Old 04-22-2008, 12:28 PM   #1
smellybumlove
My Ride: e46
4.4 V8 conversion
Building a show car for the summer and i have been rattling my brain with what to do.
everybody has a M3 so i decided not to base it on that, everybody has a 330ci with a supercharger so thats out the window also.
but what about a M62 4.4 V8 from the E38/E39 installed in the E46 coupe?
I have found a perfect engine and a good car to base it on (318ci), now what other parts will i need in order for this to be a turn key car?.
when i say turn key i mean it has to be fully functioning like a standard E46, all electronics and aircon working etc.
also i have goggled myself senseless and i cant find anyone who has done this on a E46, some guys have on a E30.
any help will be appreciated!
smellybumlove is offline   Reply With Quote
Old 04-22-2008, 12:43 PM   #2
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
It would be pretty sick, but it'll probably under-steer like a champ. But, if it's a show car, I don't guess that matters.
Old 04-22-2008, 12:44 PM   #3
MasterKzhp
Banned
My Ride: 330i zhp
are you kidding...? that would be awesome... what about a 4.8!? I would love to see the results of a project like this........ good luck!
MasterKzhp is offline   Reply With Quote
Old 04-22-2008, 12:50 PM   #4
Alter Ego
My Ride: 04' 325Ci
Interesting idea but isn't that pretty similar to the idea behind the Hartge?
Alter Ego also knows Where the Buffalo Roam.
Originally Posted by JByron View Post
I want cf condoms so I can shave a few seconds off my time
Alter Ego is offline   Reply With Quote
Old 04-22-2008, 12:56 PM   #5
smellybumlove
My Ride: e46
yes it is but they used a expensive M5 engine and charged stupid money for it!.
i was considering boring it out to 4.6 or installing a stroked crank, but then again nigh on 300bhp with 320ft-lb is enough anyway i think.
and when you say understeer, your refering to maybe the increased weight of the V8?
i have been told its lighter than the M3 engine, so it shouldnt be a problem.
Old 04-22-2008, 12:56 PM   #6
jmueller
My Ride: 2001 330ci
Would be cool, but that iron block V8 isnt exactly light!
jmueller is offline   Reply With Quote
Old 04-22-2008, 12:58 PM   #7
Brandon26pdx
My Ride: Subway
That would be totally badass. Somebody (Hartge?) swapped the 5.0 V8 from an E39 M5 into an E46 M3 a few years ago and I think offered them for sale for some rediculous amount, like over $100k.
I'd bet swapping the 4.4 into a coupe wouldn't be nearly that bad, but I'd guess at least $10k to do it.
Brandon26pdx is offline   Reply With Quote
Old 04-22-2008, 01:35 PM   #8
nleksan
My Ride: 328Ci, 325i, M3 ZCP
Send a message via AIM to nleksan
Understeer would be apparent off throttle, yes.
However, I have a feeling that once you get on the throttle, it's oversteer you'll be worrying about.
(Temporary Sig)
- DPE - Volk - BBS - OE CSL - JRZ Race 4Way -
- M-Tech II - RE - AP Radi-CAL -
- Hotchkis - AFE - AKG - KW CS 4way -
- TMS - OS Giken - SS V1 - Vorsteiner - Recaro - Focal - JL - MORE! -
GARAGE:
-00 328Ci Topaz 6MT ZSP/ZPP/HID (Street) ESS TSE2+ 2980lb
-01 325i TiAg 5MT/ZSP/ZCW (Street) Track Susp/Brk/Whl 3102lb
-06 M3 AW/IR 6MT/ZCP/HID (Dual-purpose) NA Fully-Built 2810lb
nleksan is offline   Reply With Quote
Old 04-22-2008, 01:48 PM   #9
MasterKzhp
Banned
My Ride: 330i zhp
throw it in an E30 m3.. those never get old
Old 04-22-2008, 02:10 PM   #10
david @ eas
Past Site Sponsor
My Ride: E46 M3
Wow... If you try to do this that car would be amazing... I would love to see this done!
david @ eas is offline   Reply With Quote
Old 04-22-2008, 02:29 PM   #11
Albo
My Ride: 325xi
The M62 is actually an Aluminum Block weighing 427lbs.
The S54 is actually an Iron Block...I'm sure the weight can be found on this website, but a google search turned up nothing.
Albo
2002 325xi (Orient Blue) 19" ASA AR-1's w/ 235/35/19 General Exclaim UHP’s-Bilstein Sport Shocks/Struts-H&R Sport Springs–M3 Paddle Shift Steering Wheel–Powerflex LCAB’s & RTAB’s–DEPO Projector Headlights–DEPO Clear Corners–DEPO RCR Taillights- Magnum Cross Drilled Rotors w/ Centric Brake Pads-El Cheapo Front & Rear Strut Tower Bars–SPAL Electric Fan (Clutch Fan Delete)–Aluminum Gauge Rings–Aluminum Pedals–Carbon Fiber Shift Knob
Albo is offline   Reply With Quote
Old 04-22-2008, 03:14 PM   #12
AdamBath
My Ride: E30
so its basically in LS1 territory... if anyone thinks it'll understeer, refer to this post.
AdamBath is offline   Reply With Quote
Old 04-22-2008, 03:47 PM   #13
wolfe
My Ride: 330i
I might be wrong on this, but don't the v8 e39's use a recirculating ball steering box?
That might be an issue swapping it into an e46.
wolfe is offline   Reply With Quote
Old 04-22-2008, 04:06 PM   #14
Albo
My Ride: 325xi
You are correct...E39 and E38 both use RB Steering System due to lack of clearance.
I would imagine in an e46 you would have to adapt that into the engine bay as well, but it looks to have been done before:
http://forum.e46fanatics.com/showthr...ighlight=340ci
Albo
Old 04-22-2008, 11:25 PM   #15
smellybumlove
My Ride: e46
my god, your a smart man, i forgot about that!.
i hate the feel from the wheel on those things........damn, thats a major snag......
need to talk to my enginering guy.
Old 04-22-2008, 11:30 PM   #16
samBROchill330i
My Ride: Dinan 330i
+1
Performance: Dinan Stg 3, Dinan Perf Tranny Software, Dinan High Flow Throttle Body, Dinan High Flow Intake, UUC TSE3~TMS Power Pulleys
Suspension: Eibach Sportlines, Koni Sports, Ground Control RSMs, Dinan Strut Brace, Eibach Sways, Ground Control Endlinks, Poly RTABs
Exterior: Painted Kidney Grille, BSM Roundels, Clear Sides, Corners, & Tails, 3M Tint 20% Rear, 35% Front, Halogen to P46/AE
Wheels: Staggered 19" V710s on T1Rs
samBROchill330i is offline   Reply With Quote
Old 04-23-2008, 01:08 AM   #17
smellybumlove
My Ride: e46
ok so i have a few questions that i need to confirm.
1) what coupe should i use and does it matter, im planning on using a 2000 318ci as its clean and cheap.
2) which M62 should i use, i know there are 3 versions, 4.0 from e34, 4.4 with no vanos (i think), 4.4 with double vanos.
3) do i take the electronics from the E39/E38 car or modify the existing electronics from the E46.
thanks
possible donor car
squeeze this
into here
oh just to let you know, im a british guy living in taiwan, opening up a bmw place here and this is gonna be our car
Old 04-23-2008, 01:47 AM   #18
Chris-TK
My Ride: Mk VI GTI
Do it! Go with the 4.8
K.
Chris-TK is offline   Reply With Quote
Old 04-23-2008, 08:09 AM   #19
328iBMW
My Ride: C320
Do it.
Just curious, but why is there a battery under the hood in that last pic?
What makes you come alive?.........Go do it.
328iBMW is offline   Reply With Quote
Old 04-23-2008, 08:21 AM   #20
JohnBlaze
My Ride: Black Sunshine
Hartge does this
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
