Old 04-27-2008, 03:22 PM   #1
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
shifter problem... wtf
So, I have two pretty big problems with the shifter in my e30 (just bought it yesterday)
1.) The linkage/bushing is bad, which causes the shifter to wobble even when in gear. Should be a pretty easy fix...
2.) This makes me go 'wtf'... the entire shift pattern is 3-5" off, so bad that I literally have to smash the shifter into the center console in order to go into reverse. Why the hell would this happen? It's not like the transmission is on sideways or anything..
Here's a picture to illustrate:
I understand that the 'play' when in gear can be fixed, but what the hell do I do about the offset? What could be causing it?
Thanks a million for any help..
hi its me alec is offline   Reply With Quote
Old 04-27-2008, 03:24 PM   #2
323power
323power's Avatar
My Ride: '11 335i
lol just stopping by to save nice diagram...
that is all
Jeff
323power is offline   Reply With Quote
Old 04-27-2008, 03:35 PM   #3
FlzRider
My Ride: AW 1M
Maybe its actually the center console that is off-center?
FlzRider is offline   Reply With Quote
Old 04-27-2008, 03:35 PM   #4
hi its me alec
Thought of that already... nope
Old 04-27-2008, 03:40 PM   #5
Len013091
My Ride: S52 E30, 330i
Send a message via AIM to Len013091
The shifter may have been swapped to something from a different model car, causing the offset. The same type of thing happens when you put the Z3 roadster shift in an E36 or E46, the pattern gets moved up and tot he left. As for the play, that can be solved with a new shift linkage or an SSK. I'd bet a UUC SSK would solve your problems.
Len013091 is offline   Reply With Quote
Old 04-27-2008, 04:21 PM   #6
TxZHP04
My Ride: ESS TS2+ ZHP
I'd start by checking transmission and engine mounts.
If it's not that, I would start to worry about the transmission itself.
Old 04-27-2008, 11:22 PM   #7
marouli
My Ride: E46, E36
The bushings for the shifter mounting plate are more than likely shot as well as the bushing for the shifter ball. One end of the plate mounts on the trans and the other end connects to a bracket that is mounted on the body of the vehicle. Both ends have a bushing which are more than likely shot to hell. You need to look under the vehicle to see the mounting plate and bracket. Also, the shifter "ball" mounts inside a plastic cup like bushing which tends to wear out over time. This plastic bushing is mounted inside the shifter mounting plate, which can be replaced when the plate is out of the vehicle..
marouli is offline   Reply With Quote
Old 04-27-2008, 11:41 PM   #8
deafboy
My Ride: 2000 323Ci
I believe the only solution is to drop a S50w/5 spd in there...
-Cole aka bigtall*****
Originally Posted by Owtlaw333 View Post
You'll always be pretty in my eyes, Cole :luv:
Originally Posted by Chrissspyy View Post
i was like passed out while she's shoving the entire bar in my mouth. :rofl: :rofl:
deafboy is offline   Reply With Quote
Old 04-27-2008, 11:49 PM   #9
Len013091
That won't fix his problem, he needs an S54 in there.
