Is there a DIY for Headers?!?!! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-24-2008, 04:36 PM   #1
jetskier88
My Ride: 330i ZHP S/C TS2+
Send a message via AIM to jetskier88
just as the title says... i just got quoted $750 for install and if i had a lift i wondered if i could do this
ESS TS2+ - OEM M3 LSD rear end swap - Meth Injection - Recaros PP - Defi Guages - Dinan TB - Headers&M3 Custom Quad Exhaust - UUC LTW Flywhl - UUC SegKev Clutch - Rogue SSK - KW V2 Coils - H&R Sways - TMS Subfrme&Sway Reinfrcmnt - VMR V710 & M PS2's - Brembo X Rotors and more....
jetskier88 is offline   Reply With Quote
Old 04-28-2008, 05:17 PM   #2
dpgrand
My Ride: 2005 330xi
you don't even need a lift. Run a search as I have seen at least 4 threads with header installs
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 11-01-2008, 11:49 PM   #3
dakkon
My Ride: e46 330ci/e30 318is
when i installed my headers it took me about 4 hours or so.. the headers took me longer to do than replacing my diff, or entire suspension.. the reason for it taking so long is due to the tight area to work in.. You will need to unbolt the passenger side motor mount, and the brace to the block. I used a 6 ton jack with a 1/2 piece of wood to spread the pressure out over the oil pan. I removed the forward header first, then the aft one was not as bad to remove. One other thing that added to the time, is the fact my car is a new england car so the bolts/studs were rusted together and not easy to get out.
dakkon is offline   Reply With Quote
Old 11-01-2008, 11:54 PM   #4
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
http://forum.e46fanatics.com/showthread.php?t=573566
Drew@Swift Motorworks is offline   Reply With Quote
Old 11-01-2008, 11:56 PM   #5
AntB
My Ride: MTA :(
So if it took someone in a garage 4 hours to install, a $750 price is ridiculous.
** Tim330i waz hur **
AntB is offline   Reply With Quote
