Old 04-27-2008, 07:29 PM   #1
dragos
My Ride: 2000 323i
Wth?
I was getting ready to change my oil and I was looking around my engine bay and I saw a plug attached to a plastic bracket just hanging out by my exhaust manifold :[ What the heck is it and where can I plug it back in? Its a little more then discomforting. Perhaps it explains my check engine light...
Here are the pics
dragos is offline   Reply With Quote
Old 04-27-2008, 08:26 PM   #2
dragos
My Ride: 2000 323i
Anyone? Help?
Old 04-27-2008, 08:36 PM   #3
325CI2004
My Ride: 09 335I
have you scanned the code for the CEL?
I wont be able to offer much help as i drive a 325 and my bay is a little different. Just look around on that side as see if there are any plugs.
Easiest course of action is to read the code first.
09 E90 335i Alpine White/Chestnut Brown
325CI2004 is offline   Reply With Quote
Old 04-27-2008, 08:44 PM   #4
zeshon
My Ride: S/C 2000 328Ci
Don't bump within an hour.
- Austin
Favorite sponsors
Bavarian Soundwerks | Euro Spec
Mods : Performance : Active Autowerkes Stage 1 C38 New Subframe and TMS Rear Re-Enforcements Upgraded VANOS seals M3 Fuel Baffle KW V2 ZHP Control Arms E60 Short Shifter Sound : Bavarian Soundwereks Stage 2 DICE iPod Link Looks : Replica M3 Mirrors Replica M3 Front Bumper Matte Black Grillz LED Signals
zeshon is offline   Reply With Quote
Old 04-27-2008, 09:05 PM   #5
EvilGenius
Banned User
My Ride: '02 BMW 330Ci
Could be....
Well I'll preface that if you can't find anything to plug it into over there, it is very hard to tell without seeing what DME codes are being thrown.
That being said, Bently manual shows the following signal wires in that vicinity:
1-Secondary air injection actuator signal line-plugs into little round vacuum actuator near piston 1-2 I think
2-O2 Sensor (but I think this is a 3- or 4-wire connector so likely not that
3-VANOS Solenoid signal line-plugs into very front solenoid at front low on the head
4-Exhaust cam position sensor-this should be in the very back of the block, but not sure if it plugs into a wire or directly into the sensor.
Botton line, pull the cover, use the eyeballs and read the codes. You'll find it!
EvilGenius is offline   Reply With Quote
Old 04-27-2008, 09:53 PM   #6
mechanic_101
My Ride: 2005 325I
since it has 2 wires, i think it is for the air pump.
mechanic_101 is offline   Reply With Quote
Old 04-27-2008, 09:59 PM   #7
EvilGenius
Banned User
Ahh, found it....
Looking at where that wire was coming from had me curious, and it had a ground (brown) in it, which most things ground to chassis, so it's usually not there. Soo, I just stepped out and looked under my hood and found it in about 10 seconds. This plugs into your windshield washer fluid pump. Sorry to say, no code for that one in the computer! Something else is out of whack too.
Hope this helps! Good luck.
Old 04-28-2008, 12:22 AM   #8
dragos
My Ride: 2000 323i
I must have missed that in the rules section, my bad.
Everyone else, thank you very much, I appreciate the help.
I'll check tomorrow morning to see if its from windshield washer fluid reservoir or pump.
