Old 04-21-2008, 03:56 PM   #1
elliotchong
My Ride: bmw 320i
p46 problem
i have p46's and i am having the hardest time getting the high beam locking ring to lock on to the p46 housing. i hope you all know what i mean. on the oem housing to get the bulb out you need to squeeze the tabs and twist the bulb carrier out. i have yet been able to get the oem bulb carrier to lock onto the p46 housing, the high beam bulbs have just been hanging in there without them being locked. i have tried to turn really heard and i can see the housing moving. i do not want to break anything. has anyone else had this problem?
elliotchong is offline   Reply With Quote
Old 04-21-2008, 08:51 PM   #2
beamin6
My Ride: 2002 325ci
Send a message via AIM to beamin6
oh dude its a ***** i had real hard time gettin mine back in i felt retarded but i eventually got it. i took off the white gasket to make sure i was doing it right then i ended up taking back apart and then i got them to fit
beamin6 is offline   Reply With Quote
Old 04-21-2008, 08:55 PM   #3
M0nk3y
Banned
My Ride: 2002 325xi
The highbeam housings didn't fit the P46s. (The bulb carrier) I swapped out the bulbs, into the bulb carrier supplied with the P46s, and it has worked fine..........
M0nk3y is offline   Reply With Quote
