Old 04-25-2008, 12:07 PM   #1
Xeek
My Ride: 2000 328ci, 2010 328
Send a message via AIM to Xeek Send a message via Yahoo to Xeek
Steering Wheel Buttons
I use the buttons on my steering wheel a lot, the ones for the radio. It's much easier for me to press these rather than reaching over to the radio. I'm guessing the previous owner never used these, because now that I've had the car for a month or two some of the black paint is coming off (very little). I can start to see specs where the light shows through at night.
Whats the best way to repair this? Some kind of touch up paint? I'm really unsure hwo to go about making this look right again, and then to prevent it frmo happening again. I think if I keep using the buttons the whole button will wear away (will just look horrible).
2000 BMW 328Ci
2010 BMW 328i LCI
Xeek is offline   Reply With Quote
Old 04-25-2008, 02:20 PM   #2
jwm5
My Ride: station wagon
Paint wearing off the buttons? I use my buttons all the time and have never had paint come off on my fingers... maybe the previous owner used the buttons all the time and tried repainting them and his touch up job is coming off on your hands. How bad does it look? try touch up paint but it will probably need regular touch up.
jwm5 is offline   Reply With Quote
Old 04-25-2008, 02:23 PM   #3
EIAlfonso
My Ride: 2011 535xi M Sport
Look for a used sport steering wheel pay no more than $40 and replace them.
I've never seen one that's worn, my guess is they may have used something abrasive to clean it.
EIAlfonso is offline   Reply With Quote
Old 04-25-2008, 02:25 PM   #4
idoc330ci
My Ride: 2003 330ci
black sharpie
idoc330ci is offline   Reply With Quote
Old 04-25-2008, 02:29 PM   #5
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
al sharpton?
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 04-25-2008, 02:29 PM   #6
soynaco
My Ride: 323i
Thats weird. Mine look glossy for being used too much compared to the + and - buttons of the cruise control which look new and are opaque. But the black paint hasn't worn off.
soynaco is offline   Reply With Quote
Old 04-25-2008, 02:38 PM   #7
Chris-TK
My Ride: Mk VI GTI
Mine have never worn off.
K.
Chris-TK is offline   Reply With Quote
Old 04-25-2008, 07:29 PM   #8
TheBirdmanJD
My Ride: 2000 BMW 328Ci
I guess me and the OP are the only guys with defective buttons...haha
Mine are worn and glazed shiny as well...my track up button and volume up.
I bought it that way and have since added to the wear. I doubt your going to be able to touch it up, but that whole module just pulls out, even if you have to buy a whole used sport wheel to get it, you only have to swap the left side button module.
Bird
TheBirdmanJD is offline   Reply With Quote
Old 04-25-2008, 07:47 PM   #9
carcus
My Ride: 2006 BMW M5
Dang, I just threw out a old multifunction button unit. I would have given you the buttons for free. I have a 04 and mine were fine, even with the bad condition M3 SMG wheel I had to recondition, they still are fine. Sharpie might be the only free option.
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 04-25-2008, 07:49 PM   #10
xi_ter
My Ride: 2003 325xi
This Duplicolor Trim paint is exactly the same finish as the black on the buttons. Just use extra fine steel wool to reduce the sheen a bit:
Old 04-25-2008, 10:41 PM   #11
Xeek
It'l be hard to use spray paint on this, taping the + and - would be hard lol... Sharpie might be an idea, Ive thought about that, and will try it, but I think the permanent market will wear worse than paint. It's getting worse each day. I dont think my car has auto volume with speed (maybe its disabled) cause I actually lower the volume on the steering wheel almost everytime i stop. I'm a heavy user on these buttons.
How does this module come off? Does it just pull off with brute force? Pry it off? I wont try that until I know for sure.
2000 BMW 328Ci
2010 BMW 328i LCI
Old 04-25-2008, 11:36 PM   #12
Arsevader
My Ride: '90 325i, '02 325it
If you have the Business stereo, hold the music note button down and then adjust the volume using the buttons on either side of it.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Arsevader is offline   Reply With Quote
Old 04-25-2008, 11:40 PM   #13
Xeek
For the speed volume setting?
2000 BMW 328Ci
2010 BMW 328i LCI
Old 04-26-2008, 12:00 AM   #14
tturedraider
My Ride: '04 Imola/NB ZHP:-)
Originally Posted by idoc330ci View Post
black sharpie
Originally Posted by wasp9166 View Post
al sharpton?
black sharpie's prolly a pretty good idea.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- George Orwell ---- If you love your freedom, thank a vet!!
tturedraider is offline   Reply With Quote
Old 04-27-2008, 11:31 PM   #15
xi_ter
My Ride: 2003 325xi
If it's that bad, buy a replacement on eBay. Should be around $50. To remove the buttons
1. disconnect the battery to avoid airbag light
2. remove 2 25 mm torx screws behind the steering wheel
3. pull horn/ airbag/ switch banks unit forward
4. disconnect wire harness for air bag and buttons. Stick a small screwdriver in to lift plastic over pin in harness
5. each switch is connected with 2 torx screws. Replace worn switch.
6. Reassemby is the reverse. When you reconnect the battery, some antilock warning lights will stay on until the car is driven a bit. Then they go out.
