery first
tko200 is offline   Reply With Quote
Old 04-06-2008, 10:26 PM   #9
cornbob
My Ride: 323i
Does it matter if the air bag light is on other than it's annoying? Will the airbag not work?
cornbob is offline   Reply With Quote
Old 04-07-2008, 09:18 PM   #10
pns0ccc
My Ride: 03 325i & 07 335
I'm told this disables the airbag, (according to my indy mechanic). Anyone else heard differently? Cost to repair at independent is $295.00 for Occupancy Mat replacement.
pns0ccc is offline   Reply With Quote
Old 04-07-2008, 09:46 PM   #11
ken@bimmertools
Is NOT A Mechanic
ken@bimmertools's Avatar
My Ride: F30
Stop guessing. Without reading the fault codes, you are wasting your time. Dealer, indy shop with proper equipment, or our Peake Research R5-SRS tool. All those options will cost about the same.
See our selection - www.bmwscantools.com.
ken@bimmertools.com
Ken
Bimmertools is under new ownership! Please welcome Taylor@bimmertools.com.
Click Here to say hi.
ken@bimmertools is offline   Reply With Quote
Old 04-21-2008, 10:56 AM   #12
audiphile
My Ride: 2008GTI 1993Corrado
My mom's seat belt tensioner, driver side, is the code that keeps coming back. I just want to make sure I'm ordering the right part - is it the seat belt buckle with the pre-tensioner module that's the culprit?
thanks in advance.
audiphile is offline   Reply With Quote
Old 04-21-2008, 11:30 AM   #13
K:^P
My Ride: 00 323//65 Fastback
Black electric tape over the light.
Allll fixed....Homer Simpson
K:^P is offline   Reply With Quote
Old 11-04-2008, 07:45 PM   #14
240sxplan
My Ride: 328I
Yeah.. black electric tape over the light... heheheh.. that is the cheapest way to go.. This is the best suggestion I have seen....
thanks..
240sxplan is offline   Reply With Quote
Old 11-04-2008, 08:04 PM   #15
x13atma17x
x13atma17x's Avatar
My Ride: E46 323i & MK6 Jetta
BMW dealer told me that the airbag will still work, he urge me to get it fix tho (SRS LIGHT, REPLACE SEAT MAT SENSOR $ 635.00) for $295.00 ...i'll get it fixed bro
-omar-
x13atma17x is offline   Reply With Quote
Old 06-01-2011, 08:44 AM   #16
fiftybuks
My Ride: bmw 328i
1997 bmw 328i
I Have a 1997 BMW 328i conv. Airbag light stays on all the time. I have fault codes 16, 17, & 25, I was wondering if it could be in the wiring for both seat belt sensors & passenger oss to be bad. Thank you in advance
fiftybuks is offline   Reply With Quote
Old 06-01-2011, 07:06 PM   #17
mad_polo
My Ride: E46 320
I had a problem with the occupancy sensor...
mad_polo is offline   Reply With Quote
Old 02-04-2012, 05:43 AM   #18
CrazyOneToo
My Ride: 1999 328i 4dr
ken@bimmertools.com
Ken
Does the Peake reset tool tell you where the problem is exactly???
1999 328i E46 with a M52TU - 2002 X5 E53 3.0i with a M54
ECSTuning.com/ - AutohausAZ.com/ - XOutPost.com/
CrazyOneToo is offline   Reply With Quote
Old 12-04-2012, 02:32 PM   #19
CrazyOneToo
thanks..
The previous owner of my car went a little further and removed the instrument cluster
and covered the light with black silicon.
I finally got it all dug out but now I get to look at the airbag light til I get mine
changed out. Its on order tho.
Old 03-13-2013, 12:07 PM   #20
ChampionC
My Ride: 318Ci Convertible
I've suddenly got an Airbag light. I was cutting away carpet under the ashtray but I've nicked a wire in there. When I rejoin the cable, will it reset itself or will it stay on because it has been triggered and will only go off once reset with a tool ?
Regards
C
ChampionC is offline   Reply With Quote
