#1 |
I have xenon headlights and they are flickering. When they flicker it is both of them, not just one side so that leads me to look somewhere other than a ballast. It is like they turn off and back on in a blink of the eye. If anybody has any insight it would be greatly appreciated.
Thanks |
#2 |
Hmmm, maybe the LCM is going bad?
![]() Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya. |
#3 |
what does lcm stand for
#4 |
LCM: Lighting Control Module
#5 |
This is happening to me also. I am getting a rear passenger bulb out warning. I replaced all rear bulbs still getting bulb out and flickering. How many thousand is the LCM going to cost me??
#6 |
I finally fixed mine!! Cost??? Just a little time and some wire. Sorry no pictures.
The basic problem bad ground. Were you getting a bulb out warning?? |
#7 |
mine flashes time to time, gets on my nerves. I dont have a bulb light flashing out though...I'm thinking ground, but figured i'd get around to it when I change my icv and oil..
#8 |
#9 |
#10 |
For the taillight: http://forum.e46fanatics.com/showthread.php?t=512469
#11 | |
Thanks for the help!! |
#12 | |
Maybe this can help your flickering..... HID Anti-Flicker/Bulb Out Resistor Pack Set from EAS for $45... http://www.europeanautosource.com/pr...oducts_id=1579
![]() !!!HOWZIT!!! 19X8.5 M6's, LED Tails, Clear corners/sides markers, BlitzSafe ipod interface with I-Touch, K&N FIPK, more coming soon... |
#13 | |
I think that is just for when you are adding HID lights to a car that didnt have them OEM. Mine and the original posters problem is with original xenons installed and looks to be a ground problem. |
#14 |
I have since replaced both fron bulbs and my lights still flicker. I looked at my tail lamp housing and they are different than the ones that there is a fix mentioned for above. I have a 2000 and that fix is for 2001+. I examined the connectors and they showed no signs of corrosion or burnt connectors. I was hoping maybe someone eles with a pre-01 car might have had this problem and fixed it. Any insight is much appreciated.
#15 | |
I had the same problem, and also have the same housing as you. For me it was as simple as taking each bulb out of the socket in the taillights and putting them back in. Problem solved-no more flicker. Two months later the problem came back. This time I went to autozone and bought new bulbs. ($12 for all six bulbs) Havent had a problem since.......... |
#16 |
My Ride: 325Ci M Clubsport
Flickering lights is a sign your transformer is on the fritz.
I'd suggest getting it looked at, shouldn't cost much to replace.
![]() BMW 325Ci MY2004 Individual //M Clubsport Edition, //M Clubsport package, //M Sport 18"s, Manual //M Short Shift, Carbon Black, Black Aluminium Cube Interior. |
#17 |
I don't know how to fix it, but I know someone that had that same problem and he took it to the dealership and they got fixed for him for about $800
#18 |
it's most likely a ground issue somewhere on your car. probably take it to get diagnosed or something
Have a lighting problem? Read this first: Lighting-related Troubleshooting Guide |
#19 | |
No its not. Flickering lights is a sign of a bad ground, usually in the tail lights. It causes the light control module to keep resetting itself, and this causes the headlights to flicker. |
#20 |
yeah bad ground
YEHMEN
E46 m3 - RIP 06 STI - Sold E36 m3 - Current |
