Old 04-09-2008, 11:43 AM   #1
Zero2_2005
My Ride: 328i
Misfire still when coil and plug is switched
I have this problem and it has been driving me nuts lately. I have a misfire in cylinder 4 and did the spark plug and coil+boot swap but it still misfires. I tried to do the swap again and this time with a Peake tool to reset the computer. The check engine light deosn't come on but the code is still stored within the ECU when read with the tool. The car does idle a little rough but when the rpm needle jumps and the car starts to get really rough idling, the check engine light comes on. This is really bothering me and would like to fix it
Zero2_2005 is offline   Reply With Quote
Old 04-09-2008, 12:36 PM   #2
Ebob
My Ride: 99 323I
Check idle control valve, intake/exhaust camshaft sensors.
Mine was fixed after I replaced all 6 spark plugs .
Ebob is offline   Reply With Quote
Old 04-09-2008, 02:54 PM   #3
Zero2_2005
My Ride: 328i
I had all that done about a year ago. New throttle body and both cam sensor replaced. I really don't know whats going on.
Old 04-09-2008, 03:08 PM   #4
elite53
My Ride: Twin Screwed 325Ci
If everything is checking out ok on the ignition side I wonder if it could be a clogged injector? Just a thought.
elite53 is offline   Reply With Quote
Old 04-09-2008, 04:41 PM   #5
mechanic_101
My Ride: 2005 325I
could be a bad piston rings too.
do a compression check on the cyl.
mechanic_101 is offline   Reply With Quote
Old 04-09-2008, 10:41 PM   #6
Zero2_2005
My Ride: 328i
Thanks. I'm afraid I would need to take it to the shop unless somebody could give me some pointers on how sort out my kind of problem.
Old 04-09-2008, 11:27 PM   #7
mechanic_101
My Ride: 2005 325I
run the car for few minutes and remove few plugs and do a comparison. Look at the end to see whether it's wet compare to other cylinders. do the compression check on that cyl. if it's ok, then use the fuel injector to add to fuel tank. I have heard many cases the injectors clogged, stuck open or stuck closed causing misfiring. These are simple steps you can do before take it to the stealership.
Old 04-10-2008, 05:54 AM   #8
ToddInLou
My Ride: 2001 330CiC
If you have changed your coils around and you are still getting a misfire on the same cylinder my bet is you need a new fuel injector. Keep us posted
Todd
ToddInLou is offline   Reply With Quote
Old 04-10-2008, 08:41 AM   #9
Brian15
My Ride: 2001 330c.i
if you think its the injectors , swap the injectors between cylinders and see if the missfire changes cylinders .
Brian15 is offline   Reply With Quote
Old 04-10-2008, 01:55 PM   #10
Zero2_2005
My Ride: 328i
Right now I am running some fuel system cleaner that will help clean the engine, the fuel injectors, the fuel system, and the valves and pistons. My car has been running on this stuff for about 3 days now and the engine check light just cleared up today. Hopefully it won't come back on but the thing is I would have to do a code check to see if the misfire is still stored within the ECU. I check back later on that.
Old 04-10-2008, 05:34 PM   #11
mechanic_101
My Ride: 2005 325I
you can use injector cleaner, but do not over use it. additives in there could harm your fuel pump and other components.
Old 04-20-2008, 11:28 PM   #12
Zero2_2005
My Ride: 328i
By the way, is there a DIY for swapping a feul injector cause I'd like to try that before going into the shop.
Old 06-02-2008, 05:55 AM   #13
doc5
My Ride: 2002 325 xi
i have the same problem right now.shop ran a scan on it and told me its the in line fuel filter and a faulty air mass sensor
doc5 is offline   Reply With Quote
Old 04-26-2009, 02:11 PM   #14
Zero2_2005
My Ride: 328i
Hey guys!! Been long time. I think I may have figured out the problem. At first you guys said that it may be the fuel injectors but when I went to take out the spark plug in cylinder 4, I saw some moter oil on the plug and where the plug attaches. I was figuring out, " wait, what if it could be a valve cover gasket?" I just want to know if I am correct on this. Any input would be great. I don't know if the oil is really causing the misfire but I will see after inputs. I know it only costs at least $50 to fix with a DIY. Thanks ahead of time!!!!!
Old 04-26-2009, 02:43 PM   #15
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
valve ocver gaskets shouldnt effect the idle
when my x5 plugs were soaked in oil due to the gasket seal leak on the 4.4 with new plgs it was still idled great.
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 04-26-2009, 02:54 PM   #16
jc323ci
My Ride: 2000 323 ci
definitely check the injectors
- Jordan
Nothing special but i love it!!
jc323ci is offline   Reply With Quote
Old 04-26-2009, 05:39 PM   #17
edsel12
My Ride: 325i, infiniti g35
what spark plugs are you using?
same problem here with bosch +4 spark plugs...
replaced it with ngk iridium and my car runs better now and
no more cel....)
edsel12 is offline   Reply With Quote
Old 04-26-2009, 09:16 PM   #18
iansanderson
a leaky valve cover gasket could cause a misfire
iansanderson is offline   Reply With Quote
Old 04-27-2009, 11:35 AM   #19
Zero2_2005
My Ride: 328i
Well I looked down the cylinder with the spark plug removed and I saw some dark black carbon build up in there. Could this be bad? Also there was oil in the plug. Wet plug I guess. I am going to replace the gasket for sure cause there is oil residue on some parts of the engine.
Old 04-27-2009, 11:36 AM   #20
Zero2_2005
My Ride: 328i
You with new plug though but could oil seep throught the plug's gasket or washers?
