Sponsored by BAVSOUND
Old 04-13-2008, 07:53 PM   #1
gaby1088
My Ride: 993
adding subwoofer
hi, if i want to add a subwoofer to the existing HK system how would i go about doing that. I searched and couldnt find a straight answer. How can i add a second subwoofer, (8inches) to my existing HK system? please help!
thanks
Pictures by boligrafo123 & ///OSS
gaby1088 is offline   Reply With Quote
Old 04-13-2008, 08:39 PM   #2
330CK
My Ride: > your ride
Purchase a line output converter, tap into the wires going to the existing HK subs, run the RCAs from the LOC to an amp, and and the wires from the amp to the sub. use the low pass filter on the amp to tweak.
330CK is offline   Reply With Quote
Old 04-13-2008, 08:43 PM   #3
gaby1088
My Ride: 993
and i can still use my HK subs? also can i control the subwoofer from the radio? as if it were stock.?
Old 04-13-2008, 10:42 PM   #4
albarran9
My Ride: E46, E53, E90
yes you can as long as you "T" into your wires bsw has a great vid on youtube that shows how to do it or look up the instructions on their website which have pictures and will walk you step by step, which is what I did.
albarran9 is offline   Reply With Quote
Old 04-14-2008, 08:03 AM   #5
gaby1088
My Ride: 993
cool thanks, as far as sound, since i plan on using the HK ones too, should i just go with an 8inch polk RMS't at 200watts and a 200 watt amp?
Old 04-14-2008, 06:57 PM   #6
albarran9
depends on how you like your music and what genre you listen to. every one likes there coffee different just like every one likes their bass differently. I'v got a fi audio q which dose 1000 wrms and i usually run it at 400 wrms when i listen to rock and then turn it up when i play techno or hip hop for stronger bass lines. I always like to have enough power to run the sub at its full rms rating so that i can run it as hard or as easy as i need to. but in the end its up to you
Old 04-16-2008, 09:31 AM   #7
gaby1088
My Ride: 993
so how do i connect the amp to the battery, wont i need a remote power wire to tell the amp to turn off and on?
Old 04-16-2008, 09:53 AM   #8
Paul W @ BSW
Past Site Sponsor
My Ride: Dauer EB110
I wouldn't recommend tapping onto the crossed-over signal going to the HK subs, when you can just as easily get a clean full range signal going from you head-unit to your OEM amplifier. Here's are D210.e46 Subwoofer System Install Guide, you can use this guide for any subwoofer system install, just apply the directions to your setup.
I hope this helps and feel free to contact me if you have any other questions.
Paul W @ BSW is offline   Reply With Quote
Old 04-16-2008, 10:53 AM   #9
gaby1088
My Ride: 993
thanks i really appreciate it, i just want to keep the HK speakers running as well, i would love to buy the BSW but i have a great deal on sub and amp combo off amazon
Old 04-16-2008, 01:27 PM   #10
Paul W @ BSW
Past Site Sponsor
You can still keep the HK subs and add your own aftermarket sub system by following the install guide I linked to. You're just tapping onto the audio system signals and not terminating them.
Old 04-16-2008, 09:44 PM   #11
oppa637
My Ride: 03 CB M3
What combo on amazon?
oppa637 is offline   Reply With Quote
Old 04-16-2008, 09:57 PM   #12
gaby1088
My Ride: 993
POLK/MOMO 8 inch $45 and off ebay (local seller) $60 for 400 RMS JL amp
Old 12-19-2012, 08:21 PM   #13
Johnson023
Banned User
My Ride: SDF
I would adjust it for optimum gain (max power without distortion), then turn it down if you have to. As far as getting damaged, it's just like an engine.
Johnson023 is offline   Reply With Quote
Old 12-19-2012, 08:37 PM   #14
SB_RavenE46
My Ride: 330CI ,06 R6, S1000
Send a message via Yahoo to SB_RavenE46
This is what you need it's the best LOC ever
Buy this from me it's mint condition
http://forum.e46fanatics.com/showthread.php?t=961367
M0ney = P0w3r "THEN" I = A G3nerat0r
SB_RavenE46 is offline   Reply With Quote
Old 12-26-2012, 04:42 AM   #15
SB_RavenE46
Change your mind ?
Old 01-02-2013, 04:38 PM   #16
gaby1088
My Ride: 993
Originally Posted by SB_RavenE46 View Post
Change your mind ?
lol, this was a long time ago before i installed this..
